High Oil Pressure...
where have you heard oil filters that are put on too tight cause high oil pressure? i am an automotive technitian and have never heard of this. putting them on too tight just makes it frustrating the next time you gotta take it off. it can olso ruin the gasket causing a leak.
What fuel pump
its very easy to put a universal inline performance pump. like a walbro or similar brand. are you putting the EJ tranny in it, or planning to use the EA with adaptor plate?
Still no spark. Please help !!!
im not sure what others have told you to do, but a multi-meter and wiring diagram should do you well. have you traced your power wires/ ground wires at all? power from coil? does your rotor spin on the dizzy? just start at your plugs and keep moving till you get through you ignition system. sooner or later you will find where you are loosing power.
Clutch advise for RX trans
uummmmmm..... how is that tranny holding up at all? ticking time bomb. i would recommend converting to an ej trans sooner than later. but thats not what you asked right. if you wanna a daily driver clutch a stage 2 is a good middle ground. i personally like exedy because of their centrifugal wheights on the clutch plate splines. helps for high load torgue at higher rpms.
EJ22 Head Problem - CONFUSED!
zacyork replied to ericcroll's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou are going to want to pull the motor out to work on the heads. engine stand helps a lot for rebuild. i dont quite understand what you mean there is interference at TDC. did you replace the belt and turn the motor and it wont go pass TDC?
EA82T - EJ22 swap
you will also need to get slim electric fans. little room between pulleys and radiator. might also want to put a torque arm at the bell housing. i have heard they work fine without them though.
Build Thread: Angie's Monster Wagon
when the 4wd lever is all the way down is it front wheel drive or 4wd?
my 1986 rx turbo is a part time 4wd dual range. i thought the later 80s were all full time but maybe not. what doesnt make sense to me is that you said one click down the top of your 4wd lever is neutral. it should put you in 4HI . why dont you put the car on jacks and run it. that should tell you pretty fast what you have.
Timing Belt Idler Pulley Blew Up
zacyork replied to Thirdeye's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif it was my car i would start by replacing just that pulley and re-time the motor with old belt. see if it runs at all. if it runs ok you might have dodged the bullet. then go and replace the belt and other pulleys.
"ringing" goes away when a/c on
zacyork replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa mechanics stethescope would work. if you dont have access to one you can use some spare smaller coolant hose. plug one ear and put the hose in the other. put it next to your pulleys.
ej20 swap to ej20 turbo
you will need the crossmember from a turbo car as well.
Rear drum removal
zacyork replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi do believe its an 8mm or 10mm x 1.25
Battery Drain - 93 Loyale: It's Back
good luck ken. if you have any problems with doing this let me know and i can give you a step by step. i can always go outside and find out which wires are what on my EA for ya. im unemployed right now so i have nothing better to do:popcorn:
the fuel pump relay is above the ecu mounted on top of the steering column. you gotta unbolt the computer to get to it. you can bypass the relay temporarily to see if its bad. just take a paper clip and bend it into a u shape, unplug the relay and take the paperclip and put it into the wiring harness. one side power in and the other power out. there is usually schematic on the relay itself to show you which wire is power and which one goes to the pump. if there is no schematic you can always grab a wiring diagram online. now there are 2 relays right next to eachother where it is mounted but i dont remember which one is the fuel pump. good luck:headbang:
No start: crank, crank, crank, stop
+1 using a remote start would shed light on this definitely.
