vincentmoy
Everything posted by vincentmoy
Hi all, I have a 1998 Imp OBS EJ22. I need to change the starter but not so sure how. Do I need to remove the cleaner box thing to get access to it? Is there any torque spec for the bolt and nuts or just as tight as I can get. I know it's also a dump question but I can't seems to be able to get the air filter upper housing off. It is 2 clips on the side but when I try to remove it something seems to can't come loose @ the bottom. I hope I don't have to remove the MAF just to check the air filter... Anyways, Thanks for any help! Vincent
Just give you some references. I got all my pulleys (2 smooth, 1 teeth), TB, Hyd Tensioner, 2 Cam seals, water pump w/ gasket, Thermostat w/ gasket and PCV valve. All OEM. The total for parts only is a whooping $500. I looked @ some ebay kits and there is a master kit from theimportexpert. It's for 90 - 96. I called them up and they quoted me about $300 for my 98 Imp OBS. Not a bad deal at all. I would throw a OEM timing belt as I HEARD that they have been marking. Your 98 2.2 should be an interference eng so make sure you do it right. If not it could be a few thousand dollars fix:rolleyes:
I'm up Alaska and don't have autozone, all I have is schuck's and napa. I think getting one online is a better choose for me. I saw one "new" @ importexperts for like $92. It seems low to me. http://catalog.worldpac.com/triangle/wizard.jsp?partner=triangle&clientid=theimportexperts&baseurl=http://www.theimportexperts.com/&cookieid=2LB0R23XA2LB0W2ZG6&year=1998&make=SU&model=OUTS-4WD-001&category=F&part=Starter&appTransmissionType=Manual
No a problem. The noise only comes when I start the engine cold. If I start the engine warm, say turn it off for 5 mins and turn it back on, the noise is gone or almost gone. There is no weird noises when I depress/release clutch so I think I can rule clutch/flywheel out for now. Moreover, that noise doesn't seem to affect the drivablity, and seems like the previous owner drove it that way for a while.
When I start the car cold, there is a low pitch squeaking noise coming from the engine. I have changed all the pulleys for the timing so it can be ruled out. Checked for all the v-belt they all looks good. My friend said it sounds like it's from the starter. He said it sounds like the starter is not disengaging after it started. Any ideas? Vincent
