aaronxs400
Everything posted by aaronxs400
caboobaroo, Ive had the same thought, building the ea81 control arms. Im gonna send you a PM, maybe we can bounce some ideas back and forth.
would this stuff be suitable to do the entire bottom of the car? what about using it after some bodywork on rusted out wheel wells....could you put this stuff on then apply your paint over it? Are you guys using the their Metal-Ready prep surface stuff as well? Are you applying 2 coats? Im very intrigued by this product. Living in Ohio, this stuff my be the ticket.
what did you have to do to get the ej ball joints to fit? what year wrx? O and what knuckles?
great build but im slightly confused so ill ask here. tell me if this sounds right. 1. XT6 control arms 2. EJ hubs 3. vw struts 4. what rotors/calipers are you using? 5. what tie rod ends? 6. legacy tranny 7. shortened EJ axles and ShawnW....what do those axles fit that you have pictured?
Addco sway bars for ea81?
aaronxs400 replied to aaronxs400's topic in Old Gen.: 80's GL/DL/XT/Loyales...
one more for ya...if I was building an autocross ea81...what would you guys recommend for the ultimate suspension without going to something extremely exotic (like sti suspension). something that would take some modifing but nothing to crazy. im thinking ea82 front suspension with 5 lug swap, coilovers, addco swaybars, rear disc swap. -
THank you very much General..and everyone else who responded as well. Now...question...if I happened to swap over ea82 front suspension...which front sway bar would I want to use? ea81 or 82? -
I seen on ebay that there are several front and rear swaybars from addco. Says they fit brats and other older subarus. Are these things really for ea81 cars or is it a misprint?
ea81 Radius Rod plates? Pictures or location?
so they do nto swap then...gotcha. -
Thank you very much. Do you know what the difference is between auto and manual radius rod plates? -
EA81 Rear suspension parts 4WD vs 2wd.
thats the plan, i was just seeing if there was anything small i may be forgetting. -
Torsion Tubes 4wd vs 2wd?
aaronxs400 replied to aaronxs400's topic in Meet n' Greet. Your USMB Welcome Center
so either will work? thanks -
OK So i just want to make sure 100 percent that I have this correct: Is this 100% the list of things I need to do this swap? Flywheel Tranny Tranny Crossmember Clutch Any console/shifter pieces Clutch Pedal with brackets and cable Driveshaft Gas tank Rear diff Rear diff hanger Rear diff hanger mounts Rear suspension with torsion bar Rear axles rear brake system Thanks a million guys. Once i get this conversion done maybe ill stop asking so many newb questions -
I have finally located everything for my 4wd/MT swap. Are the torsion tubes the same, or interchangable, between both models? Thanks! I some how posted this in the wrong place...can this be moved or deleted?
Any way to ID a full time dual range tranny easily?
aaronxs400 replied to ghost's topic in Old Gen.: 80's GL/DL/XT/Loyales...
is the car your talking about an ea81 or ea82 car? what year? If its an EA81 id be intrested in everything to do my 4wd to FWD swap...except the tranny if you want it.
