mike golin
Everything posted by mike golin
put the lube gard in the trans only. before you do that , check to see if the yellow power light on the dash goes off when you start the car ,or if it flashes a bunch of times . that is the computer check light for the trans. [like the check engine light for the engine ]. i have replaced a few duty solenoids for the 4wd clutch lately . they fail and the clutch goes to full pressure which chatters like a 4wd truck on dry pavement.
you would be surprised how long a timing belt will last when a water pump locks up! it will slide over that pump untill it melts the belt . make sure the crank sprocket is on the 12 o clock mark [ which puts the pistons at the halfway point of the stroke] , turn the cams to the closed position [ cam turns freely by hand ], then use a cylinder leak tester to pressurize the cylinders to check the valves . I have had a couple of 2.2 L engines break timing belts and not hit any valves. make sure you use a subaru thermostat when you put it back together . have had way too many aftermarket stats fail . the older 1.8 and 2.2 engines didnt have much head gasket trouble [ unlike the 2.5 ] . the 93 didnt have obd-2 which wouldnt have the misfire detection . the crank sensor handles the timing side and the cam sensor handles the injector firing sequence. either one failing will cause a no start.
I would turn the cams to the closed position [ cam can be turned freely - both cams on same side ] and use a cylinder leak tester [or regulated shop air around 100 psi ] and check for leakage into intake or exhaust . it is not easy on a 2.5 DOHC but is the best way to check for bent valves. the water pump is turned by the back side of the timing belt . if the pump seizes it will burn the belt off . with only 130,000 on it ,should be good for a few more years. even if it needs a motor you are looking at around $1500.00 to keep it going .
the oem subie timing belt has white stripes and a dotted stripe which line up with the crank and cam marks. this just makes it quicker . i put white marks on the crank sprocket and the cams [crank sprocket has a mark that lines up with a indent on the crankshaft sensor boss - straight up position. the crank keyway should be at the bottom ]. i use spring clamps to hold the belt on the sprockets which makes it go much easier . the crankshaft bolt is 7/8 inch. make sure you put some blue locktite on the crank bolt and torque it to 130 ft/lbs. On a man trans I have a hook bar that catches the ring gear teeth to hold it . go through the access hole in the bell housing.
the fuse is only for a/t units. the wiring harness is universal . the man trans has a viscous clutch that works by heat when it senses slippage between the front and rear differentials [ when the front spins faster than the rear it creates heat in the clutch which makes it apply ]. the fuse does nothing on a man trans.
12 inch lift pics, daylight pics of the new paintjob *Updated pics*
mike golin replied to subarubrat's topic in Off Road
that is by farr the meanist looking brat on earth! wish subie still made them [ with the STI powertrain - of course ]. -
I would recommend replacing them [about $1,000 job] because it is at the milage that they usually let go. could be a bargaining point if he hasnt bought it yet. subaru is covering gaskets up to 100,000 miles [not sure of time - may be 7 years?] from original date put in service. you would have to check with dealer for specifics to see if it is covered.
