Everything posted by 1-3-2-4
maybe for an auto but after I blocked the wheels I had the crank bolt off in less then 2 min. dare I say it, I thought it was pretty fun doing the timing belt.. I got confused with the arrows myself and all but once I did that and knew which to look for I was done in like an hour. Going to do it all again this spring because i did not do the cam seals which area leaking but I have them ready and I have an impact for the cams. Turning the cams over by hand via the sprocket only is a good workout!
I never knew they had a older for it.. Also someone should add some feature here to let other members know what year you have typing it over and over is a pain (not directed at you) I will try the sears site just that the nearest one is like 40 min away. The sensor I will be getting is a Denso. Oh and my car has 2 '95 legacy wagon
So i'm looking around here I'm not sure a oxygen sensor would last 236K but nevertheless I have to think that way.. I did not know it was possible to snap them off? I need to get some more penetrating oil but I wonder how much work it will involve. Also it may not be stock because the wire to the sensor seems to be a bit too long.. it was long enough to rub on the inner cv axle and I caught it just as it was wearing away the outer shield cover. For the tube wrench I was thinking a pipe wrench but that does not seem to be it at least looking on google image search.
Nice what are you using to mix colours?
I had to sand the green off the back too much to type on a phone but worrh the effort Using white leds
Confused myself... Dont remove them.. I changed the color of mine so I had to move them.. Fuel is stepper motor rest is not
So home now and about 3 weeks ago I cleaned the battery terminals and the posts for the cables that picture btw is old back during the fall I did not take one this morning since I was in a little rush but I did check the output and again it was showing fine.. I sat in traffic and turned on my loads again and it was fine :-/ And the main power panel are you talking the box with the fuses in them? I wish this damn snow would all melt so I can start doing work. It can't be the ignition switch since turning things on like the headlights and hi beams and blower on all causes odd idle issues and a drop of almost 500 rpms.
wow I just had the issue again but this time that wire was wrapped from the alt output.. I noticed when driving to a friends house one of my headlights (HIDS) went out.. and I thought ok.. I did not bump the switch.. So I dont think much of it.. So as I drive home and pull in my head lights turn off and my head unit (Alpine) restarts as if you are just starting the car up.. And i'm like what the hell? So I pull in my space and I turn my blower speed to 4 and sure enough my idle dips, radio restarts and my headlights go off for a split second... I check under the hood and the wire is still wrapped.. So I turn the car off and then restart it and try again with everything on and it does not do it anymore... At this point I'm about to call it a day and just replace the damn alt.. I mean it was a reman anyways when I got the car but it's something I need... I don't think the weather would have an issue on this?
heh it's late night I should of noticed but I missed a few hours of sleep lol I have a question for the gasket for the center pipe to the muffler do they use some sealant on that? When I did change the exhaust from the stock to one from a 2.5 GT I again had a slight fitment issue I had a tiny gap with the gasket (subaru gasket) but I noticed when I took the old one off it had this like orange looking sealant.
