Everything posted by 1-3-2-4
Strut mounts?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell at least we are on the same page now.. From what I understand the strut mounts should have some type of dot or whatever for proper placement?
keyless entry
1-3-2-4 replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm how much is the keyless entryI never knew which fit my model.. I have a 95 as well with power door locks.. so anything in the 95-99 range works?
howling
1-3-2-4 replied to jrt2nd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's pretty dangerous..
Question....? 90 loyale 4wd...
My car is at 232K and it still shifts great only thing I need to do is replace the shifter knuckle because the bushing is shot. I never liked the paddle shifters on any car
Parking pall
1-3-2-4 replied to jrt2nd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI stand corrected then
the car had no oil slicks my 95 impreza had transmission problems.. I lost reverse I'm more then happen with my MT now
it failed because the front diff ran dry because it leaked.. it was a 2003 Forester XS that I miss big time. besides that I don't want another AT after all that
Need Some Help? Drive shaft problem?
the nail sized thing you are talking about sounds like the roll pin? Nevertheless it should be flush on both sides of the CV it should not be missing or pushed out.
I had a 4EAT that I broke the front diff on and the car would not move at all.
Parking pall
1-3-2-4 replied to jrt2nd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought it's called parking paw and not pall
Rear wiper spray
1-3-2-4 replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhmm well try what nipper said.. the longest I've had to wait when i first got the car was about 10 secs to purge the line of air.
Strut mounts?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm talking about the bump stops.. look on page 2 it's so the strut wont bottom out. I had planned to order 4 new today from rockauto but something came up.
My '95 Legacy: Trashwagon10
I have to watch out coming out of driveways where they have a dip because most of the time the bumper hits or the front tow hooks.. that used to happen a lot when I had my 95 impreza.. went to town hall and forgot kept rolling forward and BANG! lol everyone looked. I'm hoping my wheel shimmy is because of the strut or bad tie. I wont get my tires mounted until next week or week after next, I sure as hell don't want to do it now with my toe out of adjustment.. I have to have my wheel like 30 degrees to the left to go straight haha the winter tires would be gone in no time
Engine Coolant Temperature (ECT) Sensor
1-3-2-4 replied to ktdenali's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdefrost can turn the fans on.. having the A/C button pressed will turn the fans on.. report back when you check.. it would be better to hook a live scanner up and see what the ECT is showing a reading of after sitting over 24 Hr.. lol if it's maxed out at over 220 F when it's 32F outside then you have a problem
haha I'm finally replacing my blown struts tomorrow it looks like.. at 232 (almost 233) I think all 4 are gone. I get some serious wheel hop from the left rear corner if powering up a ramp at wot.. I'm hoping downshifts wont feel so jerky in the car now.. almost any bump and the rear end now is like bouncing for like 3 seconds lmao. in the summer I might be looking for forester struts but not for long term
Rear wiper spray
1-3-2-4 replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo you have enough fluid in the tank? I find when it's too low the front will still work (pump longer in tank) but the rear will not. Now since you made this thread I hate this rear washer.. I prefer the spray to be from top to bottom not bottom spraying up.
Strut mounts?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo I'm going to do the struts tomorrow.. because im pressed for time can I just reuse the bump stop until spring?
Door lock timer location 95 legacy
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow did everything go did you ever get to change it out?
'97 Legacy will not start
1-3-2-4 replied to Mikevan10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDont you hate when it gets dark early now
13" Steelies on FWD Imp.
1-3-2-4 replied to kc8apm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe 13's are 5 Lugs I used to have a 95 imrpreza FWD and yes the tire size is hard to find anything on it... That's one subaru I don't really miss at all..
Sorry if this is old news...but....
1-3-2-4 replied to rxleone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's called FB25 now? I'm going to have Ej25 stuck in my head forever
1-3-2-4 replied to rxleone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhy would it be buggy? They do a lot of engine testing (hours) before they just stick it in the car.
Trouble Resetting Computer
1-3-2-4 replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm friken lost.. are you saying it ran better with the Green and black connections under the dash disconnected? If so those are not meant to be plugged in they are for reading codes.
Idle Up Sequence?
1-3-2-4 replied to Crawlerdan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure what style IAC you have but I did half a can of sea foam on mine which never worked and had any change.. so I picked up a can of carb cleaner and used the whole can on the IAC making sure the inside, back shutter area and the inside hose were all clean and that fixed my idle issue but mine was only when the car was warm and it was not really an idle issue.
1-3-2-4 replied to rxleone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow did not know they were out now
