vagen
Everything posted by vagen
  1. fantastic I think I might be able to get some then the parts store says the turbo ones are special but armed with this I may be able to order axles. Are they the same part for both sides or is there a difference?
  2. I am in need of rear axles is there any interchange for the turbo axles?
  3. I am looking for more airflow across the board but mostly I want a cooler charge
  4. ah... point taken i'll hold out for the TD04L then
  5. I'm looking at a vf10/11 from a legacy turbo as a possible upgrade for my stock vf7. here's my question... will the vf10/11 bolt in place of the vf7 or am I better off just converting to the TD04L? I'm not looking for huge power just less heat at the same boost levels. I already have an intercooler and d/v installed on the car and I am planning a set of 280xz-t injectors in the very near future.
  6. Installed one seat tuesday I might do the other this weekend
  7. I'd sell them to you if you don't mind putting your sliders on them. Plus shipping of course.
  8. I have another subaru only autocross coming up on the 12 of December I will post results of that event no matter how I do. even if I don't win I will say its nice to have a car that can compete my last two autocross cars were DOGS. I will say this I am still learning this car so it will get faster as I drive it more
  9. sure here is the first autocross I attended with the RX I had to use a link because it got messed up trying to cut/paste http://www.ccrscca.com/results/2009solo/ccrknightsax6_raw.htm the second event was a time attack put on by a drift club my times slowed down due to rain Cl/# Driver Location Make /Model Fastest Time POS FR 121 Alan Schoonmaker Concord, NC C4 Corvette 50.591 1 FTD! FR21 Adam Schoonmaker Concord, NC C4 Corvette 50.625 2 FR50 Billy Coan Harrisburg, NC BMW 325i 53.224 3 FR47 Michael D'Amico Charlotte, NC Mazda Miata 53.868 4 FR48 Kevin Parlett Charlotte, NC Infinity G-35 54.406 5 FF64 Duane Stepp Jr. Asheville, NC Burke Motorsports Saab 9-3 57.794 1 FF54 Greg Cannon Matthews, NC Honda Civic 99 59.36 2 FF60 Jonathan Collins Charlotte, NC Mazda Speed 3 62.154 3 FF63 Tom Jones Charlotte, NC Mazda MP3 63.407 4 FF67 Justin Bickley Concord, NC 3SX Eclipse GST 72.317 5 AW55 Philip Rodda Charlotte, NC Subary Leone RX 55.826 1 AW78 Josh Sotomayor Charlotte, NC Subary Impreza 2.5RS 57.598 2 AW65 Eric Bowden Concord, NC 3SX Dodge Stelth RT 63.176 3 Run Breakdown Group A 47- ) 54.689 55.309 54.852 -53.868- 54.569 48-) 57.747 54.972 55.208 -54.406- 54.908 50-) 58.754 -53.224- 58.262 ------- -------- 64-) 63.096 58.118 57.912 57.739 -57.794 Group B 121-) 54.469 51.465 50.591 --------- -------- 54-) 63.419 59.550 59.920 -59.360- 64.109 55-) 54.917dnf 54.509dnf -55.826- 57.516 58.908 21-) 52.202+1 -50.625- 61.219 Group C 65-) 67.768 65.473 77.322 66.355 -63.276 67-) 76.781 74.627 -71.317- 80.064 Group D 60-) 65.780 64.085 64.137 64.774 -62.154- 78-) 59.843 58.795 59.094 -57.598- 58.152 63-) 68.141 67.562 64.993 -63.407- 63.765
  10. for auto cross the RX suspension is pretty decent but with the miata struts and coil overs it should be fantastic. this car has made a good showing in it's last two races. 6th out of 31 running no I/c and stock boost and then 5th over all out of 13 winning it's class by about 2 seconds. after the Miata/coil over suspension I hope it will be a FTD car or within a few hundredths of it. I just need a little more power
  11. so what I really need is a wrecked in the rear or rusted to near oblivion EJ car that I can pull the harness and engine out of. Correct?
  12. Numbchux sells a conversion harness for the OBD1 EJ22. I am most likely going to go with that harness and matching computer. I was just wondering if it could handle the extra 245cc of displacement that a 2.5 has. I am leaning heavily toward a 2.2 Frankenstein for my car. it would be a 2.2 bottom end with EJ18 heads (ported and polished naturally) and delta cams. I am planning to use a 2.5RS header and probably my existing exhaust (even though it is probably too big @2.5 in). Intake is the area I'm still working out, the stock airbox on my car is incomplete and there is no heimoltz resonator in the fender. I'm thinking about using two sizes of pipe to try to imitate the resonator 3" for most of the intake but a section of 4" to buffer the pulses. I have seen an intake like this on a friends 2.5RS and he doesn't seem to have any problems RE: AFM misreads. Option two would be to use the resonator box from a newer subaru that mounts right at the TB and go from there on an intake.
  13. can the 2.2 ecu compensate for the additional displacement of a 2.5? I'm not seeing many prepped 2.5 harnesses available just 2.2. TBH I'm just lazy enough to go for a 2.2 because of the harness availability.
  14. this EA was built by someone who knows what he's doing but the years of high boost and equally high RPM have taken their toll. I will be looking for a good EJ22 and probably a set of EJ18 heads to build a high comp Frankenstein EJ. If I can't find a good 2.2 I'll go with a SOHC 2.5... The problem there is I can easily buy a ready made harness for the 2.2
  15. I got the car with the knowledge the engine has had a LOT of abuse. 14psi at the GRM challenge and then rally stages in GA followed by several years of autocross. it has started to use oil a touch faster so I am thinking it is on the way to EA heaven. I'm currently looking at an N/A EJ22 and I've looked into heads and cams for more compression and breathing. what I've discovered is with higher compression and a set of Delta cams the EJ22 makes good power in the 150-170 crank HP range. That would replace the EA nicely and have almost none of the reliability issues associated with the EA.
  16. I have a pretty well set up ea82t but it's showing signs of being tired. I am looking at the EJ22e but I'm worried it will be a performance downgrade compared to my turbo. I am wondering if the 22 can be modified for more power easily? my ea82t is making just shy of 160HP at the crank so the EJ would have to match that at least.
  17. today I replaced an exploded fuel pump and then won my class in time attack at a drift event.
  18. Preparing for an autocross Sunday I am taking on a 2.5 rs and two 500+awhp DSM 3000(ton)gt's so I'm making sure everything is tip top. I tightened all the hose clamps under my hood and diagnosed my low speed off boost stumble. turns out the inlet pipe had come off the turbo and was just sitting on it I also turned up the boost to 11.5 psi if I pull in 4th or 5th from low speed it'll hit fuel cut but if I rev it in a lower gear no fuel cut. It's supposed to rain Sunday so 500hp hopefully will be a detriment
  19. my setup is a lot like turbone's I learned my lesson building turbo datsuns so I knew before anything cool the charge. I'm currently using a $5 Ebay MBC but I have modified it to actually work and I see a steady 9.5 psi. below is a photo of my setup note the BPV (Bypass valve) routes boost pressure back to between the turbo and afm. it opens only when the throttle is closed. this keeps the turbo spinning at speed so when you shift the turbo will reach boost faster. A BOV/BPV will extend the life of your turbo because the turbo doesn't deadhead against a closed throttle. Dead heading will actually stop or even spin a turbo backwards imagine what the bearing is going through when that happens.
  20. I haven't done it yet but I have new race seats coming anyone interested in my old RX seats they are in ok to good condition. fronts only I'm keeping the sliders for now
  21. modified Tokiko iluminas for a miata they are 2" shorter than the stock struts. a miata weighs 21-2300lbs my car is 2500. I hope to bring theweight down a couple hundred by removing the sound deadening. On my last race build the sound deadening accounted for 150lbs.
  22. according to the manual you must rotate 360 here's a link for reference http://offroadingsubarus.com/timingbelt_ea82.html
  23. did you install one belt then rotate the engine 360 and install the other belt? Not doing this is a mistake that is rather common. If you just install them with the cams 180 it won't run. I've made this mistake so I make sure others don't.
