Everything posted by 2K4 STI
Trans and Diff Fluid.... What Kind
Just want to see what others are using for the Transmission and Rear Diff Fluid.Brand and weight Want to change mine in the RX but am not sure what to use. TIA
LSD or Not
:confused:
LSD or Not
Cleaned all the crud off the rear diff and it is a LSD.
LSD or Not
So my 87 Turbo RX should be LSD.
Transmission info, what will fit?
- LSD or Not
Thanks Guys,Ill check the rear Diff tag and if its not there ill try with the rears off the ground. What Models and years came with the LSD?- LSD or Not
How do you know if the rear is a LSD or Not?- Brought the RX home today...
I probally should have started my own thread but this one seem to get out of hand on that subject Back to the originally scheduled program.- Brought the RX home today...
In the ON position it is fine.In the Off position is when it binds when turning. Where are these solenoids and if i switch the vacuum lines will that change when the light is on?- Brought the RX home today...
Thats why i leave it in the ON position which is actually Off. Any ideas on what it might be or should i just check the wiring?- Brought the RX home today...
Great Thanks Junkie Another quick ? My diff lock switch is in the On position but the light is not on.When i move it to the Off position the dash light comes on- Brought the RX home today...
Thats a good looking RX When is the 4WD light supposed to light up?Ive never seen mine and didnt even know there was one. LOL Ive only seen the green turbo light and the Diff Lock Light and thats it.- EA82T tps question
Where is the stock fuel pump?- EA82T tps question
Does the Walbro 255 for the WRX fit the EA82T gas tank in a 87 RX? I might upgrade now just to see if that cures the problem.Plus i wanted a better fuel pump anyways.- EA82T tps question
Mine does the same thing 87 RX EA82t Seems like the throttle is either on or off no in between- Rear wheel bearing price?
Might check on http://WWW.RockAuto.com- Just bought my new Ride
Which route are you taking back? If you come through Vegas come and see us http://www.Flat4LV.com We have a weekly meet every thursday night,usually about 30+ cars show every week- Painting Interior dash and trim??????
Looks like the VHT is the way to go. Thanks For the link 86BRATMAN If i can do it pretty soon ill try and snap some before and after pics- Painting Interior dash and trim??????
Can the dash and interior pieces be painted and what is a good paint to use? I know the plastic pieces can be painted but im not sure about the soft dash pieces. My interior could use some new life to its color.- Just bought my new Ride
Nice :grin: How was the drive back Home?- Anyone have FSM's for 1988 RX's?
If you can find the PDFs i would like to pick up a set also.- Please Read! EJ swap write-up: ver. 2.0, now in .pdf form
I wanted to take a look at this PDF but just says site maintenance. Can this be downloaded somehow? TIA- 17" Wheels on a RX????
Thanks for the link NumbChux- 87 RX sputters
NGK BPR 6ES11 are these for a EA82T and gapped at what??- 87 RX sputters
Well i finally got all the tune up parts done.I did them in stages to see what was actually causing the sputtering. 1st stage Spark plugs Autolites #63 /cleaned Maf No change 2nd stage Spark plug wires No change 3rd stage Cap and rotor No more sputtering :grin: Turned out to be the cap and rotor causing it. Thanks for all the help guys :clap: - LSD or Not
