Everything posted by Setright
Whoa there! That center nut holds the drive axle into the hub, that DOES NOT need to come off! You need to remove the wheel, then remove the lower caliper sliding bolt, rotate the caliper up and hold it while you remove the pads. Then swing it back down and put the bolt in loosely. Now, at the back of the caliper mount there are two bolts that need to come out and give you clearance to lift the rotor off. The rotor is not bolted in, the wheels hold them in place. I would strongly recommend Mintex brake pads. The standard pad ("Red box") has better performance than Subaru's own pad, and won't dust more. Be sure to refit the black pad shim, that's the one that stops squeal.
Yes, check to make sure you don't just have a leak from the auto trans fluid cooling system. Then, remove and flush the OF tank. Fill it to the FULL mark with fresh coolant and keep a watchful eye on the temp gauge and coolant level. Even if the you-know-what is leaking, keeping the coolant topped up will keep you runnning for a long time!
The main thing to research is the cost of the tyres you intend to run. I run 15 inch rims because the tyres cost HALF the price of 17 inch tyres. You need to correlate that to your expected mileage. 17 inch tyres will also be more susceptible to damage over rough roads - the carcass can easily be deformed by a hole in the road. I would choose 16 inches :-)
That's the much talked about "piston slap". The pistons have been shortened to reduce internal friction, and since all pistons are oval in shape until they heat up, this design will slap/tick/rattle. Nothing to worry about. A lot of Honda engines do this too - even at idle! 5W-30 is what I am using for winter, and it's working fine in terms of slap. 0W-30 or 0W-40 is even thinner and the slapping can sound slightly violent with those oil types. For summer I run 5W-50.
Noisy Fan
Setright replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If the Dash is like my 2000 Impreza, I don't think you need to remove the glovebox. Just get under there with a short screwdriver...the motor is not hidden. -
Leave the ignition system, if it ain't broken.... The coolant hoses are a good idea though, including those that feed the cabin heater. These harden and lose their ability to seal and this can lead to overheating and subsequent damage. If you decide to replace the hoses, make sure you search this board for the tips to purging the air from the boxer engine. Most important is filling slowly through the upper hose and then idling with the rad cap off until the fan starts. Top off, close rad cap.
