Everything posted by Subie Gal
Annoying Under-Hood Squeaking
Subie Gal replied to Chip Hedrick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXstart the car.. put it in neutral have someone get in the car and depress the clutch pedal. if the chirpy chirp stops... it's your t/o bearing good luck! Jamie
Any of you old skool guys have or use a sandblaster?
wow you guys are too great! and this makes my decision even harder... heh we have a decent compressor... i would use the cabinet for smaller items only... i think that's the route i may go. still have some research to do, but i think i am on my way thank you everyone for your input. Jamie
okay i'm leaning towards a bench or tabletop cabinet and do i use this silica sand stuff.... (sounds scary) http://www.northerntool.com/images/product/images/155472_lg.jpg or the new aluminum oxide particles.??? compressor i have.. it's plenty large should work fine... You think i need One of these Moisture Separators <--- as well? any other suggestions? i do not plan on using this on the body. wheels, and heavier bits that need it for the most part... Jamie
94 Impreza
Subie Gal replied to Dazed Dreamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrear bumper.... rear tail.... rear glass search : www.google.com for : used-subaru-parts should find some useful info couple of my faves that have worked out well: http://www.halspartsandservice.com/ www.aaronsauto.com http://www.uneedapart.com/used-subaru-parts.html Jamie
thanks for the tips guys! was thinking of using this mainly for 360 wheels, and bits.. most of which are steel... i can hand sand the body bits... i was thinking of something like this lil unit -->click me<-- ??? what do you guys think? Jamie
yeah if i go the compressor + hose route... i'll probably buy a nice hood/gloves/mask and use a huge tin barrell or something... just not sure if the attachment/hoses work and all i all they end up costing about as much... (hose attachment vs benchtop cabinet - 27"er) but with a cabinet, i'm confined to the spacing within the cabinet... what if i wanna blast something that doesnt fit within it just not sure what to do... arrrggghhh!! jamie
Does Whiteline make a bushing kit for the 1st gen turbo Legacy?
Subie Gal replied to lastchance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhmmm i think that indeed they do. to be certain... scan their on line store? http://www.whiteline.com.au/store/ or contact maybe an MRT dealer as MRT has the lock down on all Whiteline parts. www.mrtrally.com good luck to you Jamie
103,300 mi From Original Front Brake Pads!
Subie Gal replied to Chip Hedrick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt can be done i had 75k on my 2001 RS front pads when i got bored and decided to swap them for something more aggressive.... they still have about 50% left in em.. the original rear pads are still on the car.... hehehee 103K... that's great Jamie
Steering wheel vibration/noise
Subie Gal replied to powderhound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsounds PS related to me.... did you check the fluid? how was the PS fluid level?? Jamie
Subie Gal replied to Chip Hedrick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXkinda like a cricket chirping squeak? or something else? cricking/chirping/squeaking = throw out bearing on clutch... really annoying noise too... i've gone through 4 of them chirp... chirp... chirp.... Jamie
STi cat-back
Subie Gal replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit will not be a bolt on. you'll need to likely rotate flanges to meet up... maybe even custom mid pipe also you will in all likeliness need to relocate one or more of the rear muffler/exhaust hangers... any real exhaust tuner shop can sort this for you. good luck! Jamie
heya gang diving into my 360 Sedan project and have tons of misc bits that are perfect, minus the surface rust.... they need to be blasted before I can use them... (as do portions of the car itself!) have any of you purchased your own sandblaster? what works best? gun adapter? blasting cabinet? even bench or tabletop cabinet? i've just began to research and it's overwhelming when u know squat about it!! THANKS to anyone who can shed some light and input.... Jamie
Any rally racers want to help my daughter with a school project?
Subie Gal replied to All_talk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave her email or phone me i currently rally in SCCAPro and Club rally... one of the only females out there driving - have won a few championships in the past 2 years... as well as a private hired drive up pikes peak if she's interested!! jamie@subiegal.com 800.426.1332 x161 daytime. www.subiegal.com <--my home page jamie
new sube questions
Subie Gal replied to zbase's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhy would you change your oil at 1000miles? that's total overkill... break the engine in and change it at 3k as recommended search on oil brands. many prefer different brands for diff reasons. i use a synth blend... seems to work nicely. save receipts from any self warranty work... good luck Jamie
Outback Sport Clutch
Subie Gal replied to capewaveride's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgrinding while going in to reverse is normal. until 2004, revers was not synchronized if it doesnt wish to go into R put it back in 1st...roll forward 1" or so try again... this will get the gears meshed up and make it easy peasy to get into R good luck Jamie
Last year of 2.2 in Legacy
Subie Gal replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXresearch at: http://www.cars101.com all u need to know is there. jamie
Legacy Hood interchange
Subie Gal replied to CJK440's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX95-99 Should fit just fine GT's beginning 1997 - 1999 had the scoop. good luck Jamie
NWR RallyCross Photos
YEAH i am really sorry about that.. i'm so so so tired... been working way too hard lately. (at work and at home) i'll get u guys next time!!! I'm sure someone gotcha Jam~
managed to take a few while working a control View all photos here few of my faves... STi - way to go.. good show! RHD GT4?!?! - and i thought he was gonna take us out a few times... yes, even an Evo showed up to play ahhhh.... and lookie what was on the track - yeah yeah i was in heaven great effort by NWRegion... I think everyone had a blast! See u guys again soon! Rally this weekend!!!! Jamie http://www.subiegal.com
SCCA ClubRally - Doo Wops Series March 6-7
ahhh the sound of rally cars through the forest u dont wanna miss this boys n galz! the first SCCA Rally event in our region for the 2004 Season! come see the Evo's, the WRX's, the Ford Escort Costworths?!?! yep it's true... real cars going real fast on real roads!!! Located about 45 minutes West of Olympia - this is virtually in your own backyard!! [ NWR site is down at the moment but check back often] spectator info/directions here Download Event Flier here Get out there and spectate! Get the best seats in the house by volunteering Download event flier on http://www.subiegal.com Any questions just ask! It's been too many months!! time... to.... Rally!!! cheers - Jamie http://www.subiegal.com 2003 SCCA NorPac PGT Champion
Fog Light Replacement
Subie Gal replied to boysoccer3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXanother option to consider? 1 - remove fog light from car and dry it out... 2 - replace the bulb 3 - cover both fog lights with StonGard shields. these create a solid seal and keep further moisture out of the light (the moisture is what killed your bulb) - at the same time they protect the light from further rock damage. I have StonGard light shields on all of my Subaru's... stuff, works, great!!!! StonGard is a transparent adhesive material that does not affect the light output, but does protect the fog light itself from rock/debris damage.... see: StonGard light shields here hope this helps. Jamie
Click Click, no start start
Subie Gal replied to lastchance's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcould also be starter CONTACTs.... we sell a TON of them at work (subaru dealership) cheers Jamie
NWRegion Rallycross - Feb 29th at Pacific Raceways
i dont think they've determined run times per class as they are unsure as to how many folks are gonna show up?! heck, i didnt even hear word one about this until someone posted a blurb on nasioc... then i had to check and make sure it was indeed, true. nothing like "no advertising" *laugh* i'd just show up when you can... and take it from there... unless they update the web site BEFORE the event?!? see u guys there Jamie
c ya monday and c ya @ the rallycross Jamie
get your rallycross game face on!! this on is in our own backyard boyz!! see you there!! Info HERE Rally! Rally! Rally! Jamie
