Everything posted by etc
Help - dropped a tool into TC bung hole (Legacy 2.2)
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI tried a telescopic magnet to no avail, because it doesn't flex. I need a good flex telescoping magnet so it can bend going in.
how bad is the ej25?
etc replied to wfothrottle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnecdotal data: A family member had a 2001 OBW, 2.5L - wrecked it at something like 150K miles, no HG issues or other issues. Now 2000 OBW, 2.5L, 198K miles, no HG issues.
I was trying to remove the crankshaft bolt. I accessed the bung hole, tried to hold the TC with a 3/8" extension but it was too short and dropped right into it. Now I am having a hard time turning the bolt, at times it goes easy but in one spot it kind of gets stuck. Do I have to remove the transmission now or what?
98 Legacy: How to replace the leaking crankshaft seal
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a problem, I droped a short 3/8" extension into the bung hole. It didn't go into one of the holes in the TC but in the large space adjecent to it. Now when I try to turn the crank bolt, it rotates smoothly most of the way except in one point where it encounters resistance... Is this a problem and how do I get this piece out of there? Where exactly is it?
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, I marked it --- and finally now I saw it move. Now what? I think this answers my question:
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSee, that's the problem. When I rotate the crank bolt, while looking in that hole, I don't see anything moving at all. Confused :-\
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow do I access it from below?
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, I certainly did not remove anything.
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, I found the plate but when I turn the crankshaft bolt with the breaker bar, nothing is rotating inside.
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCannot find the drive plate even after taking the air box. Where is it?
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI will do that... Just need to find it first. I am ready to unbolt it otherwise:
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am in MD. Link for the tool? I cannot proceed further.
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow do I hold the crank pulley when removing the bolt? I have a breaker bar and a 22mm socket but it's moving and I cannot get the bolt off.
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX> You can get a pulley holder, Where do I get this part? I had some repair shop look at it and was told that camshaft seals are bad and the valve cover gaskets are leaking. I question that, as they didn't mention the massive power steering leak. That is leaking for sure but I am not sure if it's getting to the exhaust or if it's something else. I will shoot pics from the bottom. There is a lot of oil there but where it's coming from, I am not sure. I do know that when the vehicle is sitting, I get next to no leaks. When it's driving apparetly there is a massive leak. So that to me suggests either power steering or camshaft? I need expert advise. I will post more detailed pics shortly. Now I need a plan to deal with the leaky power steering pump. Do I just get a rebuild kit or do I replace the whole thing? I don't fully understand. I want to take care of all the issues while I got the thing apart. The 98 2.2L has 149,000 miles on it so I want to replace the timing belts anyway. Might as well do the WP. The radiator went bad so that is getting replaced.
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow do I get the crank pulley off and where is it? Yes, the power steering is leaking, should I replace it while I am at it? Is it cost-effective, is it difficult, how much do these pumps cost?
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI took out the radiator and fans and the alternator and WP belt. What's next? Should I remove the timing belt covers right now or is there something else to remove before I do that?
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLink?
Site for OEM Subaru parts
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks, I got some parts from Jason. All needed for my cam seal oil leak as well as the radiator. He did suggest a few things I did not think of.
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI plan to do it, I have access to a rack so it should be pretty simple, doing it from below. I need to tear this apart and see exactly what's leaking. Exactly which pin wrench do you recommend?
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRE: tools I don't think I need to replace the crankshaft seal? I need to take a look, as far as I understand, the cam seal leak is much more common on 2.2L? Anyway, what can I use to improvise these tools?
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI printed some timing belt replacement manuals so they should help. Question, where is the cam seal located, in relationship to the timing belts? I understand it's right in that vicinity? So that in doing timing belts, I could replace everything in one shot. Another question, should I replace the Timing Belt tensioner as well? The 2.2L / vehicle has 147K miles on it.
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTheir site appears to be: http://www.mikescarffsubaru.com/specials/parts.htm
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThank you....
98 Legacy: Cooling system problems
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks. I am doing T-belts, WP and other things, and plan to address the cooling system right at that time.
etc replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo what tool do you use and where to get it?
