Everything posted by mrtoyou7747
SUBY Sales increase 8% in Jan
Subaru did good - Again!! http://www.nytimes.com/aponline/2009/02/03/business/AP-Auto-Sales.html?_r=1
98 OB seatback tilt mechanism
Anyone know how to fix the seatback tilt mechanism? When you pull the lever the seatback moves but will only "lock" in one place.
Wire in switch for FWD?
mrtoyou7747 replied to rpiereck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI installed a 10Amp fuse in series with the switch - Just to be safe! BTW no diff in mileage.
Mechanic Referral Queens/LI area
mrtoyou7747 replied to Roamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've been using Al at Centre Service Station in Syosset for years. (516) 921-1300 30 Underhill Blvd, Highly recommended
another 4eat question
mrtoyou7747 replied to stumpy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't forget to place a 10 Amp fuse in that line.
Need a Carfax report
4S3BG6850W7661213 Thanks in advance
BEST OBD2 Diagnostic scanner ????
mrtoyou7747 replied to blaze's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI bought mine from Harrison R&D in TX. Connects to PC with USB port. He has several versions with different options. (OBDII, CAN bus, ABS eyc.) Enables you to see and record various sensor paramaters.
Power Steering Fluid
What types of ATF will work in the power steering of a 98 OB? Any suggestions?
Mold Smell in Cabin
mrtoyou7747 replied to mrtoyou7747's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the info. The Lysol sounds reasonable
Mold Smell in Cabin
When I turn the AC off and use the heater my car gets a very strong moldy smell. Anyway to clean this up without opening the heater/evaporator? Like some kind of additive added through the air intake (by the windshield).
Help!!!!!!!!!!
mrtoyou7747 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHome Depot has a meager selection but you can try these folks: http://rotorclip.com/ They have a full line. Probably can get a sample
Help with ECL/OBDII diagnosis
mrtoyou7747 replied to PAezb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you expand on the installation of the "Non Fouler" and what it's doing for you?
How to solder w/o a soldering iron.. or heat gun... ?
mrtoyou7747 replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou might want to try some conductive epoxy. They make 2 component RT cure. Maybe from radiocrap or autozone. apply with a tooth pick.
98 OB - Throttle / Accelerator cable stuck
While driving I punched the accerator pedal to merge onto a fast moving hiway. Once in lane I pulled back on the pedal but the car continued to rev up and would not respond to the pedal. I turned off the ignition and roled off on to the shoulder. I jiggled the pedal a couple of times and restarted it - the engine still reved out. Shut it down and opened the hood. looked at the throtle cable and couldn't see anythng odd. Had the wife push the pedal a couple of times and saw the cable move. Got back in restarted and it's now OK. Been that way for a few days. Don't know what I did to fix it but it's just fine now. Any ideas? Is a lubricant required?
OBDII info request--anyone use the BR-3 OBD-II Scan Tool?
mrtoyou7747 replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI use the Harrison OBDIIunit USB with CAN on a laptop. Works great! http://www.obdscan.net/
How many miles once the gas light comes on?
mrtoyou7747 replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 98 OBW takes 13.7 gal to full once the light comes on "full". Been like that for 134K miles and many fillups. You can ge the light to come a bit earlier if your on a hill or a tight turn like on an exit ramp but it will shut off once your stabilized. Once the light comes on full I look for a gas station.
rough shift from 2nd to 3rd on 99Leg Wagon
mrtoyou7747 replied to raybo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChange the fluid - flush the lines and the cooler (may be clogged or obstructed) - worked for me. Also installed an external filter. Seems to have fixed the problem.
Radio/CD interchange
mrtoyou7747 replied to jib's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCrutchfield will show you only those which fit your car. As well as the code probably an "I" or "J" http://www.crutchfield.com You will probably need to buy the wire harness and connect it to the radio's supplied harness for any of them. They might try to sell you a special installation kit to eliminate the "box" under the radio (at least for my 98 OB). I don't know if your's will need it. I t hink mine won't
98 OB Fog Light
Anybody know where I can get the passenger side fog lamp for a 98 OB? Tnx
Nipper HELLO can you help me?
mrtoyou7747 replied to pitstain's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI use Al at Centre Service in Syosset. (516 921-1300) Real good, honest and fair! Highly recomended. He's the man!
Fuel hose for '98 Outback
mrtoyou7747 replied to mrtoyou7747's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks a bunch - Goodyear is marked "5/16 fuel injection". Suggest also changing out the clamps as the old ones come apart and you could loose the "nut" end (happened to me). And another trip to the auto parts store. Let the engine cool way down before you start as you will loose some gas when you remove the old hoses. This will flow down onto the engine and could burn.
Anybody know a repalcement for the fuel hoses near the fuel filter? Need to know size and source. Thanks in Advance.
2000 Outback, auto transmission, gets stuck/jerks in 2nd/3rd gear
mrtoyou7747 replied to jedperry's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had the same problem with my '98 OB (135K miles) except I never got the AT light flash. I found that the transmission cooling lines to the radiator were basically clogged (very little flo) and that there was some crud on some of the spinning parts of the tranny. Cleaned the lines and replaced the fluid a couple of times and added an in-line oil filter from an older SUBY. I know that starting in '99 they started using a spin on cartridge filter but in my case the extra filter has kept the tranny working great for almost three years
auto trans filter/filters 1998 outback
mrtoyou7747 replied to bluebird's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave the xmision cooler and lines flushed as well. I installed an inline filter from an older model Suby which uses a replacable cartridge.
OBDII code P0402
mrtoyou7747 replied to kimkathan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are several OBDII readers that allow you to see the performance of each sensor. The one they use at Autozone only outputs the problem code. I think the one from Harrison let's you see the indivdual sensor. BTW try and reset the computer and see if it goes away. My '98 threw the code after I went through a puddle. Reset the ECU and it went away - it's been 2 years.
