Everything posted by Dirk
Some good stuff on here right now. I want it all but me got no penny's. http://www.trademe.co.nz/Members/Listings.aspx?member=58913
Nice one! Moosens will be jealous.
Pretty sure a 78 dl would have had breaker points as standard. Maybe someone has upgraded to breakerless since then and not bothered to ditch the condenser. Have a look under the dizzy cap and see. That said if it is still breaker points then the engine would not run without the condenser connected.
Dual Hitachi 26/30 vs Weber 32/36 on an EA71
Dirk replied to Dirk's topic in Historic Subaru Forum: 50's thru 70's
Bueller? Anyone? -
Transmission reseal/ new bearing. With Pics!
Dirk replied to soobenthusiast's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Bookmarked. Great pics thanks for the thread. -
EA71 - Rough Idle intermittent problem
Dirk replied to zuki1100's topic in Old Gen.: 80's GL/DL/XT/Loyales...
'You think it's worth while changing out the plugs & leads for a spare set I have? I suppose it would be good comparison.' Always worth a shot but better to change only one thing at a time. -
Odd that only two plugs are fouled......... I would make a start on the dizzy. First up, is there any play in the shaft? Next, check the air gap between the paddle and the pickup. Should be 0.14" Be absolutely sure there are no cracks in the cap. Maybe you could borrow a cap from someone to try just to be sure. Cheers. Dirk. -
I'm still thinking the plugs are fouling. Maybe due to weak spark. I would like to see the condition of the plugs. When did you last change them? Maybe check the igition system. Make sure you are getting a good spark. Plugs Points Cap Rotor Leads. You got a manual? -
Working room in the engine bay.
Carb is the larger EA81 Hitachi. I removed all the vacuum accessories and converted the secondary to a mechanical linkage. Also I converted to maunual choke. The air filter is 'ramflo' It is a washable filter but I don't trust it so I have changed back to EA81 filter but have cut up the filter box and repainted. -
Subaru still burning coolant after head gaskets
Dirk replied to Nick_R_23's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Maybe take a shot at 60Nm (42ft/lbs) first. I'm willing to bet a beer you will get 1/2 a turn on them now that youv'e run the engine in. Foot pounds???? Bloody imperial stystem! You guys had the golden chance to give that crap back to the limey's on the 4th July! What happened? -
Cool. thanks. But what about a stock hrydro cam on solid lifters. Benefits?
Wouldn't hurt to give them a tweak. -
Clunking sound on acceleration. 86 brat.
Dirk replied to fattie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Could it be a slippy clutch? Maybe an oil leak from transmission or main seal? Or a lose bolt on the bellhousing. -
Could be that the plugs are fouling at WOT. Seconardy too rich? or maybe a sticky power valve. When you swapped over the carbs did you swap over the jets? -
Skim read this so sorry if you already have but.. Have you re-torqued the heads? -
Has anyone done this?
Cool. Thanks.
Question for our kiwi contributers
Dirk replied to maudsland's topic in Historic Subaru Forum: 50's thru 70's
Hey. I've done a few local business searches but nothing much comes up other than a cafe. Maybe try posting something on trademe nz. someone out there will know. Small town and all that. Dirk. -
I think a little research might be in order here matey. I hate the search function on this forum. I think it is awkward at the best of times. However, with a little patience I think you will find all your answers and more on this forum if you look. Cheers Dirk.
I have access to a grunty lathe so I was considering machining a wee bit off the flywheel or at the very least cleaning it up before getting it balanced. But looking at it, it is not all that big anyway. Is there any benefit to lightening such a small wheel? Cheers Dirk
running ruff, wierdest issue; explained
Dirk replied to soobie_newbie67's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Is fuel flowing freely through injector rails?
