Everything posted by sasquatch
Idle problem '90...
sasquatch replied to sasquatch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwould a problem with the IAC cause a problem with the idle even after it's warm? I think tomorrow I am going to check the middle terminal on the connector to make sure it's getting power and then pull the IAC after it is warm and see if the valve is closed. won't hurt to hunt around for problem hoses as well eh? Which hoses would y'all recommend?
Well Guys and Gals, it's been fun...
sasquatch replied to duane b's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, I'm new to the board and I wish you luck with your new vehicle. My '90 Legacy has been quirky (idle) but otherwise has been a workhorse that has been very reliable for it's 205k (so far). I do find it interesting though that anyone who seemed to care about the environment would harken back to old volkswagons (or subarus for that matter). But again, good luck to you.
1st Post - 91 Legacy question
sasquatch replied to Stickboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTiming belt is pretty easy...lots of people on here can help you before you get started.
91 Legacy power light flashes?
sasquatch replied to NoahDL88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh, okay...so it's not different driving "modes" but it's different shift "maps"
sasquatch replied to NoahDL88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's for when you're feeling "spunky" I may be wrong but without looking it up in my manual the car is supposed to have two different driving modes depending upon the needs you're asking of the car. You can actually switch between modes manually. Have I ever felt a difference? Nope.
legacy brake problem help!
sasquatch replied to speakermakers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI did know of the tendency of fluid to attract water (which I believe is why some after market brake systems use different oils in their hydraulic systems). I appreciate you clarification. Specifically though to the question...his brakes were working, he changed the pads, then they aren't working....this wouldn't seem to be due to the break down of his fluid. I am certainly no master mechanic but given that he has already tried to bleed his system there must be a sealant problem no?
sasquatch replied to speakermakers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOkay, so enlighten me...fluid can break down and be less effective but in a closed system, a system w/o seeps to draw in air or dirt, what debris is getting in there?
sasquatch replied to speakermakers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjust get a rebuild kit (should be cheap--at least compared to a whole master cyl)
THUNK THUNK THUNK when turning...
sasquatch replied to Scotty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXstop driving it until it is checked....it sounds like you may well have a front axle problem....
sasquatch replied to speakermakers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree...I've never opened the bleeder screw....opening the cap should be fine...I don't know what 'debris' is going to get into a closed system FWIW, for the pedal to go to the floor of a hydraulic sytem, I'd think you have to have something not sealted properly..... good luck..
Subaru High Mileage list and Badges
sasquatch replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is a great idea. Just recently I have been marveling at my car...a '90 Legacy Wagon I purchased in 1992 with 15K on the odometer. I have absolutely pounded on this car. It has seen me through countless moves and lots of off-road miles. I currently have 205,000 miles on the original motor w/no work having been done on the internals. Other then the occasional unsteady idle (who doesn't have that problem) it runs strong, pulling right up to it's redline. My only complaints? struts sure are expensive, I'm on my 3rd set. I also replaced the tranny w/a used low mileage one last year. She's got plenty of little dings, the paint is thin and chipped, my dogs ate the carpet in my cargo area but I love her. As we speak my wife is driving it with a front door for our house loaded in the back with the hatch CLOSED. I love this car.
I Need Help! Now!!!!!
Use the hide-a-key that you have stashed on the car you DO have a hide-a-key don't you?
throttle price..
sasquatch replied to sasquatch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, mine is on the passanger side and bolts on...strictly speaking it bolts onto the intake manifold. I have to go there today to pick up a parking light cover that some a*hole broke for me, so I'll have them pull the part. It sounded to me like they had a couple used ones that they pretty much took off the manifold with everything still bolted onto it. I have another thread about my 90's idle problem. I've only tried squirting brake cleaner where the hose connects. I haven't pulled off the whole unit. I guess I can try that next.
Online Repair Manuals...free
sasquatch replied to ststephen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReally good find...i had no idea.
"New" SUBARU LEGACY--a few questions...
sasquatch replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy '90 Legacy gets about 320 miles on a tank on a regular basis (with 206k)....with that said, it can also get 260 miles on a tank....depends which car I commute in.
throttle price..
So, I've been looking around for an IAC for my '90 Legacy. I called Foster Auto Parts (if you live in the US NW, you may know of them) Though they won't see me an IAC, they quoted me $50 for an entire throttle body...Good price no? I mean, I'm thinking I buy one (or two) and maybe the IAC will be good right?
Tach & fuel guages....
sasquatch replied to sasquatch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump... okay, that is the last time, I promise....anybody taken the dash apart on a 1st gen? Anybody? Hmmmm?
Idle problem '90...
sasquatch replied to sasquatch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou mean replaced it? No....I just tried to clean it out with brake cleaner then reset the ECU
heat shield (exhaust) rattling solutions?
sasquatch replied to flash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust today I was underneath my '90 Legacy wagon.....I came to the conclusion that the heat shields are a good idea (1) you'd need to do some cutting to get them all off (2) they are located very close to some items that I wouldn't want to get to hot (3) in several spots I have put dings in my heat sheilds that had probably saved me from a busted pipe. I just tapped all along the length with a rubber mallet. I only found one area with play...I drove a 3" nail in the seam and voila, no more ratte.
Lug nut torque specs?
sasquatch replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI prefer the German spec 'Gudentite'
This is just Tooo-o wierd, you're gonna love it.
sasquatch replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSWEET!!!! That explains what's going on with my '90 AT Wagon w/206K! I thought the rear window just wasn't pumping any fluid. Turns out I'm just driving to fast!
sasquatch replied to sasquatch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump.... I want to take the dash apart and see if I can find a connector that might be the problem. To recap, about a 1/2 the time my tach and my fuel gauge go out (at the same time). Does anyone out there have experience getting to the gauges? This vehicle is a '90 and I really don't want to break any plastic clips or what not. Thanks.
Idle problem '90...
sasquatch replied to sasquatch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI did the brake cleaner thing, reset the ECU....no dice. There might be a bit of an improvement but when the car starts up it still does it's little idle dance between 0 and 1k until it settles down around 500. The car didn't stall out when coming quickly to a stop but.... What next guys? Any more suggestions? (please)
Idle problem '90...
sasquatch replied to sasquatch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnevermind, I checked your website...thanks! I'll report back.
Idle problem '90...
sasquatch replied to sasquatch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'll give it a try tomorrow...to reset the ECU, do I just pull a fuse, wait and then reinstall? What is the fuse typically labeled? 'motor'? (I'd check before I asked, but it's dark out)
