Everything posted by Setright
Idle it like that until it gets warm enough to turn the fans on. It'll overflow but any trapped air will be expelled when the fan comes on. ' Waiting for the fan means you can be sure the thermostat has opened and isn't holding onto any air bubbles. Install the cap, fill overflow to FULL mark. Presto, air free cooling system. Drive for a few weeks, open rad cap. If the coolant doesn't reach up the spout, then you have some sort of issue.
Thermostats???
Setright replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You won't go wrong with a Genuine thermostat. Some aftermarket replacement parts might be just as good, but it's a big risk for a small saving. The classic symptom of a non-genuine thermostat is over cooling though. The springs tend to be too weak to hold the coolant back. -
Legacy Sapporo
Setright replied to nixon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Power should be 136bhp. Extra toys might include electric headlamp height adjustment, electric fold-in wing mirrors. Momo steering wheel.. NOt sure about that though. In fact I find it odd that the Japanese local market had a 2.2 at all. They had a DOHC 2.0 with 150bhp. -
Factory headers aren't all that bad. And with the turbo pulling gases out, the gains here aren't going to be massive. Better to look behind the turbo, especially the flange that looks nice and wide from outside, but is really just a small pipe in a big flange. A good turbo-back system can give you 25-30 bhp more along with less lag.
For sure you need to take it back and have those faults documented. So much easier to complain to higher authorities if you have a "paper trail". Oil burning on a brand new engine isn't that strange, but I wouldn't expect a non-turbo to eat that much. My 2.5 Turbo drank 2quarts within the first 3k miles, and now seems to have settled down.
Yep, another vote for the "they all do that, sir!" line. I have long term experience with three Subes, one of them a turbo, and they all have a slightly erratic lump at idle. Most of the time smooth as an androids bottom, but occasionally there's a shake. If you don't feel the engine mounts are being stressed and the engine is bucking about, relax and enjoy the ride!
Yes, try to read the codes before guessing anymore :-) Sometimes the ECU won't store a code, but we'll cross that bridge... Is there any relation to revs and speed, would CEL come on at the same revs in a higher/lower gear? Or is 100km/h the cause. Off hand it sounds like a fuel delivery problem. Perhaps the fuel pump is giving up and the mixture is going lean.
