Olnick
10
Everything posted by Olnick
You also might want to remove and clean your idle air control valve--they get pretty gunked up and sticky. Recently did the Seafoam thing, cleaned the MAF sensor, throttle body and IACV and replaced the engine coolant temperature sensor (it was giving me a CEL) and my hesitation went away. That was on my '95 2.2L.
Mike! Mike! Calm down--it's not all that difficult! You might want to treat the threaded end with penetrating oil for a day or two first. Then drive the car a bit to get the cat and sensor hot before you attempt to unscrew it--really helps. Crack the sensor loose with the wrench before you unplug the electrical connector, then unplug connector and sensor should unscrew with just fingers. I found it easiest to work from top of engine bay leaning over passenger side fender. Good luck!
Oil Light???
Olnick replied to Stu Baker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Agree with ShawnW--you'd be wise to change the timing belt, replace the crank and cam seals and reseal the oil pump (tighten the backplate screws, new o-ring and sealant). Might want to replace the waterpump while you're in there too, a good preventative measure. Search the board--there's a lot of good info here. -
The "click-click-clicking" you're hearing could be the copper contacts in the starter. They pit and wear away over the years and eventually won't make enough contact to feed electricity to the starter motor. They can be replaced--new contacts are realtively inexpensive--but you have to remove the starter to get to them. It's not as difficult as it sounds! There have been write-ups about it here on the board. A search should turn up a lot of information. And if you need help, just ask! Good luck.
When my power steering started growling and the steering wheel began "stuttering" a bit, I didn't know that rebuild kits were available. Ordered a brand new pump, about $130 IIRC from 1stsubaruparts, and it went in quite easily--it's certainly in an easy to reach position! Immediately cleared up the problems.
Guys--not to be a "told-you-so," but I posted the location of that relay a week ago (post #22)! The 3-in-a-row relays are not in the fuse BOX, but are on the same PANEL, at the top. Reason01, if you got the middle relay out can you now swap one of the other relays into that position? If the lights work then you'll know that it was, in fact, a bad relay.
I agree with cookie's take on it. The price is good and the car sounds very attractive. But you would still have to burn premium fuel and there's always that slightly higher risk of expensive problems. If you are still interested in a Subaru and a car's "maturity" doesn't bother you, I'd still suggest a Legacy model, 1990 through '96. (After 1996 they redesigned the good old bulletproof 2.2L and it became an "interference" engine!)
Autumn--welcome to the board. You have a beautiful name! In my opinion, and based on your desire to help your daughter with dependable transportation, I'd shy away from the car. It was the first year of the 2.5L engine and does require higher octane gas (higher compression ratio I believe.) And if and when the timing belt goes, you are in "deep kim chee." It's an "interference" type engine and, as it has already done, will cause very expensive damage to the top end when the pistons and valves collide. 'Course that may never happen again, you never know. But by-and-large Subarus are beautifully designed and well put together vehicles. I've driven them for over 20 years and love 'em. Would suggest a better buy for you would be a Legacy model, any year up through 1996. They have what is often called a "bulletproof" 2.2L engine. With normal care they seem to run forever. And if a timing belt breaks, generally no massive damage (they are a "non-interference" engine.) I'm sure the '96 Outback is a lovely vehicle but--again just my opinion--I'd let it go and look for a decent Legacy. My own daughter picked up a '92 Legacy sedan a year ago and I swear it runs better than my '95 wagon! Hope this helps. Any other questions, just ask. The people on this board are a fantastic resource.
I drive a 2.2L--'95 Legacy L wagon AWD with 5-spd manual, 106k miles. Averaged 21.7 mpg over the last 8 months in nearly 100% stop-and-go city driving. Maybe that's the best I can expect. AWD will never make for super economy. Then I fondly think back on my '85 GL--2WD, sweet little 1.8L, 25 to 27 mpg in virtually the same driving conditions!
Okay, curiosity got the better of me, so I grabbed a flashlight when I got home and crawled under the dash. When you remove the cover of the interior fuse "box" the board, or backing plate, that the fuses plug into extends higher up--in the direction of the left corner of the windshield (looking from the driver's position.) It's ivory colored plastic in my '95 Legacy. At the very top of that board is a row of 3 black relays. If Haynes is right, the middle one should be the "Tail Illumination Relay." Could see what looked like a latching mechanism at the base of the relay but couldn't get my fingers in there to release it. Hope this helps and . . . good luck!
