Everything posted by avk
Two Things - Roof Rails and Cup Holder
avk replied to The Professor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't know for sure if 2d gen. roof rails would fit 1st gen. roof. There were roof rails for gen. 1 in Japan and Europe, but AFAIK they are not available as spare parts. From dealers in UK, you can order a roof rack with "feet" that attach to the same factory mounts in the roof channels that are used with USDM "port installed" rack. The cross-bars are removable. With shipping it would run something over $200. A console cupholder is supposedly available from Husco as a special order, it fits on the optional storage-box console.
2004 Illuminated Ignition Ring
avk replied to Evanism's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe ring and the bulb holder are separate parts that can be removed after the column covers are off. Don't if know lighted and non-lighted lock have the same dimensions, but on Impreza even 1st gen. locks have a trim bezel which looks like it has a spot where the bulb would attach.
Another Coolant Odor
avk replied to Soup's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt might be simply a common type of radiator failure, although it usually happens with older cars. The seal in the crimp joint leaks upon start-up, when the thermostat is closed so the rad is still cold but pressure is already building up. When the rad. warms up, the seal expands and closes the leak.
what wires are for the VSS, vehicle speed sensor
avk replied to needbigtruck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you consider a factory cruise control kit? It should be still available for a '99. Costs more than Audiovox but all connections are simply by plugging in, and the parts are so much more solid.
Spark Plugs Revisited
avk replied to PAezb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey did make them! http://www.theodoregray.com/PeriodicTable/Elements/084/
avk replied to PAezb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSmoke detectors use Americium, the half-life decay time for Polonium is 138.4 days.
98 Forester timing belt replacement
avk replied to Curtis1955's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXExcept for '96, maybe that's what Myles has?
Front bearing inner oil seal install question
avk replied to frag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe the seal inserts into its bore from the axle side and the CV housing itself is what holds it in place. Not sure what the green coating is made of, but inner joint housings have it too. My guess would be paint.
abs pump running continuously - key off
avk replied to littlefish's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's one of the two relays under the cover next to the ABS hydro unit. Even from a dealer it shouldn't be more than $50, and the labor is just to pull the old one out and plug the new one in.
How do I get a third party mechanic to replace head gaskets under Subaru's warranty?
avk replied to remarcable's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOrdinarily, only a dealer can file a claim under warranty, but maybe there is some sort of "emergency" provision that allows you to use a 3d party and then submit their bill. Extended warranties from Subaru include this, but not sure about the regular powertrain warranty. And it's about time SOA came up with some sort of goodwill warranty for the headgasket problem, even Ford did that with their 3.8.
Aux panel, mystery wires???
avk replied to 1ABAJA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's for cruise. The plug for actuator under the hood is there, too. There was no fog wiring on '93-'96 (but factory add-on kit came with what's needed). The defrost button is a big one to the left of tach.
Attn Avk
avk replied to frag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBecause the manual says so! Seriously, the purpose is to have minimal stress in the bushing when the car is at the normal height. The bushing is pressed into the arm and at the axis, attached to a stationary sleeve which is tightened by the bolt to the subframe mount. If the bolt is tightened with the wheel hanging down, the bushing will twist quite a bit when the suspension is loaded, and would stay that way. On upward travel of the arm, it would twist even more. My way to tighten the bolt was to turn as much possible with wheels on the ground, then when the sleeve is already tight, drive up on the ramps and turn some more.
ABS in 95 Legacy
avk replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChecked Joe Spitz's archives: according to him, ABS on FWD L was optional in combination with TCS while the standard brakes were rear drums w/o ABS.
avk replied to 1ABAJA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe connector is for cruise control.
ABS in 95 Legacy
avk replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn my '95 Imp., the ABS light comes on very briefly when you turn the key, not like the other lights. ABS was standard on '95 Legacy L, at least with AWD.
avk replied to littlefish's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFWIW there's a TSB about a sticking ABS motor relay, it says to replace the relay with an updated part if it's bad.
Genuine Subaru Coolant
avk replied to Chris4141's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru coolant is green but labelled "long-life". I am using it, it's a cheap insurance.
'95 Legacy heater fan control, hard to replace?
avk replied to Brettm57's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou likely need a to replace a resistor pack (or repair the old one if it's just cracked solder). That part is inserted into AC evaporator case, for cooling, and held by a flange with two screws. For access, remove the glove box and the reinforcement stamping behind, if present.
Auto Transmission Pan Gasket on 93 Impreza AWD???
avk replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe you can get an OE gasket mail-order, it's not an obsolete part.
avk replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI remember reading that the change from gasket to sealant was mid-year in 1995 and that if a gasket was used originally, it should be replaced with another gasket. I believe that was in another TSB, but not sure now. Also, I agree with the idea that the filter screen can catch only large debris and doesn't need to be replaced in normal operation.
CV Joints ???
avk replied to Chip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe tie rod doesn't have to be touched, the sway bar bolt is 12mm and not too tight.
CV Joints ???
avk replied to Chip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith the control arm method, you only need to remove one, front mount bolt (17 mm head and nut), plus the sway bar link bolt. There is enough play in the other bushing for the inner joint to clear the stub shaft. The caveats are that re-tightening must be performed with wheels on the ground, or at least on low ramps, and the nut is officially not reusable (mine is OK with blue Loctite). But same things already apply for the sway bar bushing bolt.
Oil leak from a ej18, from the distribuator.
avk replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalias: I meant the EJ engines discussed here, it had to do with differences between RH and LH heads. Not sure about 2.5l. He said he just wants to block the hole, maybe parts can be swapped from the bad engine?
avk replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEGR was only with AT, at least on 2.2l.
avk replied to wrxsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the distributor on the rear facing side of the right cylinder head, driven by the camshaft? If so, it can be replaced with a factory cover plate and O-ring.
