Everything posted by Big Country
'01 STi Swapped RS
PICS! Sorry, Its been slow. I've been installing the STi drivetrain! I'm pretty sure I broke 2nd, but I haven't opened the transmission.
'01 STi Swapped RS
I picked up a new toy a couple of weeks ago... I don't exactly have huge plans for it yet, but there are a couple of thoughts going through my head. However, tonight I broke the tranny, so that is at the top of the priority list right now... Here is some info... Engine Mods -05 EJ257 Full STi longblock swap with AVCS -Garrett GT30r w/ .82ar exhaust housing -Full 3" downpipe -GT-Spec UEL header -Turbonetics Newgen wastegate -HKS Hipower catback -4" intake -FMIC -PE 850cc sidefeed injectors -Allstar vented catch can -ARP Headstuds -Perrin overflow tank -Hallman MBC Transmission/Drivetrain/Suspension mods -Forrester transmission -ACT street clutch -M4iF fender braces -KYB GR2 struts -17mm FHI Rear sway bar -20mm FHI Front sway bar (not installed yet) Exterior/Interior Mods -STi V6 replica wing from Bakemono Imports. -STi OEM foglight covers -04-06 STi style hood scoop -Shaved door moldings -JDM Ver.6 Taillights -Black Housing Headlights -Black housing Corners -Triple 52mm center gauge pod
Good Wheeling Shots! Add you favs! (Comment Free Thread)
Do Buicks count as a type of terrain?
New on here, From Albuquerque New Mexico *pics inside*
Welcome! Nice cars and shop! I live in Socorro, Glad to see another Member from NM!
Kentucky Fried ECU
Well damn, at least I know that I definitely have a phase one EJ now Thanks for the info and help
Kentucky Fried ECU
Thanks for the diagram. You were right, it was the main relay. In your drawing there are 3 plugs. I'm under the impression that the obd 1 ecus have three plugs and the obd2 ecus have one large one. I'm only saying this because I have one large plug. Am I missing something? I'm asking because I know that I don't have all of the powered pins connected but it is currently running fine off of the switched power. I would like to fix this at some point. Thanks again
Kentucky Fried ECU
It ran before wires got cut, but I didn't check the main relay. Could you refresh my memory of how the pins are numbered please? I'm in the middle of a move and don't have access to my diagrams. I'll check this out in the morning, otherwise I'm headed to the junk years to pull another ecu. Thanks.
Kentucky Fried ECU
A few weeks back, my stripped wiring harness for my 95 EJ22 swap got some of its wires wrapped up around one of the front axles. A few wires were ripped, but for the most part it just unplugged the engine. Today we soldered the wires back together plugged everything in, and no love. There is no signal to turn on the fuel pump and no spark. From what I've seen while wiring the engine, the ECU grounds the Fuel Pump relay to turn it on. We manually grounded the pin for that wire, to test the the relay and it came on, but the ECU never did that while plugged in. The power and ground pins for the ecu also tested good. I've been using my scan gauge for most of my gauge readings, but when we plugged it into the OBD2 port, it would never connect. This leads me to believe that the ECU is malfunctioning. I'm assuming that it got fried when the wires snapped when wrapped up around the axle... What does everyone else think? Any ideas, experience, or advice would be greatly appreciated.
So Really, how many started a ej swap and never finished it
Update: As of this week, the EJ Swap is finished!
Lots o' Swaps
Great news! I was having idling issues because of too little back pressure! I held a plate over the exhaust and it idled fine! :banana: (I'm only running the legacy Y pipe right now) I *just* finished stripping my wiring harness... wow... Can someone please explain the key switch to me? When looking at it, the Black/Yellow, Red, and Red/Yellow all look like they are supposed to be connected to a hot. Is this true? How is that supposed to work? :-\ Thanks! It may be 2 am, but I still have a huge smile about the harness being fully stripped. Hopefully it still runs
2011 NMT Mudbog Competition
I realize that a large portion of the members are not anywhere close to NM, but for the few there are.... The 2011 New Mexico Tech Spring Fling Mudbog Competition! Saturday April 9th!
Lots o' Swaps
I've never heard of fail safe mode... We tried to start it up again today, this time with the green test plugs unplugged... It didn't want to start. It backfired alot, and never started. We fixed the vacuum leaks, (so we thought) and Added an O2 Sensor. It did however start with the green test connectors plugged in again... How do we know if the Cam and Crank sensor are wired correctly? (We had to splice the wires in.) The Same question for the O2 Sensor. It will not idle. We think the cam and/or crank may be wired backwards, which would cause the backfiring and running in Test Mode. (Test Mode does put it at a factory idle and timing setting, right?) We may have the idle air control plumed wrong. Does anyone have a vacuum diagram, or insight on this problem? Thanks for the help so far everyone, This project is finally moving along, now it's just the small kinks left. Thanks again!
Lots o' Swaps
It Runs! ...Kinda This was a proof of concept test run. There is no O2 sensors and quite a few vacuum leaks (as you can see fingers plugging them...) After fixing the Vacuum leaks and adding a O2 sensor will the idle smooth out? Any other suggestions from anyone? Thanks. PS, the video doesn't do justice to how loud it was... It never got above 1400RPM in the video...
Lots o' Swaps
That makes more sense now, thanks. Did you get my PM?
Lots o' Swaps
Thanks for all the great info, but I have another question now. On a OBD1 Block, the cam and crank position sensors have three wires. But on a OBD2 Intake harness only has two wires for those sensors. Is the extra a ground? Thanks again.
Lifted Subaru's 2011 Edition
'88 GL Hatch 6" SJR Lift 15" Drilled Chevy Wheels 33" Mud Terrains EJ swapped in, but not wired up yet. *Update* EJ swap finished!
Lots o' Swaps
Thanks a ton! Its almost finished! In the Harness, there are two O2 sensors. Are both of those needed? None needed? What do people usually do about this? I have a manifold with no places for them, but i could drill holes if needed. Currently I plan on running only the manifold/Y-pipe and no catalytic converter. Any suggestions? Thanks
Lots o' Swaps
To clarify, intake manifold harness from an obd 1 will plug into a engine harness of an obd 2? thanks
Lots o' Swaps
It seems my Intake manifold is from a '92 (OBD-I ?) but the rest of the engine is from a 95. My Harness is from a '95 (therefore OBD-II, thanks numbchux). The Newer ECU won't plug & play with the older intake manifold, will it?
Lots o' Swaps
I have an obd-I ecu from a 95 legacy. What does the vss do exactly? I understand it is an electronic speed sensor, but why does the ecu not run well without it?
Lots o' Swaps
Thanks for the info for the Clutch. I'm starting the EJ swap now, Is a (VSS) Vehicle Speed Sensor necessary for the ECU? or can I just use a speedo cable from the tranny to my dash? I guess my question is, Does the ECU use the speed data for anything other than the speedometer? Thanks,
Lots o' Swaps
I have an 88 GL 4spd D/r with an EA81 engine, I have a 95 EJ22 & Adapter plate, and a EA82 5spd D/R Tranny to swap into that car. I've been reading and I'm a little confused about the differences in the trans-axles. From what I understand, the current CVs on the car are too short for 5spd tranny? Does anyone have insight on new clutches and throwout bearings? Any Links to write-ups would be greatly appreciated. Thanks.
Chevy 350
Sorry to take so long... I have been working on my hatch. This truck is a 1988 1/2 ton silverado. She still hasn't told me what is wrong with it, I've heard everything from the engine and or transmission is blown to the axle is missing. I haven't made the road trip to go see it. My DD is a 06 chevy half ton that is also my tow rig. I'm still thinking i want to stroke it to a 383 and super charge it, but i guess what i was asking in this thread is if anyone has seen or heard of anything interesting... My buddy showed me a website called Flyin' Miata, where they put corvette engines in miatas. That seems kinda interesting, but i dont exactly fit well in a miata. The way I'm looking at this is... I have a tow rig/ reliable DD, I also have a wheeler (88 Hatch), I'm guessing that this engine would probably go towards a small, light weight, fast, street car. But it doesn't have to be... I'm just looking for something to do with it that people don't see everyday. I would have never thought of lifting and wheeling a car until i saw this site, now i love my hatch. I'm just looking for ideas on a fun/unconventional high powered engine.' Thanks
Hello..from 1st time Brat owner..have a few questions
There is also a Southwest Group here if you would like to join. http://www.ultimatesubaru.org/forum/group.php?groupid=2
New here just wanna say hi
There is a Southwest Group here if you would like to join. http://www.ultimatesubaru.org/forum/group.php?groupid=2
