georgeinmd
Everything posted by georgeinmd
My still very strong '99 with 135000 mostly 70+ mph is closing in on the best car I've owned (a mixed bag, to say the least, commencing with a '58 Morris Minor...). Only non-routine items: failed viscous coupling unit and (fortunately) contemperaneous failed trans. output shaft bearing at about 120000 mi., so far cured by a replacement used transaxel, and 4 (!) cracked windshields (any stats. out there?), fortunately replaced by insurance under MD law. Come git me, headgaskets! I defy you, rear wheel bearings!! Ah, hahahahaha... -- George
Just got through with this on my '99 Forester. Its definitely the center diff.; specifically the VCU, based on my experience. All my tires were matched, and it had the same symptoms -- binding only after warmup, not rolling when warm... I replaced the whole transmission with a used one, which worked fine, but of course, you're taking an increased risk of the same thing happening with a used one. $1000 sounds like a fair price for replacement -- my total for a used tranny replacement actually came to a bit more, in the DC area. -- George
The gaurd is there to prevent the belt from loosening and potentially jumping out of time, if the the engine is forced to rotate backwards (e.g., if the car rolls backwards in a forward gear with the engine off). (This will happen only with a manual). I would advise replacing it to be safe. -- George
fwiw -- same thing happened to my friend's '03 Forester at 8000 miles. Here's a transcription of the dealer's technician's service ticket: "CUSTOMER STAETS CAR IS STUCK IN REVERSE; SPOKE TO MRS 11/19 TO LET HER KNOW THE PART CAME IN TODAY AND CAR MAY BE DONE THURSDAY; CAR WOULD NOT COME OUT OF REEVRSE - R/R UNIT; REPLACE 5TH AND REVERSE SYNCHRONISER WAS WORN AND SIEZED UP; REPLACED FORK FOR FIFTH AND REVERSE WAS WORN" (I suspect it was stuck in 5th & reverse since the wheels were locked up regardless of clutch engagement/disengagement). -- George
Hi, classicalbass -- a timely question, fer shur. I just spent many hours and dollars on the same thing ('99 Forester). (Excruciatingly) long story short, I tried to tackle it myself; ended up replacing the whole transaxle with a used one. Anyway, I have all the parts out of the transfer case, and both the mainshaft bearing and the large roller bearing which supports the front of the differential unit have a LITTLE roughness -- but probably enough to cause the symtoms we hear (the VCU was also binding up). I don't have that much experience with this sort of thing, but I'm thinking your hunch is right. I have the appropriate pages out of the online workshop manual and would be glad to share them with you if that would help. They're surprisingly sketchy on "how to" stuff, but the illustrations are good... There's nothing in Haynes. -- George
Impeccable timing -- I just completed this job on my '99 Forester this weekend. There are split boots available that can be installed without dissassembling the suspension and axle; I have no experience with them, but I would be surprised if they last very long -- much better to take time to put OEM quality on. Its not too bad if you have some experience. You need to disconnect the lower control arm from the strut -- one bolt (but mine was rusted pretty badly -- heat and penetrating oil would have helped; push the stub axle out of the hub; probably need a hub puller for that -- mine was pretty rusty -- again, heat and solvent would have helped. Swing the strut and hub aside, knock out a pin that holds the inner joint on the transaxle output shaft and its off. Dissassemble and remove the inner joint and both inner and outer boots can be replaced. The boots I got from Car Quest had very good instructions with them. Again, you probably need some experience to tackle this, but nothing a good shade-tree mechanic can't do. -- George
Wonder if anyone's experienced this: '99 Forester MT 130K miles -- there's a whirring or clicking (depending on speed) coming from the transaxle. Listening with the shift boots removed, it seems to be from the transfer case/center diff./tail shaft housing. Frequency directly proportional to vehicle speed, not dependent on gear selected, but much more noticable on deceleration than acceleration. Gear oil looks fine, and tail shaft has no unusual play or looseness. Been getting louder for about a month. Any ideas??? Thanx -- George
That's my guess, too. I had it happen in my BMW 1600 when the shift linkage broke (destroyed the transmission), and it happened to a friend's brand new 2003 Forester. I've pasted in my last post to ***(another board)*** on the issue. (They told me not to waste their time with arcane problems (hint) which rarely occur. Sigh...) -- George "quick follow up on the locked up xmission, '03 Forester, 8k miles (#1974 & 2011). It was repaired under warrenty and seems to be fine. A transcription of comments on the work order: "CUSTOMER STAETS CAR IS STUCK IN REVERSE; SPOKE TO MRS 11/19 TO LET HER KNOW THE PART CAME IN TODAY AND CAR MAY BE DONE THURSDAY; CAR WOULD NOT COME OUT OF REEVRSE - R/R UNIT; REPLACE 5TH AND REVERSE SYNCHRONISER WAS WORN AND SIEZED UP; REPLACED FORK FOR FIFTH AND REVERSE WAS WORN" -- fwiw -- thanks for all your suggestions. -- George"
Ptrbilt -- The VCU is sealed and cannot be refilled (it contains a special silicone fluid); it must be replaced if it fails. There's an article at http://www.autospeed.com/cms/article.html?&A=0920 that says pre-'99's have a cartridge that can be replaced, rather than the whole unit; you'd probably need to find a dealer service/parts dept. that's willing to share information to find out if that's available. 1stsubaru.com is pretty good. -- George
Kurt -- well, I don't have an answer, but I have the identical car (but with cruise control) and the identical problem -- 42 mph, ten mph range, everything exactly the same. Smacking the top of the dash gets it operating properly for a while. Seems to be worse in damp weather. I, too, would welcome any insights. Thanx -- George
jeremy -- right, mine bolts on. (Subaru actually made something EASIER to fix?!). No, never got a reply on the source of the $250 unit. I've pretty much decided there's nothing else it could be, and, as I said, a local mechanic agrees. I'll post my experiences if and when I tackle the bugger.-- George
