vagen
Everything posted by vagen
  1. I have used this on nissans many times but I'm not sure if it will work on the suby turbo. what we used to do is slightly crush the regulator top increasing the pressure a little. I think it was 10 psi max before rupture. would this benefit the EA82t or am I chasing my tail again.
  2. Thanks that's what I needed to know.
  3. For mine I figured they would just two tone the grille so here's my take...
  4. has anyone tried to fit a WRX muffler on their older car. I'm thinking about buying a WRX muffler for my RX ( I like silent power ).
  5. go to ccrscca.com the auto cross schedule will be on that site. I hope to see you out there.
  6. I just scored a sweet SVO intercooler that should help this engine make more power reliably. now to hunt down an oil cooler...
  7. 2wd struts from the XT OK and I guess I can use the special springs that are coming with my car. the rear I'll give a call to a friend with a Miata and use the rear struts from one of those. I saw that setup used by Numbchuks
  8. Ive been using the search function and have found lots of info on rear struts but little on the front. I want to keep the 4 lug but I want travel at a lower ride height what struts will give me that? this is on an 88 RX. The reason I want to keep the 4 lug is I have several sets of wheels with my various race tires on them. I am using this car for autocross aiming at street mod (so I can get away with bad things )
  9. oh well top mount it is.
  10. Darn I was hoping this would work. the grille on my rx looks like it went missing at some point. perhaps I could have the in/outlets moved to the back of the cooler.
  11. I am wondering if my FMIC will fit I don't have the car yet so I can't just walk out and measure. what I have is a 27x5.5x2.25 Ebay cooler. I'm thinking about replacing the grille with it the 27inch length is to the end of the in/outlet. If I cant replace the grille I will probably put it behind the grille. this is an RX that I'm working with
  12. first stop for this car is right back in the hands of one of the builders. He will give it a thorough check and we'll go from there. I will keep you in mind if I decide to move on. On the rebuild date MY Mistake I didn't check the date on the event and was told they built the car two weeks prior to the event.....the 2004 event was Sept 2003 so OOPS.
  13. Where does the spider Intake come from?
  14. I don't plan to turn up the boost from it's current setting, just improve the efficiency and gain power from that.
  15. Thanks for the advice. I should add some background on this car... This car had a complete rebuild in 2004 in preparation for the GRM $2004 challenge. The heads were ported and decked and a 5 angle valve grind was included. A bov was added to the stock boost pipe and many gauges to monitor things. A TWE down pipe was added and a straight pipe exhaust with just a glasspack. The air box was gutted. there is a manual boost adjuster on the car set to 10psi (as it was for the challenge). Custom wound springs and a custom camber plate were used to improve turn-in. I think this car is well built. I however want to make it nearly bullet proof (well more so than it is now) and have a bit more power. My plans (after reading things here) are: oil cooler intercooler 280zxt injectors XT-6 sway bars WRX turbo for reference this is the car
  16. never mind I figured it out
  17. I have an 87 rx awd turbo coming I know it has analog gauges does this have a boost gauge or a light? and if it has a light what pressure does the light come on?
  18. that's what I was looking for. I think any oil cooling is better than stock especially in a turbo application. I guess I'll have to figure out exactly what is legal in the class I'm planning to race this in.
  19. can I use a sandwich adapter type cooler and cool all the oil?
  20. so this is the same as a sandwich plate adapter type cooler that takes the oil and runs it through a the filter then the cooler and back or is it unique to the ea81
  21. I think I'll add an oil cooler as well as the intercooler if I can find one that is.
  22. yes a former GRM Challenge car built by a friend up here in CLT.
  23. I will add a top mount. I have an old celica top mount and a Mazda recirc valve. I don't plan to get nuts with this but bumping boost up to 10psi is not out of the question.
  24. I wouldn't mind doing an ej18 and use the stock EA82 turbo but the class this car runs in requires the original engine code IE.. if it was an EA82 it has to stay an EA82. I think 130 hp will be enough to run top 20 if I can tune the driver up.
  25. I am new to the subaru family and I am the new owner of a rather well known RX coupe. I am looking to improve performance. I was thinking about adding an intercooler and recirculation valve. Will this be a worth while modification?
