Everything posted by 2K4 STI
Subaru OEM part number research?
AAhh Ok,Have you tried just calling the dealer and asking them or do you have a bunch of #'s to check?
If you have the part # you can enter it here and see what comes up https://www.subarugenuineparts.com/oe_parts_cat.html
Holy Grail of EA82 rear shocks found!
Ok so let me get this right. Miata short rear struts with the adjustable coil kit and 92 FWD Legacy Fronts.Do they make a coilover kit for the legacy fronts or are those stock springs you are using in there? Just found that the 93+ Impreza and the 92 Legacy use the same struts in the front.
Has anyone tried those eBay shop manuals on CD?
I always hate when people post these things after ive bought something. Thanks for the link though,always helps to have more manuals.
I just bought one which is the Mitchell repair manual on CD and it has a ton of info on there. To me its worth the $15 or whatever i paid for it.
Is there a demand for bolt pattern adaptors?
So you are not or cannot make them like this but rather an adapter that bolts to this piece or is it not possible with the mounting bolt placement?
How did you break your first Subie??
04 WRX Revved to about 8500 with Pics of Carnage :-\
Rim and Tires Question
When did you sell it and to whom?
What turbo does the EA82T have?
You can always buy the DP flange from SubaChad and make your own http://uniquemotorsports.com/
Thanks TheSubaruJunkie for the pic also,Looks good
new RX STi pics
Sounds pretty good For the coilovers is that front and rear as i thought the rear mount differently?
new RX STi pics
Which Ebay coilovers are you using? Im using a passenger side door from a 87 GL thats in the JY.Same color as yours too.Actually its gave up alot of parts for my RX
The only problem i see with using adapters "on our cars" on top of the existing hub is the extra spacing of the wheels created by the adapters. This might not be a problem if you can find the wheels you want in the correct offset,and depending on if you want to lower or keep your car at stock height. Most shy away from adapters from the "rumors" of extra wear and tear on the wheel bearings
new RX STi pics
Everytime i see someone elses RX it makes mine look more and more like
If you could make this piece below with either the 5x100 or 5x114 would probally be the best. Id be interested in these but not adapters.
What size are these rims??I know they are 13" but how wide are they and what size tire will fit on them?? I would like a 205/60/13 but is that to wide for them?Or is a 185 like Numbchux is running the widest?
Another Harry's in Hazleton update
Damn, thought i would ask just in case
If the XT is an XT6 AWD please let me know as ill pay to get the Rear Hubs and backing plates from it.
Just curious what size tires you were running on the white rims on the first page there? Im giving up on the 5 lug thing for now and am just gonna run them white spokes.Cheap and easy to find in the JY
Low Voltage Problem PLEASE HELP
This was the easiest Alternator swap i have ever done. 2 Bolts and the belt and thats it. Cleaned all the battery cables and made sure all the electrical connections are tight and much better now. Thanks for the Help guys
Exactly 2 days later mine died on the way home last night.I made it home with the Headlights and radio off. The car died in the carport
OBDII into an EA81 documentation?
It will be awhile before its even done as im still collecting parts but it will get done eventually :rolleyes:
2008 calender
Ill take one How and when do we pay for these? oh and whats all in them or did i miss the Calendar thread? :confused:
5 lug rear hubs
GrossGary Pming you
Ok thanks guys,Theres a RX in the Jy with a fairly new looking ALT on it,Ill snag that tommorow and clean the terminals on the battery at the same time.
