86subaru
Everything posted by 86subaru
but are the power window motors all the same ? :wave:
ok thanks :wave:
on my 86 spfi a/t fwd sedan , the seats belts would not pull out at all , there are 2 springs at the bottom , one of mine fell off or broke off , i had a parts car which had good ones and replaced them , and the belts work good . :wave:
welcome up board , try to get past records , like the last time the timming belts were changed , hows the brakes feel , any major oil leaks, check the drive axles for spliting boots , are parts easy to get , and price , hope this helps :wave:
Spark plug changing, 90 Loyale w/ AC
86subaru replied to brus brother's topic in Old Gen.: 80's GL/DL/XT/Loyales...
this is the old generation board . use a spark plug socket , extision about a 6 in , i used ngk plugs, and 8mm wires , take one wire off at a time so you do not mix up the firing order , also might want to use a k-n air filter , :wave: -
will any crank from a subaru work on a xt ? , because my power window on the passanger side does not work , how hard is it to put in ? does any one have all the parts needed ? :wave:
'93 Loyale Wagon 3AT 4WD MPG?
86subaru replied to asavage's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i would think aleast 27- 30 mpg , my 86 spfi a/t 2wd sedan gets 29 -30 highway 24-25 city :wave: -
buy some sheep or goats , a bucket of water is all you need , and a long piece of rope or cable :grin:
The Justy is still alive and well
86subaru replied to bajavwnsoobnut's topic in Old Gen.: 80's GL/DL/XT/Loyales...
found a justy very close to me , 66,000 mi 2wd manual , white , :banana: -
where should i buy a radiator from?
86subaru replied to tompalushock's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check radiator cap, you might need a new one , is the radiator flaking or green on the outside ? -
where can be the problem? bubbles in coolant?
top of the motor , check heater hoses , this might be a bad answer but ck the over flow tank , mine went bad -
digits wanted - driving from WA to WI to KY
86subaru replied to skeet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
from greenbay wi to ky, then you might be going right by my house -
i will sell you my spare 1 for 250 bucks , in fact i will pay shipping
resistor block for fan 88 turbo wagon
86subaru replied to 86subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
thanks , will try -
my 1-2 speed does not work , it is a 88 turbo a/t fwd wagon , -
leaking sunroof 88 turbo wagon
yes i had to give mine alittle push also , if not there will be a gap and water will come in, thanks to all -
what does it look like ? and color of wires , thanks
pump shaft interchangeability
86subaru replied to MilesFox's topic in Old Gen.: 80's GL/DL/XT/Loyales...
cool. at least someone has the answer. but we would have figured it out anyway. now to get the xt on the road! -
ok thanks . -
i have a 88 turbo a/t wagon , i washed it with a power washer , when i got into the car the drivers seat really wet , any easy fix ? thanks :boohoo:
power windows 87 turbo wagon
ok, where is this red wire ? or the connecion of all 4 comming togather ? -
Where to buy: PCS & Blower Resistor
my 87 turbo wagon does the same thing , but have not checked out under the dash yet , will spray lube help those screws you were talking about ?
