sasquatch
Everything posted by sasquatch
exactly, it's actually very, very common in all vehicles (even trucks) the sides are plastic and once cracked...you're f*d. I just replaced mine for $120....it's cheap and a pretty easy swap out. once it warms up use a flashlight and shine it on the passenger side, you probably have what looks like a hairline crack but you'll probably actually see small, sharp jets of water shoot out of it.
yeah, its stupid, but answer it anyway.
sasquatch replied to SubaSkeet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's not stupid at all. Stupid would have been to put the wrong stuff in even though you weren't sure. -
likely the hydraulic lash adjusters. I had that problem for awhile...went to replace one...smacked it with a rubber mallet, it came unstuck.....50k later problem never came back.
p.s.: what really does make that knocking noise? the monkey I keep locked under my hood.
There is a strange growling sound coming from the motor when the defrost button is engaged. I was hearing the same sound before when the A/C was pressed so I just thought it was the condenser going bad (still blows cold though)....but now on the way to work, the defrost is doing the same thing. What's up?
This is great advice....2 timing belts ago I was in to big of a hurry and I rounded off the bolt some.....I literally ended up grinding off the head of the old bolt and buying a replacement....pays to have the right tools....since them mine has come off with just a socket driver (a long one) but if it's stuck the wheel puller works well
Well, tonight I went to test my IAC...it seemed to test just fine. I pulled my PCV hose off to see if that valve was working....it was. I noticed though the the PCV hose was kinda crunchy. $0.99 later for a new hose and $2.50 for screw-type hose clamps and the problem appears to be solved. THANKS for all the advice and those that emailed me offering to sell me parts on the cheap. You guys are great.
I'm too lazy to look it all up, but FWIW... It's all pretty easy...the belt tensioners are self explanatory and are around 10 to 13mm. The main pulley bolt is something like a 22. The only tricky thing is blocking off the main pulley. There is plastic port on the passenger side of the bell housing right behind the injectors. Pull the cap off and you can see little holes in there when you turn the pulley. I use a long screw driver stuck into one of the holes. oh yeah...the hydraulic tensioner for the idler has to come all the way off. It takes a lot of pressure to push it back when you go to reinstall it. Once off, use a C-clamp to push it back in. There is a little hole well you can stick a small allen to keep it depressed. The cam pulleys move pretty easily so you'll probably have to reset the timing. Again easy stuff...on the cam pulleys as I recall there are notches in the cam pulley and then also arrows...use the notches...they line up with obvious notches on the housing. The timing housing cover? Those are just little knurled nuts with a friction fit against plastic as I recall...don't overtighten them, or they'll become useless and just spin freely in the plastic. That's all I have time for right now. good luck
Just got a free 86 GL-10 Wagon!
sasquatch replied to SubaruRichie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
holy crap, you got a free turbo wagon. Wow, good for you.
