136
Let us all bow our heads and pray, may the good lord have mercy on your transmissions soul. Here's the deal. The Torque converter should be unbolted from the engine and left attached to the transmission. The reason for that is that the torque converter has to be seated into the transmission a certain way or else it will destroy the trans fluid pump. Now the fact that it hasn't grenaded yet says that you might have dodged a ginormous bullet. Normally trans fluid pump death is nearly instant. There's about a one in a million chance that you got the TC lined up perfectly with the fluid pump, and It sounds like you actually got it. But it sounds like you cut the input seal in the process of mating the engine and trans together. You'll have to remove the engine or trans to repair that. Unfortunately removing and inspecting the fluid pump for damage isn't quite as simple as replacing that seal. Here's what I'd recommend. If the pump is damaged, it will throw in the towel before long, and basically you'll need to drop in a whole new (used) transmission. Tearing apart the trans to replace the pump unit just isn't worth it and there's no guarantee that other parts of the trans won't be damaged by all the metal shavings being pushed out of the pump in the fluid. I say, remove the engine (or trans, your choice) replace the input seal, seat the torque converter the correct way, and drive it 'til it quits.
Yes you can. But just for good measure, set the engine at TDC on number one, or turn the crankshaft until the dot mark on the sprocket lines up where it's supposed to be. Then make your OWN marks on the cam sprockets and timing covers, and a mark on the crank sprocket with whiteout or paint or something that won't rub off easily. Doesn't really matter where, just as long as your marks are clear. That way you know exactly where the sprockets are supposed to be just in case they get moved by accident.
A thunk and then no more go, makes me think of blown out valve body seals. But the only way to find out would be to take it apart and look or have a transmission shop diagnose. Either way that's a pretty expensive job. It could be a $100 fix, or it might need a complete rebuild. Hard to say without taking it apart. Good used transmission time for sure.
Interesting observation. This may be true for some vehicles but it all depends on the market conditions where you live. Scrap value for American cars hasn't changed much over the past few years, but wholesale values have sure dropped like a rock. European cars on the other hand are a whole other story. I've got a 2002 Lincoln LS with 75k on the ticker. Beautiful car, over 40K sticker when new, clean Carfax, but I'd be hard pressed to get $4,500 for it at auction right now. (auction prices generally determine trade values) We have a 2000 Mercedes Benz C230 on the lot at work, with 76k on the odo, in similar shape to my Lincoln. Clean carfax, no accidents, was around $34k new. Other cars like it easily bring $6,000+ at auction. Older car, same mileage (which does help but not as much as people think), lower original MSRP, still worth more money than my American car. The market determines depreciation, and it can change at any moment. Eight months to a year ago a 2006 - 2007 Mercedes E350 in average shape with sellable mileage (between 30k and 60K) would sell at auction for between $19k and $24k. Now the same car is selling for 22k - 27k. An average of $3,000 more for older cars with slightly higher average mileage. Those cars have actually appreciated.
As stated before, the Short dipstick is for the differential gear oil, which is separate from the transmission fluid. You need to drain the front diff and refill with fresh 80w90 gear oil. Takes about a quart IIRC. The long dipstick is where ATF goes. Sounds like you need a couple quarts in there, though I'm not sure why it would be low unless you drained the fluid or have a leak that hasn't been addressed.
If you got the car from a dealer, did you buy it with any kind of warranty coverage or "As Is"? Most dealers will include a 2 months/2000 mile powertrain warranty on cars sold at retail. Of course if you got it from a private seller then You just get to eat the cost. But I second finding a Subaru repair shop in the vicinity of Boston. Bent valves aren't that bad to get fixed. And you might spend $1200 to get it back on the road with new timing parts and head gaskets (Rather than $2000+ on an engine in unknown shape), and have a car that's ready to go another 100k miles.
Exedy/Daikin (same company) clutches are OE parts for Subaru. Valeo supplies Subaru OE clutches as well. Sachs clutch kits I've always had good luck with. They make OE parts for many European cars (Saab, Volvo, and BMW I know for a fact). I just ordered a Valeo kit on thE Bay for my 96 legacy for $109 shipped. I cheaped out on it for money reasons. (might bite me in the rump roast, I'll know in a few weeks) I was going to order a Sachs performance clutch, but this came up suddenly, and right after Christmas... I didn't have $260 to spare on the clutch kit by itself. You can get Exedy clutches the Bay for under 150 + shipping in most cases. A non-performance Sachs kit can be had from Rockauto for about $160 + shipping.
You shouldn't let any kind of sealer set on aluminum parts before tightening. Always tighten as soon as applied with any sealer on aluminum or you'll run the risk of cracking. Aluminum doesn't flex the same way steel can. While it is stronger pound for pound, it's more brittle and prone to cracking if specific tightening sequences are not followed, and the surface being sealed is not completely uniform with the surface of the part. To err on the side of caution I would remove the pump, clean the sealer off and re apply. Then tighten the bolts in order to the specified torque right after it's put on. I try to wait at least an hour after applying sealer before adding fluid. Twelve to twenty four hours is usually the preferred cure time.
If it gets thin enough you can end up with this... But that's an EXTREME case of worn out. That was caused by the rotors and pads getting too thin causing the caliper pistons to jam. Rather than retracting back into the caliper they dragged on the rotor, causing uneven wear and eventually wearing it so thin the braking surface of the rotor was severed from the hub. From what you've described I think you'll be OK to let it slide a few months as long as you're not driving the car long distances.
Radiator
Fairtax4me replied to state's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Probably cheaper to replace it. I had a copper radiator flushed at a local radiator shop a couple years back. They charged me $120 to flush it and patch a small hole, and it wasn't even in the car! A brand new one was $120 at the parts store! Check out Rockauto.com. They have great deals on stuff like that. You'll have to pay shipping, but it's usually not much. -
Did you see what they broke before they replaced it? I can't picture which bolt it is that they were trying to "adjust". The one that holds the ball joint in has to be removed to get the ball joint out. The two bolts that hold the strut are easily removable. And if you can manage to break one of those...
I thought about that, but it seemed like they should have had plenty of time to bleed and re-fill since he said he'd driven the car over 100 miles with no problems since doing the work before the problem started. Usually compressed air is best for clearing oil passages. If you don't have that use a spray cleaner. Wear eye protection.
The "slop" is commonly known as "lash" in auto terminology. The lifters or lash adjusters are hydraulic and use oil pressure to keep the lifters pumped up, and lash at the recommended spec. Lack of oil will cause the HLAs to bleed down which creates a gap between the rocker arm and valve. Makes noise and prevents the valve from opening all the way which could lead to rough running/low power. You'll want to remove the rocker shaft and find/remove the obstruction in the oil passage. Do you have a service manual for the car?
That O ring is only a seal for the bearing retainer. The bearing doesn't touch the axle stub so replacing that will have no effect. The bearing is pressed onto the differential carrier as seen in this pic: http://i209.photobucket.com/albums/bb29/Gloyale/DSCF0039.jpg not very clear but its the best I could come up with right away. The stub sticks through the differential carrier but the carrier is between the stub and the bearing. If there were anything that could be replaced to help "cure" the problem it would be the stub itself and the shim washer behind the side gear. But even then it may not fix the problem entirely because the carrier itself will also be worn where the stub makes contact. There is play in that stub because of the design. It may be less when the differential is brand new, but there is still play. So I suppose if you really wanted to "fix it" or make the play as little as possible, the easiest (and probably cheapest unless you have the proper tools) way would be to buy a new transmission.
