Everything posted by 89Ru
Zero compression in cylinder 3 in 2008 Outback 2.5L wagon
236k miles. Both heads rebuilt around 180k after we got it for cheap (tbelt break). Engine was replaced by previous owner, history not known. Sudden onset of running bad. May or may not have been some winter joyriding. Wondering about oil starvation? Runs very rough, engine is shaking, stalling at idle. cylinder misfire codes are not new. Able to limp home. At the end look for the cam wobble Tried a few quick fixes but no major improvement. The timing belt was off one tooth on the pass side cam. Reset the timing and runs better but still shaking, low power and still stalls randomly. Oil puddling on ground underneath on pass side from tbelt cover between oil pump and oil filter. Replaced the cam seal but probably also cam seal leak. CEL flashing intermittently, probably misfires. New Diamond coil (existing diamond coil didn't look bad at all). No improvement. Changed plug wires to new NGK (from existing NGK). New NGK plugs. FR5AP-11. A bit of chunky carbon on one plug (either 1 or 3) and #4 was loose possibly causing low compression and shaking. Now running with naked timing belt so everything is visible. Passenger side cam sprocket is backing off the cam! Able to turn the timing belt with a socket on the cam bolt, but it doesn't feel loose at all. Cam sprocket is wobbling while running. It likely partially backed off the keyway. So many questions. Did the cam sprocket rotate on the cam? I just don't see how this would be possible. Cam oil seal is compromised and oil is puddling below the cam. Oil coating the belt and flinging around the engine bay. Is the cam itself out of round? This seems impossible. Maybe the cam journals are gouged out. Car is knocking. Bottom end problems? Finally got the car on a trailer after sitting in a parking lot up in Michigan for a bit. Back in the garage. Just now checking compression after finding a new ride for the daughter, of course a Subaru. Cylinder compression is good on 1, 2 and 4 (220, 205, 200) but ZERO on cyl 3. Plugs look ok, not oily. Will pull the engine and check out the head. Probably the valves got grenaded on #3 or worse. Car hit a deer in 2024, needing a bunch of sheet metal replaced in the front. Tbelt cover was cracked. Wondering if the cam sprocket took an impact that was missed.
2017 Outback 3.6R power liftgate fix
New outback (to me) with non functioning power liftgate Liftgate just beeps but won't open when pressing the open button on the fob. Tried the reset trick by disconnecting the battery and shorting the battery leads together to reset the system, didn't work. Toyed with the option of converting to manual liftgate cylinders but we still need a functioning latch. The manual liftgate latch will not fit in the stock powered liftgate actuator position (non compatible mechanically). Also tried bypassing the touch sensors in the liftgate but this did not help. Disconnected the touch sensor connectors (two pin, left and right) and checked continuity across the sensors. Opening the liftgate (relieves pressure on the touch sensors) and both sensors should read 10k ohms. Remove the left sided lower touch sensor (two screws and a plastic plunge keeper that needs to be popped out). The lower touch sensor has a mating connector for the upper touch sensor, so both are daisy chained together. The upper touch sensor does not come out easily, apparently it is glued in place and if removed, needs to be replaced (according to the FSM) May spoof the system with a 10k ohm resistor across both touch sensor connectors. This is just for a test, as operating in this mode is risking someone (or something) getting trapped between the liftgate and the body) BOJACK 1000 Pcs 25 Values Resistor Kit 1 Ohm-1M Ohm with 5% 1/2W Carbon Film Resistors Assortment Amazon $15 A new liftgate actuator wasn't in the budget so opted to troubleshoot below. With parts and test equipment still came out ahead. Latch and Actuator Tailgate (power Rear Gate) Part Number: 63032AL000 $350 Remove the plastic access cover on the liftgate to show the innards on power up. Video shows the system searching for the home position and not finding it and defaulting to the liftgate latch open position. As a result, the system 'searches' for home, and not finding it, may leave the system in another state, such as unlatched Video of liftgate actuator The green 'sector' limit switch (with the lever pressed in, in closed position) defines the home position but if this switch is failing the system won't work. Schematic of power supply and switches One switch (OFF ON) is used to bump power on and off. The other switch (OPEN CLOSE) allows reversing the polarity of the motor leads and therefore motor direction. I only had two position switches DPST on hand so this is what I used. A single momentary DPST switch would work better, allowing momentary ON/OPEN ON/CLOSE with the default position OFF (center). Rigging an external power supply at 12 volts on current limit (guessed at 3 amps) with manual switches to simulate the battery and control module allows actuating the liftgate open (fully counterclockwise on the gear) and closed (fully clockwise) Power supply doesn't have to be fancy, just the basics but this is what was available (don't need USB) DC Power Supply Variable, 0-32V 0-10A Switching Bench Power Supply with 20W USB & Type-C Quick-Charge, Encoder Coarse & Fine Adjustment Knob, Output Switch, 4-Digit LED Display - SPS-3010V https://www.amazon.com/dp/B0DDPVDWPZ?ref_=ppx_hzod_title_dt_b_fed_asin_title_0_0 Video of bench power supply testing Replacing the power liftgate switch. Drilled out the "sector" limit switch aluminum post using a 3/16" bit. The bit slid around requiring several position changes and finally tearing off the remaining bit with linemans pliers. Then used the pliers to shear the post leaving the aluminum nub behind which popped out easily. Now we have a 0.24" thick switch body and a 0.07" hole that needs to be drilled out to 1/8" to allow a fastener to secure the new switch. Have to remove the motor assembly (3 bolts) to allow the M3 fastener to fit. M3x12mm hex bolt is 0.118" which should just fit inside the mounting hole of the switch (0.12") 2240PCS Metric Screw Assortment,M2-M5 Metric Screw Kit, Hex Socket Metric Bolts, Metric Machine Screws 12.9 Grade Alloy Steel,Black Zinc Plated,Free Allen Head Wrench Amazon $24 New limit switch. Panasonic ABJ363861 SWITCH SNAP ACTION SPST-NO 0.1A 125V $16 shipped from DigiKey Used solder sleeve to hook it up. Replacing the limit switch allows the system to detect the home position with the orange pawl on the gear engaging the green limit switch lever and closing the limit switch contacts. New limit switch Initial position of the actuator gear was max clockwise after bench test (which is where the system had left it after the failed initialization due to the bad switch). This position caused two issues The boot sequence no longer ran the initialization the same The system just beeped three times. No motor activity Why isn't known The manual unlock lever doesn't work in this position since the actuator lever is forcing the latch into the lock position Used the power supply and switches to run the actuator gear counterclockwise just enough to be able to manually open the latch Cycling the system power (battery disconnect) boots the system into a good state and the working limit switch is able to allow the system to find home, which consists of the system resting state with the limit switch closed (limit lever snapped shut) Test after resetting the system after reconnecting the battery This is the first powered liftgate opening test after replacing the limit switch Video Hope this helps. Bonus points if you have read this far down and are still awake.
2006 3.0R engine opinions wanted
89Ru replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVVT will flag codes ending up in limp mode. The mechanism is kind of cool if you end up diving into the valve cover. Yes the oil pressure sensors leak and make a mess on top of the engine, but not expensive or hard to replace. the 3.0 h6 is a great engine presume the 3.0r is the same. we're running a jdm h6 replaced at 300k now into 400k miles on the 02 h6 outback. lots of hex bolts on the timing cover. had fuel leaks on the rails/injectors just replaced orings/seals/lines/dampeners dang expensive. had a hard steering line oring fail on the rack but what do you expect after 25 years.
alternatives to opposedforces?
89Ru replied to turboguzzi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://opposedforces.com/parts/ back online. It goes out periodically.
2007 Outback wagon rear ended, totaled
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGoing to try the cover and the bumper too if it will fit. The taillight is only 3/8" pushed in past the hatch on the left side. The right side taillight is flush with the hatch. Maybe try hooking into the trailer hitch but how to mimic the right amount of force that bent it inwards.
07 outback manual wagon base model, 2.5L, 148k miles. Hit from behind on left side while stopped at a light. Crushed the aluminum bumper on the left. Damaged the trailer hitch and the left side frame rail a bit. Hatch opens and closes but there is a slight offset in the latch. With this amount of damage the car has been totaled. 2nd totaled car for us in the past two months. Car runs and drives ok. On impact, the car was pushed from behind into the next car ahead. No apparent front end body damage but the PS pump sprung a leak which has been fixed (new return side o-ring). The impact sheared a muffler hanger on each side, replaced with spares. https://photos.app.goo.gl/SusTyPs8RqCmTwBA8 How repairable (and necessary) is the frame rail and rear panel under the bumper? It appears that subaru does not sell any body panels for the back end / tire well / frame rail. I could grab an aluminum bumper and cover easily from a parts yard but doubt that it will easily bolt up without replacing or unbending sheet metal or cutting new holes into the bumper. The accident happened in TN so there will be issues with a salvage title / possible re-inspection. Where to get parts? Not sure I'm ready to buy a parts car and have it towed or if this job is even conducive to harvesting the needed body panels. Just learned from my recent front end deer crash that my neighbor is keen to weld, and I'm kind of interested in welding all of a sudden given my track record with totaled cars.
Outback vs. deer
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe accident was out of state and my insurance company said that it wouldn't be reportable to Tennessee. So I'm hoping that I don't need a salvage title and all that headache. Car is in southern Michigan right now so that could be a mess.
Outback vs. deer
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah I had initially pulled the radiator support forward by hand just to get it back on the road. It's pretty flimsy. I ended up deciding to weld new rad support figuring that there was probably some lateral deviation from all the twisting and crimping, and the hood latch would be wonky.
Outback vs. deer
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCar is done! Kept it two tone for the win. Purchased new sheet metal including radiator support, center hood stay, and right/left hand radiator panels for about $160. These come painted (black) from Subaru. Or just cut them out of a donor. I counted just over 20 spot welds for the total weld job. Didn't have to completely remove the fenders to access the weld points for the radiator support, just moved them aside. Removing the bent metal wasn't hard using a 3/8" spot welder hole saw removal tool and a drill motor to punch through the spot welds. For the rebuild, these welds are beyond the harbor freight 240V "pinch" spot welder in my opinion due to the lower section essentially welding to a tube. My neighbor has a HF MIG welder that did an excellent job welding the new metal in place. Just cover the whole engine first with fiberglass cloth to avoid hot slag melting the harness. Before removing any metal I marked the outline of the pieces to help line things up. Having the headlights in place helped line up the two radiator panels (actually they should be called condenser panels) prior to welding. The hood latch was aligned with the hood and clamped prior to welding. After welding, put the condenser/radiator/headlights/bumper/bumper cover back on.
no start weirdness a month after front end impact
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX08 running the 07 pump doing fine after 500 miles. 08 stock pump failure could be coincidence/foil scrap/or running without alt belt, which is probably just general good sense to avoid in the future. 07 running 08 pump also fine after driving around town for a few days.
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks. Yes, codes cleared after reset. Swapped out the stock fuel pump from my 07. Started right up. Runs without cutting out. There's a fuel temp sensor in the fuel pump, flagged a code when I disconnected the cable. The 07 pump doesn't have the foil scrap. Going to remove it and give the suspect 08 pump a go in the 07. Oddly enough the three little plastic feet on the 08 pump were stuck to the bottom of the gas tank.
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's a pic of the strange piece of foil on the fuel pump https://imgur.com/gallery/vDzDdMQ/comment/2436129451 And another couple https://imgur.com/gallery/vDzDdMQ/comment/2436129563 https://imgur.com/gallery/vDzDdMQ/comment/2436130359
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXQuick look doesn't see any piping damage. Pulled out the MAF and looks intact. Intake is still aluminum for 2008. Still keeping this in mind as the only times it has started is with the MAF connector off. I continue to find bits of shrapnel in the engine bay, grill plastic and metal fibers from what is left of the alternator belt.
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe fuel gauge tracks upwards with small amounts of added fuel, 1 gallon up a little, two gallons, up a little more than before. Unfortunately starting isn't reliable even with more fuel. Still cranks a lot, sputters. If it starts it dies a few minutes afterwards. So I'm now suspecting fuel pump assembly. All this started after I pulled off the alt belt, so voltage to the fuel pump is less. Maybe less voltage is causing a problem, higher current, overheating maybe, browning out. I have a bit of front end work left to fix from the deer damage so the belt remains off for convenience. So I pulled the fuel pump out. It looks to be OEM. Fuel in the tank is definitely not 3 gallons (what I have added in by hand). Fuel gauge is now reading just over half a tank and there is a lot of gas in the tank which probably agrees with the reported level, just a guess. Anyone know how this generation of OEM fuel pumps typically fail? There is a little sort of loose piece of foil in the lower plastic plumbing of the pump housing. Not sure if that is a failure point. Might swap my 2007 outback fuel pump just to compare if they are compatible.
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUhh yes actually! Low tank. Put about a gallon in and after a few ignition cycles it started up. Runs fine without accessory belts, MAF connector, etc. Stalled when I goosed the throttle but probably because of all the codes, etc. Weird since the gauge is not low and the fuel light isn't lit. So, dive into the fuel level mechanism inside the tank?
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes! But only after I added a bit of gas. Ha! Got the same CEL codes after disconnecting the MAF (air temp P0113, MAF P0112) so its not a sensor after all.
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be. Didn't start again this morning. Fuel gauge just over 1/4 tank. Going to check fuses and see if I can hear the fuel pump kick on when I turn the key. Car is on a flat surface. Will try loosening the fuel cap.
2008 outback wagon 2.5L auto 218k miles. Hit a deer a month ago and still working on getting the car back in shape. Damage mainly to radiator (still functional), condenser (also functional). Car was running fine and has logged over 400 miles since the accident even with the damage (mostly highway just limping home) and a couple of trips around town for repair work (drained the r134, no I'm not running the hvac). Today I took off both accessory belts, the crank pulley (bumped the starter x1), and the cracked timing belt covers from the deer impact. Was doing some topside work (power steering connector cracked) and had taken off the MAF connector to remove the airbox. Nothing too complicated. Reconnected the MAF and drove a mile without any accessory belts or TB covers. Air guide shattered at the deer impact so have been running without it, just a wide open slot with an intact air filter in the filter box. Yes the dash battery light is on but just driving a mile not a big deal. Car had been starting just fine. Battery is fairly new. After a right turn, car died and would not start. Just cranks, strong cranking and sounds like good compression. Someone stops to help and gives me a battery charge with one of those electronic fast chargers. Doesn't start. I checked the engine codes and saw a few, but forgot to screenshot it. What I remember is a "heater circuit" and "air temp" code. Plus a MAF code probably from disconnecting the MAF connector on the air box. Its about 60 degrees here outside today. Car wasn't totally warmed up after driving a mile but probably close. Thought maybe the ECU was confused about several things, the weird pressures from not having that plastic air guide. Running without any headlights or bumper or grill so there's nothing buffering the air flow into the MAF. So I tried resetting it by disconnecting the battery for about 5 minutes. Still wouldn't start. Getting 11.5 volts on the battery during cranking which I thought was enough, but tried jumping it anyway. Still no start. Outside air temp sensor could be damaged, is unprotected and maybe got hit by the deer, but it doesn't look damaged. Will try swapping this out. Towed the car home using the stock front end tow point in neutral going about 20 mph or less, about a mile, after reading the owner's manual about towing. No new codes after a few start attempts after the battery disconnect. In fact all the codes got reset. Going to try again in the morning after the car cools down.
Outback vs. deer
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttps://imgur.com/gallery/vDzDdMQ/comment/2433311575 Found a donor, grabbed most of above, after pic.Not sure about getting it painted to match or not. Might keep it two tone.
Outback vs. deer
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood to know. Have a friend who can weld if it comes to that.
Outback vs. deer
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAwesome, those kangaroos pack a punch eh. Engine crossmember and strut towers good.
Outback vs. deer
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGoing to try the come-a-along method first. Rad support is mangled, maybe too far gone. Thanks
Outback vs. deer
89Ru replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttps://imgur.com/a/vDzDdMQ
Outback vs. deer
2008 outback 2.5L auto, 217k. Car is totaled by insurance. As I have a lot invested in this car I feel the value is worth more than its presently calculated. Not doing a job like this before, just how fixable is this car? Plan is to remove the bumper and replace the metal framework and broken bits (headlight(s), radiator, condenser). Aside from the obvious damage below, what pitfalls if any are there? Early AM drive at highway speeds, was able to slow a bit but still much carnage. Deer stumbled and fell prior to impact, otherwise it might have gone through the windshield. Unavoidable front end impact to large buck, torpedoing the grill and inwards. No airbags or significant bumper damage. Significant hood damage. Radiator and condenser caved inwards. Lots of plastic shrapnel: radiator cooling fan blades/housing broken/Air guide smashed/t-belt cover punched. T-belt appears intact. No obvious fluid leaks. Alt/Bat light on. No power steering. Car didn't cut out. No CEL. Car able to drive away a few miles from impact site to nearby town which apparently is the classic car capital of the world incidentally. Not verified. Kind of impressed that the car is running. Was able to pull back the crossmember and place a spare alt belt, getting up to operational status fairly quickly. No apparent mixing of coolant and transmission fluid (as the trans fluid looks clear, and not suspecting internal rad damage to the transmission cooler portion). I'll try to post pics.
2011 Impreza Overheat
89Ru replied to thesmokinggasket's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou get heat in the cabin on warmup or is it delayed or just cold? Bubbles gurgling in the dash? Exhaust gas testing is unreliable for head gasket issues.
