Everything posted by 2K4 STI
5 lug rear hubs
If it was that easy to find them we would already have them by now.There are several of us looking for the XT6 parts :-\ With no luck
Low Voltage Problem PLEASE HELP
On my 87 RX EA82T this morning the Charge,Brake Fluid and Stop Light,Lights were on and the Voltage gauge was just below 12V. It was fine last night when i drove home then this morning these were on. as i drive they go away but when i stop at a signal they come back on. Any ideas on what to check? Not sure if the Alt is going bad or the battery or something else. TIA
OBDII into an EA81 documentation?
Im also working on the wiring aspect of the EJ20 WRX motor swap into my RX. Just the harness for now but its a start :-\
5 lug rear hubs
Im wondering how much it would cost to have some Billet adapters made that would replace the 4 Lug Plate with the 5x100 pattern,Keeping the stock rotors in place. Just a dream, but it would be nice if the adapters were not to thick to upset the offset of the wheels. Im at the point now where im thinking of filling the holes and redrilling the stock plate
EJ22T into an RX. Here we go
Any progress on your project? You can always do a scoop like this one.Looks like a sectioned down WRX scoop. http://www.cardomain.com/ride/2391065/4
EA82T Oil leaks
Thanks guys. Ive torn down and rebuilt the engine in my old 04 WRX before so hopefully doing the front seals on this engine wont be so bad.
EA82T Oil leaks
This is spawned from Huck369's thread about the EA81 oil leaks.My 87 EA82T leaks from what looks to be the front of the motor. What are the seals that should be replaced on the front of the motor?Im planning on doing the oil pan at the same time but dont know what seals lurk behind the timing covers.
Holy Grail of EA82 rear shocks found!
Which shocks are you using Front and rear then? Where the stock shocks blown as the car doesnt seem much different in ride height from the stock to the miata shocks? And do you think 17" wheels would still fit in there,By chance?
Dyno run with my coupe
Heres the link i found http://forums.nasioc.com/forums/showthread.php?t=1375626
And these would be posted where??
Blow thru Maf setup??? Anybody
Thats what i was thinking but i wasnt sure on these cars
Has anybody else tried this setup http://www.ultimatesubaru.org/forum/showthread.php?t=64741&highlight=exhaust Just curious how it runs and if you would have to do any more tuning after doing this.
wiring harness conversions 90-94 EJ22, EG33 SVX, 02-03 Ej20 WRX, and more
Can you do a harness for an EJ20 Wrx motor swap into a 87 RX EA82T?
Lets talk about an EA-EJ swap in the Loyale
Can you use a EA82 clutch on a XT6 flywheel? or are they the same?
How to Adjust Idle Speed
Cool thanks guys,ill be trying to adjust it tonight after work
How would the D/R 5 speed hold up to the 227 HP of the WRX engine?
This is one of those things that a pic would be worth a thousand words Where would this screw be located on the manifold?
My 87 RX with the Ea82T when warm idles at around 1200 rpms.How can this be adjusted? Can the linkage be adjusted or does the TPS control that? TIA
How much of this would apply to an EJ20 from a WRX?
another member added to the herd....
Nice purchase How much did you get it for if you dont mind?
Show off your roos Mileage!
My 87 RX just turned over 124,000. When i bought it 3 months ago,it had 121,xxx Not too bad 124,000 in 20 years = 6200 miles a year
Trans and Diff Fluid.... What Kind
Cool,Thanks alot guys I would shy away from Uncle Scotties cocktail as i used that in my old 04 WRX and it made the trans grind going into 4th gear and sounded like it was going to fall apart.I put the stock trans fluid back in and all was good again. This is just my experience but others seem to like it.
LOL,sentences Own Me Yeah How much
I should have put this in my OP but how much fluid is needed for the trans and rear diff? Thanks Junkie
Cool,thanks Do you remeber what the additive was by chance?
