Everything posted by Setright
I'm not entirely sure where we're talking about either. Any pictures? Or reference pictures on the net you could link to? Off hand, welding should be done off the car. Access is far better and there's no risk of fire. Of course, pullin the manifold off can pose new problems. Like bolts and nuts rusted together and pulling the bolts out of the cylinders and stripping the thread..
Nipper, that's not a sure-fire way. If you remove the rad cap, bubbles will come out no matter what. The lack of pressure in the cooling system will allow local boiling and send gas pockets out the rad cap hole. As the car idles coolant will slowly overflow the open hole and when the fans come on and the thermostat opens the coolant level will drop back. Simply because the fans cool the fluid and it contracts a tiny bit. I do however agree fully with your first suggestion : Radiator is not functioning properly anymore. Clogged or missing fins, it needs replacement. (Genuine thermstat is also a good idea).
When you mount the rad cap, there will be a delay before the cooling system builds enough pressure to push expanding fluid past the rad cap. Once it does, it WILL cause bubbles in the tank because the hose connecting them is empty to start with. But why did it happen after you switched off the engine? Fit a new, genuine cap before going further.
Low pedal is not related to brake pad wear. The brake fluid needs to be replaced to help that problem. Every 20-30k miles. I am a big Mintex fan when it comes to pads. Try www.mintex.co.uk and use the catalogue to locate the part number. Mintex may go under a different name Stateside. The caliper will swing upward and give you access to the pads. Remove the 14mm bolt at the bottom and you'll see what I mean.
Before you throw bundles of money at at, try this: Buy a new radiator cap, genuine part please, and remove the old one. Top off, start the engine and idle it until the thermostat opens - the coolant level in the rad neck will drop as it starts to circulate. Top off again, mount the new rad cap, fill expansion bottle to FULL mark. Keep a watchful eye on it. If it continues to mysteriously overheat, plan on replacing the head gaskets. Don't start going down the same road most of us did: New radiator, new hoses, new thermostat, new waterpump...
Most likely would be a failing wheel bearing - or two. The rear bearings are the main weak-link on that generation of Forester/Impreza. Apart from needing a hyrdraulic press to remove the bearing from the hub, it's not a complicated job. But whether you DIY it or not, the rear bearings the place to start.
5% ethanol is now standard in my neighboring country, Sweden. I recorded my absolute best mileage ever of 14km/l on a long trip over there. Perhaps there's a connection? (They also have SAAB's designed to run on 85% ethanol.) The mileage increase is okay, but I don't like the increase in light-brown ash deposits on my spark plugs :-\
