Everything posted by Setright
Hard shifting into second
Setright replied to Erockanderson's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHOGWASH! Synpower which covers GL3, 4, and 5 is the best of all. Castrol Syntorq is good too.
Setright replied to Erockanderson's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you mean Valvoline "Synpower", then I think you need consider seriously worn synchro rings on second gear. Synpower is the best oil to use in these Sube gearboxes, so if you have problems then it's not your choice of oil. What speed are you selecting 2nd at? Any chance of helping it along with a bit of double de-clutch?
stinky cabin
Setright replied to debzbru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe cabin pollen/dust filter will NOT stop the smell.
how hard is to do impreza timing belt?
Setright replied to rainbow123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYEah, it IS more lengthy than on a Toyo-Honda. As mentioned above, you could do it with the rad in place, but it will make the job a lot harder than need be. Rad-in is only for seasoned Sube mechs with the correct proprietary tools.
Idle question ?
Setright replied to gsp4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds normal to me, all the autos that I have driven have been like that. Even the Germans.
Very High RPM's after Timing belt replacement
Setright replied to Raindog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs it possible that the mechanic liked your wheels so much that he stole them? And fitted smaller ones on your car?
The UNOFFICIAL Impreza Shakedown Thread
Ok, my first time was 1.14 I'll be back
Brief idle surge on '06 Forester when "cold"
Setright replied to denversprings's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds ok to me. My Impreza with a 2.0 liter engine will behave in the same way sometimes. The mixture is rich because the engine is well below operating temp, and that mixture means high idle speed, and that the revs will drop more slowly. The ECU is trying to keep the engine from stalling. If you feather the clutch up and leave the accelerator untouched when you reverse out of the drive, I bet it won't do this.
Setright replied to Raindog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm, does sound like a slipping clutch. However, don't worry about the engine revs, 3000rpm is nothing. I cruise my Impreza at a legal 80 mph and the gearing puts me at 3500rpm. I regularly take the engine into 5000-6000 range when accelerating. No worries.
Purge Air from Radiator
Setright replied to YFC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy Imp doesn't. However, it does have that bulge around where the rad cap and top hose mount on the radiator. Reckon Subaru has put that bulge there to collect the air. Highest point in the system..
Tork Steer-Forrester
Setright replied to murphsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the tyre pressures and the wheel alignment. Torque steer should not be an issue - unless you have the 2.5 turbo, which could pull a bit on boost.
An STI for "grownups"?
Setright replied to dpoppeli's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, yes, yes, less screamy "Q-cars" are better for some people. Did you consider that a 3.0 Liter Legacy would play that roll very well indeed? No loud graphics or spoilers, just smooth torque to surprise the ricers ;-)
Best Oil Filter!
Setright replied to 69800's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"Oil/water heat exchanger"? BUilt into the block or what?
Ignition problems
Setright replied to RobJ426's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, Genuine Subaru ingition cables are good and offer very consistent quality. Most Subaru parts do, that's why the cars drive so well and last so long!
Growling rear end, 01 Forrester
Setright replied to Brick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI vote bearing too. They are a relative weak part .
impreza shaking when i drive
Setright replied to ssphish's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStart by looking at the spark plugs. Then the cables.
Which Air Filter
Setright replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChip, noise and emission regulations limit the factory options. If oiled gauze is so bad, why does STi produce one? And many Subaru's have CAI stock. The older models draw air from the fender, interim models from behind the headlight (dubious CAI), and newer models suck from the bonnet/hood lip.
Legacy Suspension upgrade
Setright replied to Kcwiro's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDampers/shocks will not reduce roll and pitch very much, but only slow it down. This will of course make the car easier to control. Lower, stiffer springs will give a more direct feel to the steering and maybe balance the front/rear better for less understeer. I would suggest sticking with the stock springs since you need the ride height. AGX's and an alignment with a bit more camber up front will work wonders for the handling. Stock camber is 0.0 front and -1.0 rear. If you adjust the front camber to -0.5 you should find that understeer is a thing of the past. (But be careful under braking, the tail will become a little more lively.) Works for me ;-)
Handling woes - wandering over the road
Setright replied to destey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX???Nipper??? The dampers/shocks are probably worn out. Even though the car doesn't bounce, they are not working optimally anymore. Replacing all four will improve the handling a great deal. Steering rack/servo might be getting tired. You should have an alignment done. Person doing the alignment should be skilled enough to diagnose the steering. Some of the alignment measurements aren't adjustable, but are references to trace down worn components. New shocks will require an alignment, so you might want to combine things.
Convince me why I should buy Subaru vs. Toyota
Setright replied to Pinny's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn terms of reliability there isn't much to recommend one over the other. Both Toyota and Subaru make very reliable cars. Some models from both companies have had weaknessess, but not nearly as frequent as other brands. (Apart maybe from Honda and Mazda) If you want AWD, Subaru is the king though. I would rate the Outback as your best choice.
Why not change oil when cold?
Setright replied to TheBrian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhy not when cold? I have often wondered a bit too. It's true that more oil would be in the pan when cold, but I think that warm oil would carry out more sludge/particles because it would be in suspension. The particles of soot and ash that may be present in the oil would tend to sink to the bottom of the oil pan overnight and not get drained out.
How much damage did I do to my clutch?
Setright replied to clementson's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may have shortened the service life, but it's not enough to lose sleep over. If it doesn't slip in the shift from 2nd to 3rd your clutch lining is still OK.
Gas mileage improvement with K&N air filter?
Setright replied to go_mo_bryth's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOr be patient, the ECU will learn in due course.
Who here runs heavier motor oil?
Setright replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell folks, I have just drained my 6k mile old M1 5W-50 and refilled with M1 5W-30 for the winter. I'll be back with feedback, rest assured.
Setright replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI will avoid getting into the present debate, but would like to clarify what those numbers on the oil bottles mean: "5W-30" The 5W refers to the low temperature "pumpability", how cold can the oil be before turning "solid". It doesn't mean that the oil has an SAE grade 5 at a specific low temperature. The oil is much thicker at low temps. These oils ALL thin out as temperature increases. The 30 is the SAE grade of viscosity at 100 degrees centigrade. BOTH of these numbers are classifications and are based on ranges of values. This means that two oils with 5W-30 on the label can have different viscosities. They just fall under the same category. So, I recommend reading the tech data sheets if you are serious about selecting oils. A slap avoiding oil will measure 100-130 Centistokes at 40 degrees C.
