Everything posted by bobaru
gen years
what years are the gens 1st gen 2nd gen 3rd gen 4th gen 5th gen models included please
numberonestunna getting lifted Gen2 hatch
Jeff you are the man. I cant believe its that easy. my wagon is comin to you:banana::)zzz:Flame: youre the teacher Im the student Bob
Ea82-ea81
X2 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^x2^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^x2
Lost MPG???
Ok your not going to believe this check your charging system and battery weak battery = weak spark your battery may be good to start it but not good for the best spark
Lost MPG???
opps I should have read your post better I see you did change filter
Lost MPG???
when a car sits that long in wet areas the air filter can get damped- dry -damped -dry on and on well you get the story
My XT Turbo Runs but has some problems...
on my hatch it leaks water at the thermostat housing
Weber parts
you mite try carbsunlimited from what i understand ther good to work with http://www.carburetion.com/
Ea82-ea81
one more bump also http://www.ultimatesubaru.org/forum/showthread.php?p=820026#post820026
swaping motors
thank you ihscout54 I guess I'm blind I searched the older posts but missed that one. anyway. can I use a power steering pump off a ae-81 wagon? also on 2nd thoutht I think the hatch is 06-82 month and year. Ill recheck the build date tomorrow thank you
swaping motors
Ok heres what I got 87 gl wagon, weber, power steering, really BAD cause of T.O.D... blown timing belts. I bought this 83 hatch, no title, rust, manual steering,motor runs GREAT well after beatin this body to death driving it in quad trails out in the back forty Ill be pulling this thing apart. now for the ?'s where do you get a weber EA-81 plate ? can I use the wagon Y pipe we distroyed the hatch's pipe power steering is that a PAP part or will the 82 fit on the 81 also any other parts should I save for the swap Ill be savin some stuff off the hatch after this hatch Ill be needin another
JDM engine hacked
you DEMAND your money back---------3 broken bolts = MONEY tool time - getting tools& parts (taxi's cost money) tool rental-hoist (you dont own the one your using your renting) your time removing bolts = money most important what if you damage the block getting those bolts out. your out ONE motor ==MONEY
Blower resistor question
Dude I plan on doin that. But if I find another one without paint is it possable
Awesome video I made of my lifted wagon in action
PLUS that is the best suby flick Ive seen
I got one from a nieghbor that has no paint on one of the three coils. ?1 is it useable of couse it is but for how long?--- guess please ?2 is there any way to repaint it? if so were do we get the stuff to fix it? Ive pulled 3 out of PAP cars all shot
manual choke?
I put a manual choke weber on my 87 wagon runs great I need ideas ? is where did you mount your cable? pics would be nice hint hint thank you
What oil to run
yes more input please I bought this subaru with abad carb so in other words it didnot run webered it changed oil with delo 400 15/40 runs GREAT but the lifters tap [ off&on]
wats your mpg old soobs?
87 gl 4WD wagon 5sp 142,000 miles weber 245 miles 8.6 gallons 28.488 MPG's
rear diff flush
my link failed to wiki just goggle limited slip differential lots of info
rear diff flush
NEVER EVER flush a limited slip diff the clutch disks in the LSD,s NEEDS a limited slip additive If you were to put seafoam, marvel mistery oil, ATF,....ETC ETC ETC it will dieloute the additive and FRY the clutch packhttp://en.wikipedia.org/wiki/Limited_slip_differential
vac line
Ok im changing out my carb to a weber 87 gl ea82 4WD 5speed H/L power steering power brakes ............. No air no power windows just a basic gl there is a vac line that runs with the 2 fuel lines that are clamped behind the altanator. the vac line goes into the firewall of the car just below the wiper motor. any body got a idea what its for? thank you
weber install help
ISEE said the blind man
weber install help
thank you Tom Today I found a post written by loyale 2.7 turbo GREAT pics on the PCV routing http://www.ultimatesubaru.org/forum/showthread.php?t=53143&page=2&highlight=weber+insta ll EGR valve how can I get that part to work? or do I need it, or disable it, or where can i buy plates & plugs to remove it. again thank you Bob
weber install help
ps does the stock carb have 2 fuel lines? and the weber only 1? which 1 do i use? top, bottom, both???
weber install help
Hi guys names Bob this is my first post I've been reading this forum for quite a while. Lots of good info here. Now for my ? friday I bought this 87 gl wagon 140k on body 75k on japan crate motor. maintence records going back 10 yrs. 300$ well the carb is shot so monday I order a weber kit $333.33;) what vac lines ect ect do I keep & do I remove? so far Im keepin dist. pcv. and the line that goes to the vac can on pass side strut tower. Am I correct? thank you in advance Bob
