Everything posted by 1-3-2-4
How do you open up the brake calipers?
1-3-2-4 replied to nickolai's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah I just noticed that but then I just noticed they make replacement bolt I don't need the sliding one.
1-3-2-4 replied to nickolai's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot really unless you are looking to replace brake fluid but pressing the caliper piston back in will require you to take the brake fluid cap off and if you topped it off you will need to take some out as pressing the piston back in will cause the fluid level to rise. Remember brake fluid will take off paint. Speaking of calipers.. does anyone make replacement screws for the caliper.. you know the part that keeps the whole caliper from flipping upwards? I have a feeling if I can't find it I'm going to need to just buy a whole new caliper. Ok forget that seems like they do make replacement bolts! every bump I can hear my bracket.. Not clue how the bolt fell out at all..
ABS on
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't feel so bad they had some issues trying to locate it as well.
ABS on
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was driving in about 7 inches of snow in a parking lot but when I noticed the light was on when I went to run out I was parked on ice but it was not smooth ice but like bumpy. I can't really check because we are getting snow yet again I just hate yellow warning lights on my dash. But do I really have the plugs under my dash to check?
PCV Disaster!!!
1-3-2-4 replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMine snapped like 4 weeks ago I have yet to replace it yet.. I have not checked out the whole thread yet but do they have to order this part? I doubt it will effect gas mileage? because right now I got some pretty crappy mileage..
ABS on
For awhile when it was cold out my ABS light would sometime come on but upon the next starting of the car or turning the car off while driving then back on (5 MT) the ABS light would go off.. For this past Sunday the light is on solid now and start cycles have no effect.. NOW for the 1995 Legacy how do I pull the code for the ABS? Because I looked at the later model years about some plug under the dash with two tapped wires and my car does not have that at all.. I'd like to find out what this code is I've never seen a car that would bring up the ABS light on the dash but would clear it's self if you just restart the car.. Loose wire maybe?
cinch points to pull the 2.5L engine
1-3-2-4 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdamn everyone has that bracket but me.. all the other subaurs I had had it but I'm thinking the last person who owned the car removed it when they changed the alternator thinking it' was a wasted piece of metal?
Is it the fuel pump?
1-3-2-4 replied to akjruthies's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhey I found out where that massive amount of water came in from.. the A/C evaporator line I'm not sure if it had a rubber seal around it or not (I can't remember) but that's where it all came in at. part 2
1-3-2-4 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat happens if your car does not have that bracket by the Alternator?
1-3-2-4 replied to akjruthies's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat happen is it works fine it's a tad louder then the stock pump which means I can hear it a little.. I got on the highway and did some WOT pulls and no starving for fuel. also the fuel strainer on the new one is not as curved as the other so when I went to place it in the tank I had to do a little moving... interesting to see how little change you have from a half a tank to a full tank Also when trying to release fuel pressure I think I had the car as low as an idle.. nipper might of remembered when we went off road that day and I got stuck on the trail with the wet ECU it was idling a little under the 2nd hash mark which I think is 500 rpm? I'm going to be uploading the video in a few here.
1-3-2-4 replied to akjruthies's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhaha I guess you're right.. I just ran into a snag.. for some reason the positive post on the new pump is smaller and fits the stock screw nut but the Neg post is larger and wont fit the negative cable. I don't think I have a wire nut for that here in my spare parts bin but I went out and advance auto had a M5 nut that fit just right. So the pump is in now
Car wont run
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXugh went to get the package this morning and I almost thought they lost that.. i don't get why they never left it because it was no need to sign for..\ Anyways I'm going to let the pressure bleed off (it's snowing here) and eat some food and do the job and bring my camcorder
05 OB "Zero Front Brakes" Wouldn't They Squeak?
1-3-2-4 replied to Juan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is worn.. tore the rotor up pretty good.. replaced all rotors and changed to ceramic pads and I love it! no more pad deposits left on the rotor and getting that shaking feel when braking.
Swapping in '93 EJ22 OBDI into '95 Legacy OBDII
1-3-2-4 replied to jboymechanic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA 95 legacy auto had a EGR the manual version did not.
I just joined the 200K club again
1-3-2-4 replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtiming belt guard? You mean the cover? all mine snapped the plastic on mine so my passenger side cover is missing and so on. but wow not bad.. I picked up mine at 195,065 and I now have 235K on it almost 3 years later I've really only done minor stuff to it like water pump new radiator and timing belt and new struts.
Hmm interesting but I still don't want another auto
is your car a 2.5?
Car wont run
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwow these idiots say they tried to delivery at 2:08 pm but no one was home.. I've been home since 8 AM this morning and no one ever knocked.. I don't give a damn if it says come tomorrow but I'm going over tonight before they close to see if I can try and get my two packages that seemed to be someone who has no brain to try KNOCKING and not just throwing out pink slips.. how in the hell does the post office keep running?!?!? and the best thing of all my pink slip was for my other package and not the express one. :Flame:zzz
I already got UEL headers and mine is a dual port. at 100 MPH I think my car is around 4300.. the manual is geared higher then the auto I know that. plus I've got two speeding tickets (under 100) and don't need anymore.. I was happy enough my car ins went down when I turned 26
Car wont run
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's impossible to knock the strainer off the stock one has one of those clips with the fingers on them (I forget the name) it reminds me of a pressure plate of a clutch. Anyways looks like the bosh one is held in by a nut.. I dunno I'm still waiting here.
1-3-2-4 replied to akjruthies's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wonder why most of the replacement pumps have a threaded screw mount for the connection when the stock had a thru hole mount with a square nut. I'd have to bend my wires upwards so I can at least slide the protective cover over the + wire.
Car wont run
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust waiting for the mail today i guess I will film the whole thing and put it on youtube.. it's easy as pie.. and sweet my replacement gas oven ignitor is coming as well so no more 10 min to heat the oven up!
winterforce tires
1-3-2-4 replied to goof_ball's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think it must be because of that exhaust leak really between the first cat and the center pipe it's gotten a bit larger.. I plan on taking care of that next week.
lol the car is out of breath at that speed I have yet to hit 110 in my car but I've hit 105.
solution for leaking PS pumps
1-3-2-4 replied to afterbang's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf I don't hear any sounds from it then it's safe I can just replace the gasket seal? none of this stuff I will do until it warms up however.
