Everything posted by powderhound
Dieing 95 Legacy options.
95 Legacy 5mt 203k. This engine had been overheated around 150k. The headgaskets are now leaking leaving the chocolate mousse like substance on the oil filler cap. I'm trying to determine if I should repair the hgs or do an engine swap or look for another suby. I've read the 2.2s leak slowly for a long time thus ruining the bottom end. And I suspect this one has been for some time. The engine has started idling very rough at very low temps (-15F), when warmed it idles fine but does randomly stumble under more than moderate load. I'm wondering how I go about deciding which route to take in fixing or replacing either the hg's, engine, or whole car. TIA
What's running my battery down?
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah it was 4 yrs old and had been abused (overfilled h2o, drained, etc). Have not heard the sound (yet). Car fires right up. So I probably won't worry about it.
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the ideas. The battery was bad. Props to Oreilly for warrantying a Checker battery.
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo dash lights. And I'm only assuming this noise was what is draining my battery. Perhaps it's just a failing battery as the noise is not always present.
95 lego 5mt 185k. Recently has begun not starting after several days of rest. It will start if started daily. During investigations I have heard a mosquito like buzzing coming from the central engine bay. This is NOT the abs relay that is known to stick. It makes the buzzing sound with no key in ignition and the buzzing stops as soon as you disconnect the positive lead. I've tried lsitening at various things with a srewdriver handle but can't say for sure where it's coming from. Maybe the ignition pack? It sounds like it's dead center and top of the engine. tia.
tire chirp around corners
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell if I was made of money I would. I also wouldn't be living in suby for 3 months now. The filler tube just started leaking. I probably lost my job yesterday. And my little trip to the er put me 4k in debt. Basically the ************ hawks are circling. What should I expect to pay for new struts installed? If its the same price as a mossberg its gonna be a coin flip.
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo I just had it aligned looking at the read out its spot on. Also def not the brakes. Gonna try and see if it does it first thing in the morning I've got a few corners ot chirps every time. If not then I'll vote tb. If it does then I prolly wont worry so much. Road was too wet this morning to get results. Wish me luck I'm going in to interview to keep my job....yeah.
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm almost positive its coming from the tires breaking traction. 5/32 of tread left...maybe I've worn into a different compound? Its so weird it'll do it around one corner and not the next. It seems like the load has to be just right...too much or too little no noise. Can I hope for winter soon so I can just powerslide every corner
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks gg. When I had it aligned yesterday, suspecting that was my culprit, the tech said it was in need of new struts...so maybe. It seems like its more likely happening around uneven corners...will investigate that. If tb would it take 65k to show up from previous owner abuse..I've been religious to keep tires rotated and inflated having previously smoked a vc.
95 lego 5mt 175k. I've owned since 110k. Recently started notcing tire chirp when taking corners at normal speeds. Like a little birdie chirp chirp...chirp. seems intermittent but its just started happening. I've had it happen in left and right tight and sweeping turns. Wheels are petfectly aligned and all tires match within spec. Now heres where I'm confused...if u go to a parking lot and lock the wheel either direction it will idle itself around quietly. Previous 98 with torque bind required gas and hopped around like a 4wd truck when executing the same maneuver. Thoughts? Suggestions? Tia.
ABS wont stop running
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFixed? I pulled the 2nd fuseable link in the black box on top of the abs unit and put it back in and the humming has stopped, abs light off, and abs functioning normally. TSB for sticking abs relays...can I get dealer to fix it for free? guess I would have to wait till it sticks again.
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXItsa? Itsa 95 legacy?
Something associated with the abs wont stop running. I pulled both fuses and it keeps running. Had to disconnect the electrical to it to make it stop. Passenger side front of engine where all the abs stuff is. What's going on here and what do I need to fix. TIA.
wipers stop working
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat was my thought GD. Its a 95 legacy. Any insight as to where I can find a how to? Do I swap out the whole motor or is the transmission separate? car-part.com only lists a motor, no transmission.
wipers stop working
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnope, everything was nice and tight there.
wipers stop working
Turned my wipers on with a bunch of snow on the windshield...got out and assisted them and they started moving. As I was clearing the snow off they stopped moving. I can hear the motor cycle on but they don't move. What have I broken and how can I fix it? tia.
Blower motor removal
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah I ended up bending the bracket out of bit. It bent right back and is secured by the lower cross bracket. I just don't see why everything I read said it drops right out, Mine certainly didn't. Just another my95 "feature"?
IAC needs to be cleaned bad?
powderhound replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen my iac needed cleaning, as in cleaning it fixed my problem, I was getting the code for idle higher than expected. And it was idiling over 1k. To clean the iac I went to the dealership and asked one of the tech how they clean it. He said he just uses throttle body cleaner by spraying it through the iac while the car is running.
95 legacy 5mt Everything I've read about this makes it sound so simple...what's my problem. I got the glove box out. Removed the three screws to remove the blower motor and it drops about halfway down and hits a metal support on the right side that does not look easy to remove. What am I missing?
eating alternators
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX20 dollar fhi alt from the junk yard is quiet. FU napa.
eating alternators
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought about this but kinda ruled it out based on sticking a screwdriver on the t-belt covers and hearing nothing, screwdriver on the alt is loud. ?? The new noise is different, it goes away with the alt belt off, it's coming from the alt based on my screwdriver test. How do I tighten the crank pulley or inspect its tightness? How do I check the electric load on the alt?
eating alternators
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlright sounds like it's just a pos alt. I had to get to work today when installed it in their parking lot. Think napa will just give me my money back? I think I'd rather have that. I guess the plus side is alternators are easy to swap out on these cars. Alright I'll go hassle them tomorrow. I guess it's probably something they've dealt with before...the insta-return. Looks to be a whole bunch of em at the yards...anyway to tell if it a subaru alt and not aftermarket??
eating alternators
95 Legacy 5mt 161k. Replaced the alternator a year ago...last 6k miles my cars been making a sound like it was throwing a rod...nope...bad bearings in the alternator. So I have a lifetime warranty from napa and went down and exchanged it. As soon as I put it on I could hear the bearings in the new one...not hammering like the old one but its def noisey. SO, did I just get a crappy alt from napa or is there something else going on? Only thing I could think it MIGHT be is a loose crank pulley as the alt belt has more leverage on the crank pulley than the ac belt.(no noise with just ac belt on). Any thoughts? tia.
95 leg stumbling and clacking
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks guys. It hasn't been sitting. I just filled it up and put a new pure one air filter in. Stumbling appears to be gone. Bad gas and the dirtiest air filter I've ever seen?? knocking on wood, pun intended.
powderhound replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI changed the oil recently. I suppose new plugs n' wires are in order. Air filter is probably a good idea too this one has been through one too many dust storms. I just noticed oil seeping out around the knock sensor. I think...the knock sensor is front left next to the ej22 stamp? Doesn't seem like oil should be leaking out of there.
