Everything posted by ABawm 88 GL
not able to toggle between vent, defrost, heater...
Does your engine idle normally but shake violently? Or can you hear a hiss coming from your motor? I just had the same problem but I found a bad leak where the dude above me said to spray carb cleaner
Zero brake pressure unless pumped
Ea82 88 gl 5 speed.... Things to note: I have blead the brakes in the correct order multiple times. My hill holder stopped working months ago and shortly afterwards I started noticing the brakes getting weaker and weaker. I have 0 familiarity with the hill holder and really can't drive without brakes, please helllpppp
88 GL bounces when idling
I had a vacuum leak :/ thanks for the help
RWD Ea82
Yesterday I sat down... Looked at the remains of my wheelbearing that managed to destroy the innards of my wheel hub. Instead of Just replacing axle and hub, I decided to remove the CV axles, cut off the hub end and lock it so that its holding the new wheelbearing... So far I've been driving it for 50 miles or so and it's holding up nicely... Just had to tell someone I was proud considering I don't do anything out of the ordinary to my cars
What should I take from this 89 XT6?
I was talking to an owner of a Subaru shop and he was talking about an early 90s Legacy LSD Diff that swaps directly into my GL... I'ma talk to him later today but I might go down that path, considering its probably built a little better than my current diff lol
Good idea, I'm gonna be able to probably literally make money off this car in the long run doing that, I'm picking it up for 250
Donno yet, but I REALLY hope it does haha... You better believe ill swap it in if it does lol
Also, both are 5Speeds... I always forget to mention something :/
I have a (Converted)Rwd EA82 spfi N/A 88 GL wagon, someone is offering me a dirt cheap 89 flat 6 XT6 and I have no idea what to take other than the 5 lug stuff? If there are any parts interchangeable between the cars that have ANY worth or even look cool that I wont notice, I would love to hear about it
I don't know the difference between the two but I've definitely made the connection between the bounce and a cam'd domestic lol so I'd say domestic
Car's on jackstands right now so if I do it'd be Sunday-ish
Car physically bounces... And yeah I really think that there might be just enough wear from the strut to the engine mount for it to shake, but isn't 700rpms still a really low idle?
88 gl 4wd spfi. My engine mounts are fine but I will try what Indrid mentioned after school today. Also a guy I know (Who really does know his old soobs) Said it might be my front struts, I'm lowered just on springs and my struts are dying so is it possible that they would make it more likely to bounce at low rpms? Only reason why I doubt that is because it stops as soon as I bring it up to around 1k.. Sorry I wasn't specific before but I'll post later on results, thanks!
help! acceleration noise
Look into your axels, mine looks fine but today it completely took a dump after doing it for a month
Ea82 dash clock ipod upgrade! Now with pics!!!!
I can't get it in like you did
Horrible miss on 89 Sub GL
Is fuel coming out the tailpipe when its idling? I really don't know much about engines but that would be a huge clue
Its idling around 700rpms and I felt like asking, before I replace stuff that I've replaced not that long ago, if anyones had this random problem. The bounce it has when idling is just horrible, can't look at your phone because you move too much haha. Thanks
Dead 1988 GL Wagon - Please Help a confused newbie
Yeah the same thing happened to me, I had to get to school and the junkyard so I just through some metal in there... I was stumped for an hour though because it looked fine haha
I got wheels!!!
Yeah it sounded ridiculous when I heard it but I never actually heard a definite answer.. And I'm desperate at this point haha
Underbody Rust advice
Thats how ya do it. My boss is making paint his truck because its rusted to all hell... It's gonna be fun sanding down a big old ford truck lol
I got wheels!!!
I heard that Les Schwab will actually take steelies and drill them for you so in an hour or so I'm gonna check up on that... But seriously the search for wheels is way to damn hard haha
Just remove the rust before you use any enamel
How are you painting your corner markers?
I was doing this just the other day, SUCH a good idea... I doubt I'll find a good solution for it but if I do i'll post in here.
Made a huge scrape along my window tint :'(
