Everything posted by nncoolg
EA82T head issues
I am interested in the head bolts, do you have any more info about them?
EA82 head porting?
nice man, now do you have the photos of yours?
EA82 head porting?
bump
Splitting HEAD'ache - 56K beware.
does anyone have copies of these photos, as they are not showing up?
EA82 head porting?
Yeah, that'd be good, but I really want to see the above mentioned cut heads, and combine that information with mine....
EA82 head porting?
sweet, would you mind having a look, and putting them up here? Im sure they would prove useful, maybe someone could sticky them? - you can sticky mine too if you like.
EA82 head porting?
I just found thread that sounds very interesting, does anyone happen to have a copy of the pictures? http://subaruxt.com/forum/viewtopic.php?f=1&t=7121&p=66398&hilit=+xt6+porting#p66398
EA82 head porting?
reserved for my result pics...
EA82 head porting?
After disecting the spare set of heads ( link ), I am about to embark on the porting adventure, just wondering if anyone would like to share their handiwork... Here is a link (the only one I could find) I found... Would probably be quite nice on a set that weren't cracked, certainly some good gains to be had in the exhaust 'bowl'
XT coupe - Where abouts is the outside Air Temp sensor?
Gday guys, just wondering in a US spec 1987-on XT, where abouts is the Temp sensor for the Digital Dash? I beleive it is somewhere in the inner guard, but as to which side, I have no idea? A photograph would be much much helpful Thanks in advance!
Euro ? Spec EA82 cams .
...does anyone know what profile the A-1-2 cams are? thanks.
Why do the EA82 heads suffer from bridge cracks?
But wont the bridge cracks extend to port cracks? I mean, isn't that how they start? It's gotta be a heat issue, pehaps fitting an oil cooler would help, by cooling the head where the water doesn't get? Im puzzled as to why the triangle shaped water jacket at the top of the block, in between the bores is blocked off, I think I will drill a hole in the heads there and wad-punch a hole in the gasket, to promote a bit of extra coolant flow. Thoughts?
How to identify the different EA82 Cams...
I have heard that the cams in 4 plug N/A EA82 MPFI's had a longer duration and thus better than the 4 plug Turbo cams, does anyone have any documentation of that, and is there anyway to identify the cams when looked at. I got a set of NA cams yesterday, and they have different numbers to my Turbo cams, but my 2 sets of turbo cams are marked different as well.... Thanks.
Just wondering if someone has some background experience with the EA82 2 port heads, and knows why they all seem to crack between the valves? Are they ALL overheated? Or do they suffer from the valve seats being too tight in the casting or something? I know there is not much meat between the 2 runners, but surely FHI engineers made them good enough.... Also, is it better to buy brand new (including 2nd hand good ones, if they can be found), or repaired, like, once the heads have cracked & relaxed, then repaired are they better? Thanks.
A Few Questions About the XT coupe Digital Dash....
Please Forgice me for all these queries, I need to know.... here's a scan from the XT Gen2 Manual: (1) It mentions a KPH/MPH button, and I have heard of a jumper that define the dash between the two, but what changes the Odometer, I assume they are mechanical? (2) Is there model (transmission) specific dash's, or are different indicators in there, just blanked off? (3) It says the turbo gauge varies with boost pressure, so do they use a different pressure sensor to the on/off light dashs? (4) Does any body have one that will operate with a 4EAT AWD Turbo?
5 lug facts..a picture book (56k..go play)
can you get the pics back?
Spider EA82T idling fast
Hi guys, having a little trouble with the XT... Doesnt fast idle when its cold, fast idles (1300) when its hot(normal temp) Also, uses WAY TOO MUCH FUEL for an EA82T (22MPG on trip) Already checked for vacuum leaks So... I reckon it could be 1 of 2 things : IAC valve (not the black shutter one on the RX type EA82's) Coolant temp sensor What do you's reckon...had similar dramas? any help greatly appreciated
