naru
9
Everything posted by naru
"they have no idea on how to diagnose a problem." You need to look in the mirror,my friend. The only way to test it? Try to get at least a handhold on reality. Reading the actual CTS signal that the computer sees w/a Select Monitor or other scan tool is much superior to your long-winded approach. Your emphasis on an analogue meter is misplaced. The unburnt fuel is from the misfiring cyl.
If it is OK w/alt. unplugged,they gave you a bad one(very bad). Be VERY indignant. What yr/model?
http://cgi.ebay.com/ebaymotors/FUEL-INJECTION-PUMP-TESTER-TEST-INJECTOR-PRESSURE-GAUGE_W0QQcmdZViewItemQQhashZitem4cedb1e7aaQQitemZ330405373866QQptZMotorsQ5fAutomotiveQ5fTools This is one of the cheapo gauges I have.Works fine Lotsa sellers w/the same item.Don`t get sucked into buying an expensive one. For injectors,it is best to have them ultrasonicly cleaned and tested at a local place that does diesel truck injectors.
clicking in the center of dash
naru replied to TRAVIS75's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wildassguess-It`s a mechanical voltage regulator in the dash. -
P0420 code
naru replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Either or neither. p0420 is "Catalyst System Efficency Below Threshold" Computer sets this code by comparing the upstream and downstream sensor output voltages. In a perfect world,a faulty sensor should set a sensor specific code before the p0420. I would want to see the sensor voltages on a scan tool before replacing the cat(or either sensor). Faulty CTS could trigger this code by telling the computer to do the comparision too soon. Exhaust leaks could be a factor. Personally,I wouldn`t be too worried if the code takes that long to reset. I don`t buy the "Subaru only" theme.A sensor is a sensor.Subaru doesn`t make them.
