Everything posted by Caboobaroo
EA82 waterpump replacement
yup but make sure you only put a thin layer on it or else it'll seep into the coolant passages and make its way around the system. Bad juju...
colorado members i need a transmission
IIRC, all Full Time trannies have a diff lock, regardless of single range and dual range.
is a ea71 weber adapter plate the same as ea81?
Yes, EA71 and EA81 carb adapters are the same. I was running an adapter from an EA81 on my FE 1600 in my Brat.
Paint prep
I guess I can chime in here since I work in a bodyshop. Anyways, rust is bad, we all know that. Thing to do. Grind out the rust firs off. Get some One Step or other rust inhibitor. Apply to the area that has the rust on it. Usually, the inhibitors will have a "rust into primer" sort of deal. I've been using some at work recently and works awesome. Next, roughen up the area with some 36 grit on a grind wheel if the area is a little lower then the surrounding area. Apply some Evercoat or other glaze filler to the area, since it shouldn't be deep enough to need the application of a rough filler (like Bondo). Next, sand the area down to make it smooth, apply some Etch primer (apply to bare metal to prevent rusting as well), then use regular, sandable priner to the area, block out the area if needed and reprime, then use 400 grit wet/dry paper before painting. When painting, if using a two stage setup, apply a sealer to the area, spray the base color (3 coats IIRC), then 3 coats of clear, let sit for a few days or a few minutes if in a bake booth, then call it good. But like said before, you'll never truely get rid of the rust, you can help prevent spread of it and such but that spot will always be there and if exposed to the elements again, it'll start to rust...
Look in the marketplace Jeff...... I have a thread I started there:-\
Spottings at Colorado Auto Parts today....
Keith, how much would that SPFI engine go for?
Old School Meet! Wyoming/Colorado guys and gals! Sept. 23rd, 2006
Maybe I should help you and you can have two there:brow:
78 Brat to Dual Range Swap
Well one thing you'll have to do, if you just plan on swapping the tranny, is to pull the engine and put an EA81 bellhousing onto it. The EA71 in your Brat has a top mounted starter where the EA81 engine has a side mounted starter. Another thing is, lifting it is going to be tricky, not with th front, but the rear. Unlike an EA81 4wd car, the torion bar tubes, are seperate from the trailing arm pivot tube, whereas the EA81s have the torion bars inside of the pivot tube. This will present a problem since the torion bar tube mounts on the underneath of the body, will require some ingenious mathmatical engineering to figure out the angles and lengths of the lift blocks. Overall, sounds like a fun project! Can't wait to see some pics of it done!
I'll try to make it. I got my Bronco back, guy backed out on me leaving me with it (damn...). However the plates are expired and so risking driving it that far would be a baaaaad idea. I don't know if I feel like renewing them yet or not.
RX Powwaa! A few Q's
looks like it could be in relation with our Loyale RS's. They came very simliar to what you have. Basically it could be upgraded to an RX wannabe, but not a TRUE RX. Doesn't look bad though;)
Carpet Kit installed : 73 Splitgate :: PICTURES ADDED!
Shag?
EA82 bolt to an EA81 trans?
Yess an EA82 will bolt up to an EA81. People who own EA81 4wd cars, tend to bolt up a EA82 5-speed dual range tranny for the better gearing for freeway driving and such.
Yes I am interested as well! I'm planning on restring my Brat this winter and would like new carpet!
Excessive oil in PCV
mine seems to have a little more oil coming from the driver side, but the passenger side does it almost as much. It started doing it when I got hard on it one night. I didn't have any breathers or hoses on it, just open valve covers.
Opening crumpled tailgate
easiest way to get it open, and if you're replacing it, is to get an air hammer with a special sheetmetal bit on it. I've used one to get to the inner workings on a Avalanche door that was smacked so hard in the side, that the mechanism was FUBAR'd and door wouldn't open.
Yup, my RX is doing the same exact thing. I think I'm going to go with a stock turbo shortblock if I decide to keep the car. If not, part out city...
HELP! Need EA81 Non Vented Caliper
AND you need a gen 1 caliper my friend, not a gen 2. You can however, swap some vented rotors and calipers over and they'll bolt onto you stock hubs. Much better braking performance.
WTB 78 California Ignition unit OR 80's electronic disty.
Gotcha. Let me look around, I think I might have a couple laying around!
I have a good hard one for you guys
Have they checked the vehicle speed sensor? I believe that is in the tranny and if its bad, it'll make the speedometer not work and will throw a code for a VSS. Also, you say it puts the CEL on. What code do you get when it's pulled? That should help determine the problem right there.
TD04 or VF7?
You have to remember, the plumbing to put the intercooler in there is going to be different. Its not going to be a bolt in deal. You'll need to figure out the piping you'll need to get it to work. Also, plumbing to go from the airbox to the turbo, another deal that has to be worked out. Then plumbing to go from the intercooler to the throttle body. Its not exactly the same on the Imprezas. You'll need a reducer the right size, to go from the intercooler to the throttle body since they are not the same size.
Thought of doing an EA81 electronic disty swap into it? Might be the easiest, and cheapest way to get around it...
I'm gettin some moola set aside for you Austin. Should be sending you another big lump here in the next couple weeks;)
TD04 or VF7?
The stock boost on my TD04 is 7 psi BUT you have to remember, the TD04 flows more air then a VF7. So the boost will be the same, but more air will be forced into the engine with the TD04. The stock fuel system can handle it but at higher RPMs, it'll start to run a bit lean. Next thing you have to think about. The VF7 is a direct bolt on since its the stock turbo for that car. TD04 requires a lot of time to get it to bolt onto the car, then plumbing, intercooler, etc. I have pics of a TD04 and intercooler install on my '89 RX, which will have the same engine as yours. http://rides.webshots.com/album/302403464nPmSgF Just scroll through the pics and you'll come across them. I have pics of the stoc, nonspider intake with a mockup plumbing, then the actual plumbing I have, with has a spider intake on it now.
I can see about bringing some stuff down too Keith. Now I just need to get motivated and do some swappage on the RX so it runs better then it does now... Maybe by the end of the winter, we an have another meet and I can possibly bring my Brat, which should be fresh from getting a restoration:banana:
81 Brat needs new engine......any ideas?
basically you can make any Subaru engine fit into that Brat. My advise, for easiest installation and drop in, you might want to get another EA81. Since yours has whats known as the top mounted starter (starter on top of the bellhousing), you'll need to swap the bellhousing from your original engine to anotherEA81 you put into it. You can use a side mounted EA81 (starter mounted on the driver side of the bellhousing) and it will directly bolt into the car. You can then put a Weber carburator onto it, a better flowing exhaust, hotter ignition setup, plus lots of other little mods to help increase the power output of the engine.
