Everything posted by vagen
I think I broke a rear CV
what worries me is I can't seem to find any replacements for the rear of a turbo. any suggestions?
I was trying different things at an autocross and I thought since it was wet I could try the diff lock.... I couldn't even make the turn to stage. Now I have an intermittent click from the left rear... Lesson learned.
My RX Autocross car preparations
I'll go look for one this weekend I hope I can find one that will fit in front of the air box. While I'm there I will look to see if the Loyale they have still has a complete airbox. I want to see what an unmodified airbox looks like.
I do have some wiring to do I will admit that
Intercooler sprayer is on and working
fixed
here is a short video of my RX exhaust
the roof scoop? its just a stick on scoop and it doesn't do anything other than ruin aerodynamics. In fact I'm removing it.
I started the install of my intercooler and with the bracket to keep it solid I need to cut the pipes to hook it up and add the fittings to hook up IAC and BOV
installed the boost controller YAY 11psi and no cut wooohoo!!!!!!
I just installed the boost control and I had it adjusted wrong but wow 25 psi is strong!!!!! I backed it off to 11psi
only one problem I am staying with the 4 lug so........
I think intercooler is going to be first then more boost finally a TD04.
I took the car to an autocross tonight I placed 6th in raw time over all and was 2nd fastest for several hours. the fastest car tonight ran a 28.3 second run I ran a 29.7. For the first half of the event the fastest car was 28.7 and no one was any closer than my time. This is quite literally the first time I have driven this car in anger and WOW it's quick.
Loyal with no power.......
this might help http://offroadingsubarus.com/timingbelt_ea82.html
Problems when boosting. Subaru RX -88
when you look at the engine it is the aluminum part that says turbo on it. On my car it was the connection at the turbo that was loose.
oh I plan to I can tell you it has helped throttle response a bit and the boost is now 9psi without adding in the controller.
- What Have You Done to your Soobie lately? (Please post in here and keep it going)
Installed the nice 2.5 in exhaust- My RX Autocross car preparations
JWX has another white RX with adjustable camber plates and many other mods the hood scoop appears to me to be a stick on aftermarket piece that has had the adhesive die. I will be replacing it and perhaps the whole hood so I can relocate the opening for the scoop slightly.- Loyal with no power.......
double check your belt install there is a process that is easy to mess up.- Improving EA-81 performance
I wonder what a set of mpfi pistons would do for the EA81 after all the EA82 MPFI has 9+:1 compression. it would have to help hill climb power.- Problems when boosting. Subaru RX -88
check the connections on your plenum. if they come lose they will look fine till you hit boost then bleff no power till you get out of it. I found out this afternoon what that is like. I would hit 5 psi and suddenly no power. Opened the hood everything looked fine till I started wiggling things. so give that a look.- My RX Autocross car preparations
here is the car this is the TWE down pipe today I replaced this with this For those who want to see my camber plates here they are as you can clearly see they are not adjustable - What Have You Done to your Soobie lately? (Please post in here and keep it going)
