spark plug wire came apart in the car. how the hell do I get it out?
Fairtax4me replied to kemmer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLive and learn.
camshaft regrind 95 Legacy?
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't see the point unless they're damaged.
1996 Outback issues
Fairtax4me replied to JeffStu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd probably futile. From what I have read, these things start reading incorrectly within a year from being brand new. Replacement parts are expensive, and the problem is almost guaranteed to return. I go 240 - 250 miles in town before filling up, (I average 20mpg city) and even then I still have about 4 gallons left in the tank. You just get used to looking at the trip ODO after a little while.
Fairtax4me replied to kemmer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPick tools are great for this kind of thing.
Map, code 105 & 106
Fairtax4me replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThose two codes are two trip codes. How far have you driven since the reset? I have a P0106 currently. Replaced the MAP and it's still there. Checked all vacuum lines and can't find anything severely out of whack but the car seems to run fine. I gave up on it until the weather gets warmer.
Nice burning coolanty smell
Of course the car can't just let me slide with a new clutch and main needle bearing in the transmission, it has to make me do something else to please it! I've had a very very slow leak around the water pump since I got this thing (96 2.2 in case anyone wonders), which I can smell from time to time, but I've never had the coolant BURNING smell that I had this morning. (burning as in, dripped on the exhaust pipes and burned off as they got hot, not a pleasant smell.) So, Does anybody use something besides just the little paper gasket when replacing a water pump? I'm thinking some Indian Head shellac will keep it from doing this ever again.
Turn signal lamp
Fairtax4me replied to JohnKos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX3 bolts and the whole assembly pops out. The hardest one to get to is behind the grille. Putting that one back is optional. But the grille is really easy to remove. Get out your flavorite flat head screw driver, pull the grille outward with your hand, (start on one side and work your way across). If you look close at the little tabs on top they have two bits on either side that stick out, just pop those in with the screw driver and the tab will slide back. The lower tabs half the time are broken or will break when you remove the grille, but just a quick pull upwards will get them loose. I take them off and put them on the grille before reassembly. Little tab on the bottom that you just slide forward or up (which ever way you look at it) with your finger and it will slide right out.
who makes the electronic swithc for drive by wire gas pedal?
Fairtax4me replied to bheinen74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was wondering what Mechainicals are. Hesitation is a pretty common problem in any car that has TBW. Most of the time aftermarket tuners are the ones who get it straightened out the best.
P0100 Trouble Code on 2000 Outback
Fairtax4me replied to billbony's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI did eventually find the problem to be a broken solder joint. Still running on the $25 junkyard replacement. I may fix the old one and see if it will still work. I kinda tore it up when I opened it.
Fairtax4me replied to billbony's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had some fun with a P0100 code back when I bought my car. Mine would randomly stall for n reason though, with no other symptoms. Engine ran perfectly, no loss of power, just would stall randomly. Even during cruising at steady speed with the car in gear. Check the wiring in the harness to the MAF sensor for cuts/crimps in the insulation things of that nature. Check inside the plug for corrosion/water/dirt or other evidence that may cause a poor connection.
Strange cooling system issue under certain conditions: 97 OBW
Fairtax4me replied to v8volvo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"Air" in the system from a failed HG will be in the form of exhaust gases. Doing a simple block test will reveal if this is HG related.
OBD II scanner compatibility
Fairtax4me replied to Bad Brian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot necessarily. OBD2 is standardized to all vehicles currently sold in the US. But the communication protocol used by each one was not standardized until just a few years ago. There are several and car makers can pick and choose which they want to use. Some older scanners will not communicate with newer vehicles due to the new protocols used today. You can pick and choose what you want to believe on wikipedia... http://en.wikipedia.org/wiki/On-board_diagnostics
RWD sedan?
Fairtax4me replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot if you lay on the gas and turn into it. No but really, I've done a fair amount of "playing around" with mine on gravel, and did some fun driving in the snow a few weeks back. AWD will start to push going into a turn IF you take your foot of the gas. Keep on the throttle, and it pulls the front end into the turn, swings the back end out a bit, but it follows right through. And when you get it really sideways its close to driving Rwd... just faster.
96 headlamp differnt
Fairtax4me replied to bobaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't see anything missing. There is no "bucket" on these lights. Adjustment is done by moving the reflector inside the housing, not by moving the whole lens. What gets me is the position of the hole for that inner bolt on the top support. It looks like it's too far back for some reason. I'll check mine in the morning and see what it looks like.
96 Legacy LS, 3 CELs, P0500, P1101, P0130 and other elec. weirdness
Fairtax4me replied to WonkoTheSane's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like the test mode plug is connected. Look under the dash for two wires with a green connector. Unplug them if they are connected. Guessing this car has an auto trans? (reference to park/neutral) Search the site for P1101. Sort by relevancy in the advanced search. Lots of info about that here. Same with the P0130, and the P0500. All of those are circuit codes (wiring) so check the harnesses for those items for breaks. Helps to have a multimeter to check for open circuits.
Rear Defogger Fix????
Fairtax4me replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, you can get repair kits at any auto parts store.
Auto to manual swap: code p1101 anyone have a fix?
Fairtax4me replied to Gsir08's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe automatics are a whole different beast. Do some searching for how this pertains to automatic transmissions specifically and you should come up with a few threads on how to address it in your case. Use the advanced search function and sort by relevancy.
95 Legacy Engine warmer question.
Fairtax4me replied to mixter_co's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVery much worth the cost if you live in a cold climate. It'll mean easier starting, faster warmup (which means less fuel), and less cylinder/ring wear.
Fairtax4me replied to bobaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOutback is a Legacy with a raised suspension. The bumpers were different, and the grille was taller. There is a recess in the bumper right under the grille on the OB that isn't there on the standard legacy. But the lights should be the same I would think. Same part number. 95-97 Legacy and Outback. http://www.subarupartsforyou.com/cp_partdetail.php?partid=1281 http://www.subarupartsforyou.com/cp_partdetail.php?partid=1191
Fairtax4me replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGot a multimeter handy? You'll want to probe each of the lines on the window near the ground side of the grid to check each one for voltage. The FSM suggests using a piece of aluminum foil wrapped around the lead that you can use to slide along the grid lines while monitoring the reading on the meter.
Fairtax4me replied to bobaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere were some that had one piece housings that included the corner lamp. And others were two piece where the corner lamp was separate. I'm pretty sure the 96 should have the one piece.
Estimate cost for Oil Seperator plate and Oil pan gasket
Fairtax4me replied to yesyeah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell the separator plate is like $30 for the parts but probably 4 to 5 hours labor to pull the engine/transmission to get to it. Supposing they pull the engine to do the oil pan gasket, the separator plate would take another maybe 20 minutes to fix while it's out.
Transmission mounts Normal vs "hard"?
Fairtax4me replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'll probably stick with the trans mount for now. The motors mounts could probably stand to be replaced, but they don't feel like they're flopping around all over the place when I shift or accelerate hard.
A recently removed axle nut that won't come off?
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you hit it with a propane torch for about a half hour it might start to glow... in one spot.
Forester VLSD Troubleshooting
Fairtax4me replied to lostinthe202's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXToo bad its 4.44. If it were a 3.90 I'd be interested.
