Everything posted by opus
GL headlights
Nope, corrected that as well.
GL headlights
Did the Sylvanias, helped a little but not much. Have had the lights all apart as well. Cant put anything under the bumper in this country. Too much snow, rocks and gravel, etc.
GL headlights
They will be better than stock? Can I wire them directly to the headlight switch?
GL headlights
Ugh, I cant take it any longer. I am about to cut a set of lights out of an F250 and duct tape them in. Buckets are good, got new lights as well. I cant see deer at night with them so I drive about 40mph and it is so painful! Any aftermarket suggestions?
1987 DL damp weather power fades
Thats what it is. I have the same issue here. I cant find a hot air tube though. Need to find something to make one out of. Mine seems to be about 3' long and NAPA doesnt have one.
I was given a nice running EA-81
Ranch, but really no need for irrigation, although I could pump out the river if need be. As for generator I have a military genset with a 4 cyl engine, just like the soob. This engine however is 32 cu in. Pistons are about the size of a shot glass I would think. You could hear it from there if I started it.
I used to drive school bus, I am used to it.
[bangs head on desk]
Why do I feel that everyone making suggestions is of the pre-puberty age group? LOL!
But now we venture from the practical realm.
Actually, thats what prompted me to post. $6000, you must be in a different tax bracket than I am. I was thinking a stationary unit, like a generator, etc.
Wow, you all give impractical ideas, or idea that will cost me a ton of money. Whats with that? I was trying to find a reasonably affordable solution, plus something I could actually make use of.
Ok, practical suggestions.
I figure I will build a tube frame for it and leave room at the flywheel to attach something to it. Whether it be an irrigation pump or a generator head, welder, coffee grinder. Keep the ideas coming.
Bwwwaahhhaaaa!!
What to do, what to do...... Its just the engine though. Generator, irrigation pump?
Fuel pump?
I'll do it....if the snow ever stops.
Fuel pump?
Fuel filter was changed 3 months ago. Could be it, but I doubt it. No O2 sensor [never was]. There is hardly any wires left in this. Emissions and all but necessary stuff has been removed, its pretty bare bones. I ran it and stood by with ether. When it started to die, I gave it a sniff and it would keep running. It would start with ether if I tried it. There is no gas to the carb.
Fuel pump?
Under the rear seat...interesting. So there should be voltage without the key on/with the key on? Where would the relay be located? Pics?
Fuel pump?
86' GL Wagon runs....5 mins later it dies from no gas [it will do this a couple times]. Hard to believe it would be gas filter. I am assuming its the pump. Whats the best way to check the pump, and where is the blasted thing? Can I pull a line off an turn on the key and will it pump then or is there a regulator or such?
'01 LL Bean Outback Catalytic Converter
opus replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is no shopping around where I am. Interesting enough though!
6 cylinder This gal brings it to the dealer because the check engine light comes on. They say the CC is going poop. It will last a little while but needs replacing. $2300 to replace it. Does that sound right?
Photo Shoot!!!!!! :)
Carb screw
Under this plug: http://picasaweb.google.com/pmilne/Misc/photo#5104288466642083922
Carb screw
You mean a 'sniffer' that goes up the tailpipe?? I've not seen one here. I dont doubt that they are everywhere in the populated areas. Heck, we just got colored TV here last year.
