Everything posted by Caboobaroo
Boycott Shucks/CSK AUTO
I won't shop at Checker's unless I absolutly have to which is slim to none. Went in there to get a turn signal cancellation cam for my buddy's '78 Bronco and they gave me one and I asked them if it would work. Of course they said yes, I get home to put it in and guess what? Didn't fit... Now the guys down at Advance know me so well, I get discounts even though I'm not a tech student:D
the megasquirted and edis'd rx !
heh, that motor looks a little familiar... last time I saw it, it was in a turbowagon with a 4EAT behind it IIRC. Dude wanna build me some MS&EDIS goodies for my fantasticly big and expensive pile of crap in my driveway? I have a donor car for the parts needed for the EDIS but I'm so incredibly computer stupid its not even funny...
blasphemy? lowriding a suby? anyone?
Granted my loweriding Suby is a gen 1 but here's a pic of it still...
good place/brands for new dizzy cap/wires
Ebay my friend. I purchased a set of NGK plugwires for 15 bucks shipped for my '89 RX.
what do you think need one of these for a hot date *edit*
No a 500+ hp EA82T. Hopefully I can get one up there in numbers before too long:D
changing RX from 3.7 to 3.9 -got questions-
all righty I guess I can step up here and put my $.02 cents in... 1. The RX hubs are the same as the GL hubs. The only difference in the front axles is yes the RX DOJs are a 25 spline whereas the nonturbo GL axles are a 23 spline 2. The crossmember is the same... 3. Drivelines are the same between them. I currently have a GL wagon driveline in my RX from doing the auto to manual swap. 4. The turbo clutch kit will fit, no worries. 5. Sorry Donny, I gotta work man or I'd come and help ya out:)
3at 4wd T-coupe To 4 Or 5 Spd?
well Bill, a custom driveshaft would have to be made for the EA82 5-speed tranny whereas just an EA81 manual tranny driveshaft would work. Axles would be the same from an EA81 manual and EA81 auto but the EA82 turbo trannys have the bigger splines on the DOJ side. There's a good set of axles in the parts car and tranny ('85 GL-10 turbosedan) and the gearing is the same as the turbocoupe so no changing the rear ends out. I would recommend an EA82 clutch setup for it since it'll be able to hold the power a little more then the EA81 clutch.
Free 86 wagon: northern Co.
I got a friend up here without a car and he's interested in this one. Lemme know if its still up for grabs...
need more info... deck height, piston stuff
Jon... what are you planning......?
EA82 headers?
the TD04 does fit onto a stock EA82 uppipe but the rear stud the bolts the turbo to the uppipe needs to be removed and welded to the header since it sits about 1/2" further back then the IHI RBx turbos. Also the stud will have to be shortened so the WRX downpipe will fit once the turbo is bolted down.
non turbo spyder intakes vs. turbo spyder intakes?
The spyder intake came on only XT's, no other Subaru had them. They were on the 4 cylinder turbo and non turbo XT's from 87.5-89 I believe. They flow a lot better then the average EA82T intake which is why they're very sought after. They look like the newer EJ series intakes...
Utter N00b... questions about the differences rx gl-10 and tranny
I've used a PT4wd tranny on a few launches in a friend's '87 turbowagon. Tranny is a part time 4wd d/r from an '85 RX.
could you get some pics of the turbo and non turbo intakes to show where it would be located? That would help me out greatly!
Rolling Fog Bank
Mary, you might want to check the PCV on it to see if its going bad. Pull it out (its on the top of the intake on the driver side) and rattle it around. If you hear a metal ticking sound as you rattle it, its still good but if there is no sound, try cleaning it with some carb cleaner to clean the gunk out of it. Best thing to do is to replace it with a new one since they're not too expensive, maybe 10 bucks at most...
question about engine overhauling
but may I remind you guys that an EA82 carbed intake needs to be modified to work around the disty on an EA81 since its right in the way of the thermostat housing. I would swap over to an EA81 Hitachi 2 barrel intake and do a nice port on it.
so what do I do for the coolant return for the turbo then? Is there a spot that I can drill and tap out for a bung or something?
I just found out that a parts car out at the "ole stash" just happens to be a 2wd auto XT, year unknown, BUT it has a spyder intake on it. So what are the differences between the turbo and non turbo spyders? I'm going to put this intake on my RX if its not too much hassle so then it'll be easier to finish up the plumbing for my intercooler and whatnot:) If there are things that have to be done to it to make it work, what are they? I also am getting the throttle cable as well
RX update with pictures
hey Miles, sounds good to me! Just gotta get her runnin before too long I hope...
Hopin for the end of summer so I can get a bunch of board members together from Wyoming and Colorado for a nice cruise-in or whatnot:D
You must feel pretty special don't ya;) Mine will be running very shortly but I'm awaiting the gaskets for the turbo and the plumbing to it as well... just a few little things before she'll run but I did get her to turn over:banana:
Right out of the hood on the driver's side. Just gotta make a hole for it;) I love the dew man! Its holding it because I'm making a strut tower brace with IC holder in it currently. Yes that is a stock OEM intake pipe (thanks for the idea WJM) but its from an '85 GL-10 sedan cause mine cracked really badly when I stretched it...
Well lemme tell ya, its been quite a task getting it all to come together. I'm still getting it all hooked back up like the oil/cooling lines on the turbo and the piping that goes from the turbo to the IC. I also have to cut a hole for my BOV to fit but I'm gonna make it be hidden a bit so it'll blow off out of the hood;)
Well I finally got the digital camera to work again and since it was a nice day out, came a photo shoot of the RX. After a nice bath, she sure looks better then ever, well at least since I've had her. Here's the site where the pics are located on the last couple pages http://community.webshots.com/album/302403464nPmSgF/0 Anyways, here's a list of the things that I have done it her since I got her back in November: - resealed EA82T from an '85 RX - gen 2 turbo heads - modified stock uppipe - '02 WRX TD04 turbo - '02 WRX top mount intercooler - '02 WRX downpipe with less then 500 miles - Turbo XS BOV - AEM and custom cold air intake - full 5-lug conversion with XT6 front and rear swaybars and Impreza front brakes/struts/hubs/axles - GReddy Profec B-Spec II EBC - GReddy Auto Turbo Timer - full stock RX bodykit - 4EAT to FT4WD D/R 5-speed conversion - stage 2 clutch kit with new OEM clutch cable - WRX 3-gauge A-pillar pod - custom painted tailights - aftermarket steering wheel and shift knobs And here's a list of things that are in the works or in progress: - coilovers - Autometer Phantom EGT, Boost, A/F, oil pressure, water temp, and tach with shift light - full aftermarket TBE including a Crucial Racing downpipe with divorced wastegate - TWE header - full 10 point rollcage with harness bar - 3-point strut tower brace with intercooler mounts - custom short throw shifter - 17" rims - bodywork with new black paintjob (minus the gold stripe) - new lexan quarter windows - plus a few other misc. items that have to be addressed Let me know what everyone thinks about it. I currently have about $2800 into her and that includes buying the car. So for those of you who are kinda lazy and don't want to poke around at the pics on my site, here's what I've gone from back in November of 2004: And this is what it looks like today (7/8/05) grr click the red X's...
BRAT Entertainment
Hey now watch it buddy. There's a few Chevy lovers on this forum as well... Just because I have two '88 Camaros doesn't mean I should be "rockin my mullet". If I remember correctly, Joe Dirt was drivin a Dodge Daytona Superbird...
Flywheel? XT6 or lighten mine?
This is very true. This is why I got a full stage 2 clutch kit, not just the disc..
