86subaru
Everything posted by 86subaru
  1. ok, thanks ,the car has 180,000 mi ,new clutch, timming belts, water pump, seals, gaskets, fender, hood put back on, so it needed some work ,thanks again :wave:
  2. on my 88 gl manual 4wd wagon it seems like there is no power steering , pretty tight , has it gone bad ? thanks for the help :wave:
  3. ok , sure or i will try to do it myself
  4. yes we did the x pattern , we did not bleed the master cylinder , how is this done ? :wave:
  5. i also had the oil seals replaced 3000 miles ago :wave:
  6. i have a bad tick but only when it gets cold outside below 20 degrees , the gauge reads good cold or hot outside :wave:
  7. mine does the same thing 86 spfi a/t fwd sedan , the colder it gets the longer it lasts , but none of my other spfi motors does this , lucas may help yours or x1r which can be found at napa , :wave:
  8. i think it is a 19mm , it screws in , right behind the thottle body ,
  9. will cats drink it ? :banana:
  10. ok, me and miles fox swapped out the rear disc brakes from a 88 xt onto a 88 4wd manual gl wagon, we put on new pads rotors were good , and we bleed the brakes twice good pressure , why are the brakes still low ? and only the front brakes are grabbing ?
  11. just buy it dude , :banana:
  12. well as long as the body is good, and you can do the work your self, i bought a fwd a/t gl-10 turbo wagon for 60 bucks and it needed a headgasket , a full kit at napa was 275 bucks , but there must be 100 gaskets in the box, just my 2 cents :wave:
  13. no we have not , may change the 02 censor ,thanks
  14. also the car sat for 6 months without a hood , and aleast another 6 months just sitting . :
  15. i have a 88 gl-10 a/t wagon and it works just fine
  16. well i have 7 subaru's 1 - 2000 outback, 86 spfi sedan, 86 brat, 88 full time 4wd, 88 gl 4wd wagon, xt parts, 89 gl full time 4wd wagon, i tell her to take her pick
  17. HI JOSH . you the dude the man :cool: :cool: :cool: :cool: :cool:
  18. tried but no go , :cornfuzz:
  19. thanks for all the help , :wave:
