cpreset
Everything posted by cpreset
  1. if you crank the height all the way up it decreases the life span of your cv boots the hill holder is when your on a hill and you depress your clutch and break at the same time you can let go of the break and it will stay engaged untell you release the clutch so you don't roll back as much.
  2. thanks shawn and jerry when i get around to it ill ring you
  3. well i dont have the time nor money right know i just wanted to study up and research
  4. can anyone post some links to good 5 Speed DR swap into an ea-81 car write ups?
  5. on my hatch just rebuilt the Hitachi carburetor now it runs great
  6. haven't done much with it yet just unhooked the bat im rebuilding the carb right now so after its back on ill try to check it out i was just wondering if anyone else had this problem
  7. i had it at a shop for a mechanics diagnosis of why it was not running right he said the carb needed to be rebuilt so i had it towed home so i did not have to fight it home it was not making this ticking nose when the tow truck picked it up and it was on a flat bed so i don't know what happened
  8. 85' hatch, EA-81 so i had my car towed home and now with the bat hooked up the driver side dash is making a ticking noise i don't know what it is right now i have my battery unhooked and that stopped it any ideas?
  9. anyone got one a 2 barrel Hitachi if you do send me a pm if you got the carb and a vw bug i got a weber that i never used on it im willing to trade if you are?
  10. does anyone have experience with these adapters from sjr?
  11. what i do is go around with a can of carb cleaner and spray vacuum lines and connections one by one and listen to the idel if it changes you found your leak good luck
  12. i had a simmiler issue with my ea-81 and my mechanic said that the fuel pump was putting to much gas in the carb and flooding it out and thats what caused mine to rough idle and die
  13. the sensor on theses cars sucks so before you change anything else out put in an aftermarket gauge just to make shur that you presser gauge system is not your problem
  14. that crash sounds like what happened to my parents in their 01' vw cabrio
  15. man looking at this tread makes me sad i have an 85' the same color and i'd hate for that to happen to it sorry dude
  16. looks nice i might try that. and i just noticed your from Vallejo its nice to see anther guy from the bay on here
  17. I'll throw my two cents in from experience with my bug i had something like that happen i sheared the gland nut that holds the flywheel to the crank the person i got it from over torqued the bolt on and me hoping on it sheared it. just my two cents
  18. that be great not in a rush so asap (as slow as possible). now the big question how much?
  19. i think i messed up i went to take off the small hose thats on the inlet for the carb and well the little brass pipe broke off how hard is it to get a replacement or can just jb weld it back on [click for larger]
  20. don't got a vanagon but an old bug
  21. well if you have a feedbacked carbed car the o2 signal goes through the ecm/u then to the carb and adjusts the fuel air mixture almost like fi. but with a carb
  22. here is a photo of my coil (click for bigger) and #3 is an o2 sensor hook up
  23. so iv been looking around would i need to nab the ecu if use megasquirt? and if i do use megasquirt what would i need to do conversion wise?
