Everything posted by ivantruckman
Heater problems !!
ivantruckman replied to oskar_subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
or possiably the relay itself -
93 Loyale Alternator and Blower
ivantruckman replied to Rick James's topic in Old Gen.: 80's GL/DL/XT/Loyales...
"The blower already gave up on settings 1 & 2 a long time ago but I think that's a different issue, one I wasn't concerned about as long as I had setting 3 & 4 working. " I was refering to the "settings 1 and 2 gave up" portion of his remarks -
we could nail it if you have pics ? just a thought
the blower problem sounds like the relay is bad, its one of 4 round metal relays under the left dash panel above the fuse box also the blower speed problem is caused by the resistor block the resistor coils are burned out. thats under the passenger side dash , one of the screws for the blower motor mounts this block -
Brat Rebuild. Now with Photo's
ivantruckman replied to xoomer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
good gawd man, your taking alot of interior apart , why for ??, awsome brat -
what to look for when buying a Loyale?
ivantruckman replied to Ceejus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I abuse my loyale , i have 15 inch Chevy 6 bolt rims , and I'm running 205 60 15 , snow tires. about 24 inch over all diameter, we don't have huge mountains here in Michigan. so allot of torque isnt that necessary , you wont be spitting up 30 ft roosters in the mud . but loyales rock, and deserve to be punished. -
Winterforce Tires
ivantruckman replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i used them in the clay mud, they suck fot that. they load up too much, but there awsome in the snow and ice -
87' Gl Wagon Blows the doors off an RX8
ivantruckman replied to phantomcrooner's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i do that too, only it has to be snowing when i do it -
cold start stall/hesitation
ivantruckman replied to tehweej's topic in Old Gen.: 80's GL/DL/XT/Loyales...
cool so there is no choke, maby he has an IAC , or TPS malfunction -
1297 P.O.E. i think they mean P.O.S.
Low mileage Japenese motor? EA82
ivantruckman replied to subcyclist's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i thought all they had was ea82 turbo engines, unless you have a turbo set up, that would be bad -
i thought all loyales were mpfi, not carburetor ? -
So I Got the Old Axle Out And.........
ivantruckman replied to BEECHBM69's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the rusty grease and scoring could be from a previous bearing job -
Loyale alternator issue?
ivantruckman replied to BANgLE's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yep regulator is going out, good time to do a GM alternator swap. there alot cheaper and last longer -
Good products for older subarus
ivantruckman replied to 88coupe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
shocks... KYB via Ebay. awsome -
92 loyale oil leak from head ?
ivantruckman replied to ivantruckman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i did the cam seals and orings, the engine was out , i pressure washed it , it is defiantly leaking from the head, is there a gasket for the cylinders to the block, i only have the head gasket -
Look What Followed Me home!!
the left hedlight switch , thoes switches look like nipples to me -
Is there any other way? - Heater Core clogged
ivantruckman replied to Deener's topic in Old Gen.: 80's GL/DL/XT/Loyales...
+ 1 on draino, you can have some sort of mineral scale buildup, muriatic acid works good too, just be careful of splashing it in your face, sounds like you have it isolated from your engine already, good luck -
just replaced the cam ,crank seal valve cover gaskets, even the pan gasket, no oil leaks for the first month, now I see an oil trail from the head gasket, no compression problems, no coolant leaks, can an ea82 leak oil from the head gasket ???, never had this problem on the 3 other front reseal jobs Ive done
Looking for a good lift
ivantruckman replied to mattbob1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
just Google "SJR lifts" he's a Bord member, in bellingham WA, -
they took out her left nipple, the brutes, who did all the switch pulling? -
Another 93 Loyale..Tranny Seize?
my loyale did the same exact thing, i found a used auto trans off ebay for 350 bucks shipped. took about 3 hours to put it in, and bam, 30 k miles later, still driving it, if it happens again im gonna convert it to a dual range stick, alot better gas milage.. good luck
