Everything posted by Redcap
90 Legacy won't idle cold
Recently, my Legacy has stopped idling cold. Once fully warmed up, it is better (though still somewhat erratic, more than I would like)...but during cold-mode operation, I have to keep on the throttle or it will just die. Suggestions on a course of action? I'm pretty lost on these fuel-injected cars...makes me want to go back to an EA81 or EA82.
Broken belt, piston damage?
Redcap replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA phase one manifold works with a phase one head.
Redcap replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSwitch intakes then.
ac belt made a hole the in timing cover
Redcap replied to AEIOU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTiming belt covers are unnecessary. I put mine in the circular file.
Carb adapter plates
If doing the Weber on an EA82, this adapter is superior to the other style. http://www.jegs.com/i/Trans-Dapt/969/2107/10002/-1?parentProductId=749343
Newbie needs help with Legacy purchase please
Redcap replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just made the transition from 85-9? GL/Loyales to the Legacy. The difference is night and day.
At what speed do you cruise with your legacy ??
Redcap replied to renillo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI cruise between 60 and 70 on I-5, kind of a slowpoke.
5x100 rim interchange (Other makes)
Redcap replied to AdventureSubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhich is incorrect in regards to any wheel using cone lugnuts.
DIY strut lift blocks
Not particularly well. EA82s (as in your '87 GL) are VERY easy to build a lift for...
Check this out if you wanna Go Wheeling are Stock and are in the PNW!!! Free 2" lift
It is really too bad that Mt. Vernon is so far away. Eventually, I'll get to meet you guys.
Most cost-effective way to eliminate the boxer misfire ...er, 'rumble?
Redcap replied to bulwnkl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like you need a different brand of vehicle then.
On board air?
Using a York is the easiest and most reliable way to do this. Also, the old giant Chrysler units will outperform a York, but they are getting hard to find and are more difficult to convert. I've done a few York conversions on vehicles over the years.
1996 Subaru Legacy LEMON
Redcap replied to subarulegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCouldn't have said it any better.
Finally got myself an Impreza...
Redcap replied to cal_look_zero's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAgreed!
How do you remove that chrome finish from an old bumper?
Sandblaster.
Passing wire through firewall 2000 legacy
Redcap replied to Rpm90001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI completely agree!
Redcap replied to subarulegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah...we don't really do that kinda thing over here on this coast.
Redcap replied to subarulegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat is a 'PPI'?
Redcap replied to subarulegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo, you didn't do your homework when you bought a used car...and suddenly the car is a lemon? I think not. Let this be a lesson in the used car market.
Spark plug tools
Redcap replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnytime you need to pull the crank bolt...
Spark plug tools
Redcap replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdon't forget 22.
Spark plug tools
Redcap replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHuh?
gettin at my wits end....
Redcap replied to 95legwagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX5MT swap for the win.
How bad is this rust and damage?
Redcap replied to ttt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got a similar car (less rust, more damage on the hood/driver's fender) for free...in my area, the car in OP's pictures is worth $1000 on the high side.
EJ timing belt procedure?
Redcap replied to Redcap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSuccess! Been waiting since USMB went down to give an after-action report! Timing belt action with off without a hitch...once I knew how do actually do it. (damn those arrows!) Headgasket sealed up fine...that has to be the most bizarre headbolt-torquing procedure I've ever seen..., but the Legacy runs great and I rather enjoy it! I now officially own a fuel injected car (after 15+ years and 100+ vehicles); this is the first one. Ever. Next project will be lifting it.
