Everything posted by sprintman
Oil Pan Question
sprintman replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet some Auto-Rx and follow instructions on their web site. Ground breaking product available all over the world now.
Still Leaks Oil!!!
sprintman replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXget some Auto-Rx and use with dino oil. Follow instructions on the RX web site
Periodic high idle at startup
sprintman replied to NWScooby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 00 OB does same in cold weather. Hard to drive till idle returns to normal after a minute or so after cold start.
Synthetic in a new engine, bad idea?
sprintman replied to Zaphod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX99obw Valvoline tend to have lower anti-wear additive treats compared to most oils and don't do well across the board in UOA analysis with a few exceptions. There are better oils for same or lower price IMO eg. Mobil 1 Supersyn good UOA's in nearly all engines and is readily available but 30W's are on the thin side. Mobil have new M1 SUV 5W40 in the US now and should be good for an outback. I run BP Visco 5000 5W40 in my 00 Outback FWIW.
sprintman replied to Zaphod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTks blitz. BITOG is a sickness but I have learned so much there.
sprintman replied to Zaphod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have access to a Timken and it has proved very useful in looking at anti-wear properties of oils. Also we have purchased some 5 cases of Auto-Rx at approx A$600 per case and multiple testing in cars, trucks, and a lot of forklifts in particular shows what it can do. Nearly every UOA I've seen with a K & N air filter has high Silicon and users usually revert to OEM paper. There is a huge amount of info on BITOG but more importantly the industry people who participate particularly those such as Blackstone Analysis, GeorgeCLS (certified lubricants specialist), Molakule an chemist of high repute etc. Like any web site you need to read between the lines and make up your own mind.
seized cam and bent valves
sprintman replied to tjmisner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think you need a decent lawyer!!
105,000 mile "Valve Clearance" info needed
sprintman replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOil analysis will show if you have a head gasket problem. Presence of Potassium or Sodium if I remember correctly in the oil is a sure sign of coolant leakage. Oil analysis is pretty cheap too.
Oil Change?
sprintman replied to asuman1179's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFram have cardboard end caps, crap anti-drainback valves etc. Not something you want on your Sube under any circumstance IMO.
sprintman replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow do I tell for sure if my engine has shims or hydraulic adjusters. OB with 2.5 Gen III built Dec 99 sold March 00? Tks...s
Oil Change?
sprintman replied to asuman1179's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI use OEM Sube (Purolator?) on my 00 OB and after final Auto-Rx rinse phase with Castrol Formula R 5W30 will change to BP Visco 5000 5W40 with RX maintenance dose. Would use Redline again if I could afford it (I use RL gear oils only) but times are tough!
advice on syncro grinding solutions pls.
sprintman replied to jim martin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRedline 75W90NS fixed mine. RL 75W90 (not NS) in the diff, D4ATF in the p/s too. Not cheap but worth it IMO.
may 2003 oil study
sprintman replied to meep's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUOA's are the only real way to see how an oil performs in any particular engine or application. testa above show some useful info but you must read between the lines. M1 SS, Pennzoil Purebase etc show excellent UOA's and BITOG has a good UOA section. Search there for oil type or engine to see what performs best in yours.
Spark Plugs Revisited
sprintman replied to PAezb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have NGK Iridiums in my 00 OB and really impressed. Use them in a Mazda turbo as well and as good as when they were installed. If there are better plugs than these then I want to know about it?
The best engine oil out there
sprintman replied to Ma-fia's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCommuter is correct, first refine the question. And oil filters anything but Fram (cardboard end caps, they gotta be kidding). Spend some time on BITOG and you will learn heaps as I have.
Maxlife oil, opinons?
sprintman replied to EOppegaard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt was an OK oil then they reformulated it and bye bye moly. Ordinary additive package now and the basestiock is nothing to write home about. You can buy far better oil for same or cheaper. Search for Valvoline on BITOG for more info.
Cold Weather Bogging, Hesitation
sprintman replied to Chip Hedrick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChip ditch the K & N air filter. If you look at UOA's on BITOG in the Used Oil Analysis section you can guarantee that when you see high Si they will have a K & N fitted. Race cars yes, street cars you want to use OEM or similar.
Synthetic Gear Oil
sprintman replied to mheilmann's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsetright I use RL exactly as you posted. Best change ever for my Outback.
Gear oil poll.
sprintman replied to oregonloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRedline 75W90NS GL5 in trans anf Redline 75W90 GL5 in diff. Big improvement over factory fill rubbish especially cold shifting.
Oil usage
sprintman replied to rich1291's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnybody able to post the TSB on 0W30 oil?
Oil usage
sprintman replied to rich1291's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX99obw is spot on. M1 is a thin 30W. Try the M1 0W40 maybe or any 30/40W oil thats 12+ cSt @ 100C (on every oils spec sheet on the web)
sprintman replied to Zaphod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can change from syn to dino and back as often as you want to. That you can't is one of the top ten synthetic fables. I think there is a list of all ten on the BITOG web site.
clutch judder o1 forester
sprintman replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDealer replaced clutch free 6mths after warranty (3yrs) expired. Just did slave cylinder free 9mths after warranty expired. Lean on them hard!!
tire pressure
sprintman replied to monk50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOutback 36 psi all round on Yokohama Geolandars (OEM tyre) with Nitrogen fill. I run 38-40 psi in the Mazda turbo also Nitrogen fill.
2004 Subaru Forester gas mileage issue
sprintman replied to ksarkisian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUCL = upper cylinder lubricant. A must use with unleaded fuel. FPC = Fule performance Catalyst OEM = Original Equipment Manufacture And I forgot to mention never buy fuel with Ethanol in it.
