7
Everything posted by rickyhils
				EA82. Could be a real "find"
rickyhils replied to rickyhils's topic in Old Gen.: 80's GL/DL/XT/Loyales...
And will snap a few pix of what the "unnamed mystery rebuilder" did with the cylinder walls and pistons. Plan is to start it up within 2- 3 weeks. Prognosis looks to be that this is a $100 "find". Will keep fingers crossed and say three "Hail Mary"s . Will prime oil pump with drill socket and fill water pump from heater hose. -
Going with Fel Pro 9392pt HGs. Since engine not yet installed. And I plan to use Permatex Ultra black for cam carriers. Fill slot [groove] and then medium bead. Push down and get bolts finger tight. Wait an hour and then torque to about 10 or 12 ft/lbs max. -
	If the pivot "bowl" on the clutch release fork is worn, can the Subaru part 30531AA220 be used?
From all you guys [General Disorder, Freddo and more . . . ] the experience and knowledge comes through, big time. But, yeah, seeing that pic from GLOYALE [mt-5 trans open case halves] gave me instant visualization to tear into it and get it done. And I had local help from Avo at Certified Subaru in North Hollywood who looked up proper part numbers for both main shaft bearings. I paid him for the parts and gave an extra $100 for his time and knowledge. He helped save that car. -
GD Only 40! You guys get even more amazing all the time. -
I was forced to learn when in 2008 my Loyale started leaking gear oil out the mainshaft seal [200k miles] . [FWD 5-spd] I saw a [then named] GLOYALE post a message on USMB and he had pictures of how to open the trans case on an MT-5 and do the mainshaft oil seal. I had only ever done axles and brakes on my Subaru. But no way was I spending $2,000+ for my local mechanic to do it. So, it was either do it myself or junk the car. And I did not want that car going to the junk yard. Pat on back for me - job well done. I only knew to put car on four 18 inch jacks and rent a transmission jack. I knew I could learn to do it even with my limited knowledge. And in retrospect I am still amazed that my brain remembered to put sealant on the case halves! [Homer Simpson- "Doh!"] The irony is that the car's previous owner was very easy on the clutch, thus there was no servicing of the clutch which meant that a disintegrated pilot bearing was not spotted, which no doubt accelerated the wear on the mainshaft related components. Live and learn. -
I looked up your bio. You are only 45 years old. I'm 65. You must have been like a teenager learning from the oldsters about Subarus. I'm impressed. -
Dave - If I had more room in the back yard I'd build the engine test set up, just to say I DID IT! But will go with redoing using Fel Pro PT HG's. -
Will update progress on this "rebuild find" in coming weeks. And before the new Fel Pro PT HGs go on I'll get some pix of the cyl walls. It does crank over smoothly by hand, but at this point one can only pray that the bottom end was done correctly. Will go with conventional oil as original. The radiator checks out ok and runs cool as a cucumber. All you guys here are great. Thanks a bunch. -
This rebuild has "MBL Three- Star" timing belts on it. That's an older product. Would more likely see Mitsoboshi name now days. And the HGs are for sure not Fel Pro. This could have been rebuilt 15+ years ago. The seller was into working on VW bugs and just had this sitting in his garage. He gave no history info at all. But for $100 bucks who would pass it up? Final decision is to re-do using Fel Pro PT HGs. Will keep in mind priming of water and oils pumps. The supplied intake manifold is for a carb. I looked the block over and the only possible difference from my 1991 Loyale block is maybe the odd little bracket mount to secure an A/C line at the top/right cam tower. Can fabricate. For the cam carriers ----> Permatex 22074 Ultra Grey? -
Existing engine has 326k mi. Runs well. But I might want to change out the pilot bearing [5 spd trans FWD] as I had previous issue [120k miles ago] where bad pilot bearing coincided with a failed mainshaft oil seal and a failed rear mainshaft bearing. [Can also inspect clutch] And currently the oil pan needs a gasket. Will get Felpro HGs to have at hand in any case. 120k miles back I put in new Felpro HGs with engine in car. No problems. Hardest part was keeping rockers from falling aside when putting cam towers back in place. I think I used plastic zip ties to hold rockers in place until cam towers bolted on. You said - "I don’t think I’d retorque the bolts" - Is that to say that a re-torque [on most likely these Ishino OEM HGs] may not even be necessary? Still have to keep a close watch on oil/coolant not mixing. Maybe after 500 miles then probably good-to-go? Install cam carriers dry? Is that to imply that simply checking and wiping off any oil seepage down the carriers from time to time might be a simpler way to go? -
Bennie. This EA82 was already rebuilt when I picked it up for only $100 on Craigslist. It might be good for a lot of miles. EJ swap is out. Too complicated for me at this point. Just curious - would that be the 2.2? or the 2.5? Do those even fit in a Loyale? What about the MT5 5spd trans? Do you need to put another manual trans with the EJ swap? And not sure if California smog check would view EJ as the "wrong" engine being in the Loyale. And yes, replace radiator if questionable! -
Maybe I would do well to look inside oil pump to see if assembly lube was applied. That could only help create the needed vacuum to pull the oil up. Speaking of which, whenever I hear the EA82 "tick of death" I could always shut the engine off then restart immediately and the "tod" would disappear. Is that due to a gasket that gets sucked out of shape? And is there some kind of check valve in the oil pump to keep it primed until next startup? Thanks -
Good info Yeah. Water pumps don't pump air very well. I'll make sure to put some water directly down into the pump through that large pipe that connects from the lower radiator hose. Also some down the cabin heater hose where it meets the pump. And if I take the thermostat out I can check for positive flow right away at the radiator filler cap. Then reinstall the thermostat. But the "die has been cast" and the rebuild is either "good to go" or . . . [God forbid]. . . oil starved main bearings or pistons scraping the walls. My money is on having it purr like a kitten. Will update in coming 2 months or so. Thanks for the help. -
Yeah, I'll leave the headgaskets alone. I will find extra ecu and fabricate enough "point to point" wire connections to fire up the engine. And why don't I just hook up a radiator? [shunt the heater line] But when firing up the engine I won't hear how it's running unless the exhaust system is bolted on with the muffler in place. But I can bring it over from the Loyale. Will maybe need to fabricate some steel support for the engine mounts. And I don't recall there being any crankshaft position sensor that the ecu needs to see. -
Dave. Thanks much. But I think that I am in over my head just a little bit Dave. Thanks much. But I am now thinking that I am in over my head just a little bit on doing this test run. First- Don't I need the ECM and some of the wire harness for the distributor to send spark and the SPFI fuel injector to work? Yeah, I have another manifold that is for a carb but I do not have a carb at this time. And slow water feed looping through the engine is doable, but won't the water feed prevent the engine from reaching operating temperature? Thus not letting the gaskets get fully hot enough? FWIW- I just redid the intake manifold gaskets myself, and I've done heads and even the MT5 mainshaft seal and two mainshaft bearings, timing belts and front axles. So, I have manufactured the tenacity to get things fixed [ and they stay fixed] . I am at a standstill. Option A- A test run will be very helpful and reveal much before install, but lot's of prep work. Option B - Install, run. [hopefully the rebuild will show to be good] and then go through the doable [but pain in the butt] hassle of re-torquing while in the car. Option C - Re-do heads with Felpro permatorque. Install engine and run. All the while knowing that a faulty engine rebuild will mean swapping back in the now working engine -
No hurry on this. I need to research how to do a test run set-up. Test run will need oil, ignition, and fuel. But how to crank over to start? Would imagine that carefully monitoring engine temp means no need for cooling system during test run. Just shut down when operating temp reached. And I'll need to fabricate a 17mm socket to fit inside the cam housing at those two bolts. It looks like the rebuild mechanic knew his stuff. Even the oil pan bolts were at the correct torque, [not over tight] and he put the slightest smear of assembly lube all around the cork gasket. The main concern is that those close tolerances inside were reassembled correctly. Will make audio recording during test run. -
Mack Truck - A carb manifold came with it. I am in Kalifornia so I am inclined to stay with the existing SPFI for now. But I will research the Webber 38/38 synchro setup. My 1991 Loyale is FWD and although it is under powered it still serves me very well. But the carb sounds inviting. Years ago I rebuilt a single barrel and also a two barrel carb. Fun stuff. You have 2in exhaust? Which muffler? -
	I just picked up a rebuilt EA82. Never run since rebuild as no oil inside yet. Only assembly lube is visible. Seller had no history, but this rebuild was done some years ago. Timing belts say "Three Star" brand, which seems like an older brand. Head gasket are definitely not Felpro perma-torque. All signs say that a re-torque of heads will be needed after installing engine into Loyale and running up to temp. Doing a re-torque while engine is in this car is not a fun task. PLAN B- Since engine is not yet installed - can simply re-do using Felpro perma torque gaskets and be done with it.
	4WD? Mine is FWD. When I drive my 97 Honda Accord for a while it seems more cushy than the Loyale Wagon. But when I drive the Loyale again it is always a pleasure somehow. There is more feel of the road when driving the Loyale. And it has just enough power for me. Say, do you have that book "How to Keep Your Subaru Alive"? I have it on pdf.
	idosubaru EA82 now sitting solidly on a shelf in my garage. No intake . No exhaust. No water. No oil. Assembly lube still intact and all openings securely covered by heavy duty aluminum foil tape or plastic plugs. Oil pan is on. Timing belts are on. There is no way to verify how main bearings, piston/cyl, case alignment factors will play out until started up. My thoughts are if these head gaskets need a re-torque after running up to temp. I put Felpro Permatorque head gaskets [did the work myself] on my Loyale eleven years ago with no problems since. Felpro were blue in color and these are grey metal. I don't mind the time it takes for the re-torque process, but it will drive me crazy if the engine is in the car with that cramped work space. I will be much happier to just install Felpro permatorque gaskets and be done with it. But the thought of undoing another's work bothers me a little. Especially when they did it with more knowledge and experience than I have. A bit meta-physical there, I know.
				Check engine light help
rickyhils replied to DanielsHardLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
DanielsHardLoyale Maybe I have a fix for your problem if it is the same problem I had with my 1991 Loyale. If cel comes on and shows code 34 then it might be a bad IC chip inside the ECM module. I replaced that chip in my car and cel went away. Been two years now with no cel. There is a reference voltage that the egr solenoid needs from the ECM in order to give the AOK to the ECM. I checked reference voltage at egr solenoid and it was way below normal, showing 6 or 7 volts when it should have read 11 volts. The first IC in the ECM is where the egr solenoid will trace to. Remove ECM box and open it up. It is a 10 pin IC that handles routing. It was 5 ICs for 10 buck [China] . Chip is dead easy to desolder and swap out as it is NOT SMD. If you get intermittent cel w code 34 , don't waste 40 bucks on another eger solenoid. Contact me and I'll send you one of my extra chips for cost of mailing. -
	Yeah. Throw it in and run it. Even if engine self destructs I can still walk away with new TB parts, good cams, and maybe good heads. Will use orig specified oil and stay close to home when running it under some load. Your 2 cars turbo? My Loyale [FWD, SPFI, non turbo] has been good to me past 17 years and I look forward to maybe this latest engine as being a good thing. Or close, as nothing like original factory build quality. Anyway, the other EA82 [under powered as it is] will be resealed and ready to swap back in.
	My situation is of some relevance. There is lots to read here. Have just acquired an EA82 engine. (Scroll down for my question.) It was rebuilt some years ago and it has never yet been fired up as only assembly lube is visible. [No oil added yet.] History [quality] of rebuild is unknown. Came with a box of parts. Intake manifold for a carb [carb was missing], a Subaru alternator, new TB kit using MBL Three Star belts [good] . I removed the oil pan to maybe learn more about the rebuild and the pan bolt torque was appropriate. [not over torqued]. Turning the 22mm crank bolt showed smooth operation of bottom end. And both the new cork pan gasket and the oil filter had a very light layer of assembly lube on them, so it looks like the rebuilder knew some things. It is evident that the case was split open as a tough grey rubbery sealant is slightly visible along the join seam. A clean job but I would guess not a factory Subaru sealant. [So bottom end was addressed]. Cam towers show the same grey sealant and cam shaft bearings show a bit of assembly lube oozing out [good]. Valve covers have new gaskets and 9 new bolt grommet. The new gaskets [still pliable] have NO sealant used. [also good]. Oil pump has a "D 6 Y 22" marking on it, looks to be perhaps new, and not sure if it is Atsugi or Beck-Arnely made. So, for $100 bucks this could not be passed up. Either it will run like new or it will suffer from poor piston/cyl walls, wrong main bearing tolerances, misaligned case halves[ most likely] or ??? HERE ARE TWO QUESTIONS- The corners of the head gaskets show a slight squeeze out of a dark brown or bronze sealant. Is that a reasonable choice used by some? Maybe those tiny dabs of gasket sealant [look like Permatex product] were added at the far corners because of the water jackets that are nearby. While engine is out I can easily enough redo both head gaskets using Felpro permatorque if unsure. Or, might another safe bet be to install and run the engine up to temp and then re-torque "unknown" head gaskets?
				Dim Passenger Headlight
rickyhils replied to loyalematt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1991 Loyale. Try swapping out the relays under the dash. There are three relay canisters that are same part #. I was working on a heater fan problem and checking under dash for heater relay. So I swapped them out [same part#] to check heater motor. Anyway, one of the swaps gave similar right headlight behavior.
