Everything posted by Rooster2
Did a search and came up with nada for KYB
Rooster2 replied to lesstutrey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry this KYB link.......http://buykyb.com/catalog/ You should be able to find what you want at this KYB website.
96 Legacy: Manual shifter "feel" different from other car brands?
Rooster2 replied to brycarp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea, that is the first thing I thought about was worn shifter bushings. Like others have responded, it is not a big thing, and it is not expensive to have the bushings replaced. Prolly something you will want to consider.
93 Legacy Loosing Electrical Power, Engine Stalling (Relay, IAC?)
Rooster2 replied to mentis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll your symptoms point to a bad alternator. I don't think fusible links are an issue. Replacing the alternator is rather easy, if you are handy with a wrench. If car is no longer drivable, remove the alternator, then take to a parts store. They should be able to test with equipment in store to tell you if the alternator is bad. It is never good to have a break down. To break down on Christmas is a real bummer. I hope a replacement alternator solves your problem. Let's hope that 2011 is a good year for you.
Overheating on hills?
Rooster2 replied to dhoch14's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoesn't surprise me that the Chinese thermostat was the source of your problem. If the shop did the original work, I hope they did not charge you to replace the thermostat again. I don't think that 85% of Subies develop HG issues, but it still has been sizeable problem the last 10-15 years, well more like years 97 thru 04. Last 6 years seem to not had the HG issue.
Help. whats wrong with my 2.2
Rooster2 replied to dieselboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it doesn't over heat, then I wouldn't be concerned about HG trouble. Sounds more like a bad thermostat is your problem. If the 2.2 motor cooling system is like the 2.5 motor, then the thermostat is in the engine block where the bottom hose connects to the engine. It is easy to get at. If you replace the thermostat, go for an OEM Subaru thermostat, or top of the line after market unit. Cheapie thermostats don"t work well in Subies. If you go after market, make sure that the new thermostat uses the same length spring coil as the OEM, and is not a shorter coil then the original. It is those "shorties" that don't work well. You may want to check first to see that your radiator is full, and there is coolant in the over flow container. Running low on coolant could also cause the problem that you are having.
Frankenmotor, whats the big deal?
Rooster2 replied to Ionlyhave3suubs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes a Frankenmotor become an interference motor?
02 Outback bucking on acceleration
Rooster2 replied to Ionlyhave3suubs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is possible that you may have bought a tank of gas that is tainted with water. Water doesn't burn well, and can cause the bucking that you are encountering. Suggest you add some "dry gas" additive to the fuel tank. It just may solve your problem. Not long ago, a gas station near here had a bad seal on the fill pipe at ground level where the transport pumps gas into the tank. The bad seal allowed a lot of rain water to enter the tank. The result was a number of cars stalled just blocks from the station. That is just a severe example of what can happen.
Rooster2 replied to dhoch14's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny chance that the antifreeze wasn't changed in many many years? If so, crud and rust build up prolly has occurred. Use a flashlight to look down into the radiator under the cap to look for crud build up. If you can't see the core, pull the top radiator hose, then look in with a flashlight. That alone can cause over heating, because the radiator doesn;t allow good coolant flow.
Rooster2 replied to dhoch14's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRight on.......a poorly designed thermostat can cause the problem you are having. Even if new, a cheapie thermostat just won't work well on a Subie.
Let's forget about Subaru problems.......
It's Christmas......... Time to wish everyone on this forum a very Merry Christmas, and a Happy New Year. Larry (Rooster2)
back pain from my seats?
Rooster2 replied to afterbang's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea, same problem with my 99 OBW. The seats are not very good......just too hard with poor back support. They are okay for short trips around town, but close to lousy on a road trip. Now my wife drives a 98 OBW Limited with the leather seats. Those seats are great. Does anyone know if seats from years 2000 to present are better seats, and will just bolt in?? If so, maybe find a decent seat for the front from a wrecking yard. Also, do Impreza seats or WRX seats just bolt in? Are they any good??
Do I take it to the shop or buy a compressor?
Rooster2 replied to jdd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHarbor Freight Co sells an electric impact wrench. Cost is about $50. It works surprisingly well. Besides your job, it is a great tool to have in your garage for future projects.
99 OBW--tire size recommendations??
Rooster2 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDecided to go with Fisk tires available at Discount Tire. They only carry one model with the Fisk label. I have read on the internet, and a worker bee guy at Discount said the tire molds are from Michelin, prolly a tire they don't make anymore. He said the Fisk tire is good, with no "come backs" with problems to their store. I am not kidding myself, these won't be Michelin tires. Michelin could have sold the molds to another company, and prolly did. Hey the price is right at $64/tire in the OEM size of 205 X 70 X 15. Going to 215 X 70 X 15 cost $77/tire. A $13 dollar price increase in one tire size is not worth the upgrade. Yea, I would really want better tires, but finances are really tight right now, so a buck saved here and there is where I am at. I live in Indy, where heavy snow is usually not a problem. So, no one around here ever puts chains on the tires. Discount Tire has been good to me the last 5 years that I have bought there, so I will be loyal to them. Free flat repairs on any car I bring in has saved me some money, even fixed tires that I did not buy from them. You won't get that free service from a Good year or a Firestone store. I will report back how these tires hold up and perform.
3.0R engine longevity
Rooster2 replied to Gentz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck Edmunds, NADA, Kelly Blue Book price guides on line for used car prices, per your zip code, and by millage. Do print outs on each. You should be able to see suggested retail price when for sale by owner, and by a dealer. Print out the results and take with you as a negotiating tool, if and when you make an offer to buy the car. You don't list what year the car is, to be able to advise you if $11k asking price is good or not. 161K miles on the odo will certainly lower the value of the car no matter what model year it is.
help sliding bolt stuck in caliper 00 outback
Rooster2 replied to 000utback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 on using PB blaster. I did my brakes last summer on my 99 OBW, and had a can of PB blaster with me while wrenching. I used the stuff even before putting a drive socket on any bolt that looked rusty. Suggest using antisieze graphite cream on all bolts and slides upon reassembly. Makes the job a lot easier the next time you do a brake job.
I have a 99 Leggie OBW with standard 205 X 70 X 15 size tires. I need to replace the tires. Is it better to stick with the same size tire, or change to a 215 X 70 X 15, or possibly to a 205 X 60 or 65 X 15 size tire? I have looked at tire prices on line, and all the above sizes are about the same price. I am not concerned about loosing or gaining a little ride height, or having the speedo off by a few mph. I am guessing that the above sizes won"t cause any rub issues. I am thinking that going to one of the new tire sizes that have become available in the past 10 years may offer better handling, grip, or a better ride. There must be a good reason why 60 or 65 size profile tires became available. I did a search in this forums archives on this, but didn't find any previous post addressing my question. Anyone have any thoughts or knowledge on this?
line to line is not a quart on the trans
Rooster2 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI learned this lesson too the hard way like you. I finally figured out, and also read here on this forum that low to high on the ATF dip stick is only a pint. Suggest you drain the extra pint from your trany. There is a screw in drain plug on the bottom of the trany pan to drain the fluid. Looks just like the drain plug on the oil pan.
97 legacy outback - replace passenger outside mirror
Rooster2 replied to DavieGravy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI replaced the pass mirror on my wife's Leggie OBW a few years back. I don't remember the plate, but do remember that there were three Philips head screws holding on the mirror onto the door. Those screws were on super tight. One screw in particular is recessed, and difficult to access through a small hole in the door sheet metal. I couldn't get enough leverage with a regular Philips screw driver. The screw driver just kept slipping off the screw head. If you run into this problem, use a 3/8" driver with an extension, with a phillips tip. Push in really hard on the driver head to prevent the screw driver from slipping, then rotate the driver handle to loosen.
1995 Leg Sedan.... drums or rotors?
Rooster2 replied to mikeamondo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa bad (sticking piston) in the caliper on a disk brake system will cause the problem you describe. Replace the caliper fixes the problem.
cleaning the engine
Rooster2 replied to LanceDa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't drive around, maybe just let it idle in your drive way for about 15 minutes, then drain, and add fresh oil.
Input on minor tune for 98 Outback, SAN DIEGO
Rooster2 replied to ferox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe replace the EGR valve. EZ to do.
Flat tire caused torn boot?
Rooster2 replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor what it is worth........someone wrote on this forum not that long ago, that they add grease to a torn boot, then wrap the entire boot with seran wrap. Yea, seran wrap clings to itself, but who knows, this band-aid approach might just work to stop the grease from flinging back out. It is a cheap and easy "worth a try," can't hurt to try this.
Replacement bulb 2000 GT
Rooster2 replied to daddycool100's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood call on the bluish tint to replacement head light bulbs. I got suckered into a pair of those bulbs some time back. They looked really cool, when looking at the front of your car to see the bluish lamps, but light output was terrible when driving. I ditched those bulbs in a matter of days, and went back to OEMs. There are now brighter bulbs being sold these days. I can't remember the manufacturer, but saw their ads on TV some time ago. Suggest you talk to any parts counter guy at an auto parts store, and ask his opinion. The guy who sells them should be able to point you in the direction of who makes better bulbs.
Snow dumps hurt cars. Error 55
Rooster2 replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell if it is simply a reminder to replace the EGR valve, it is a simple and inexpensive project. Buy the part at a parts store, then remove old one, install new one, with minimal labor involved. The parts store counter guy should be able to tell you where to install the new EGR valve. Heard on the news about your massive blizzard snow storm, and the roof falling in on the Metrodome in the cities. Winter starts in another 9 days.......how much worse can it get?
98 OBS will not start Electrical problems FIXED
Rooster2 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know it is a little late to tell you now. Several companies sell stereo installation kits. It makes installation of an after market radio real simple. Simply remove the original radio, then plug in the the installation kit harness into wiring into the car's wiring system. This eliminates any wire cutting that the college kids did.
