Everything posted by mikaleda
How do I tow My 90 Legacy L FWD
mikaleda replied to robertmcginn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck online for used tow dollys, that would be a less expensive fix. that is what i would do.
early ej22 headgasket failure
mikaleda replied to subarurx yo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwith a good accurate torque wrench i don't see what it could hurt to re-torque the heads. one time on a mazda truck one of my neighbors had, started spraying water everywhere i went over and took a look at it i couldn't find anything. later on he had a mechanic look at it, they re-torqued the head and no more problems since. i know these subaru motors have weird things that can be wrong with them, but sometimes they can have normal things wrong with them to.
90 subaru legacy sedan
mikaleda replied to mikaleda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat's a good idea i like it. fortunately when i inspected the car better it turned out that the rotors are almost wore through and are warping causing the vibration and squeak. easy fix i can do that in a half an hour if it ever quits raining
mikaleda replied to subarurx yo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave you re torqued since you did the head gasket? i have seen these engines over heated on a couple different occasions and never seen steam come out of the oil fill tube, something doesn't sound right about that.
mikaleda replied to robertmcginn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbefore you get a dolly and tow it you might want to make sure its front wheel drive. i know i have a 90 subaru legacy all wheel drive and the symbol for all wheel drive looks a lot like fwd.
mikaleda replied to subarurx yo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhy did you change the head gaskets on the engine? where they blown or did you just want to do them because it was already out of car?
85 ea81 what is this?
i haven't got around to plugging this yet but i found out why it failed. the reason it failed is because this car was sitting for about three years and something was nesting in the muffler. when i fixed the oil seal and fired it up i revved up the engine and it blew out a bunch of insulation now it works fine! when i replace the ball joints i will plug these off.
nice i like that idea!
95 legacy auto dies occasionally while braking.
mikaleda replied to mikewilke77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave you checked you rear diff? it sounds like the all wheel drive is having a problem.
i will thanks i kind of figured as much i just wanted to make sure. what kind of emissions components can be removed when you have a Weber? if i can clean this engine up a bit i would like to, its a mess under the hood.
cool i thought that so, i did see that metal pipe you are talking about. i will do like you said and weld it shut.
i moved it to get a better pic. so yes it did melt on its own
Cat converter location 1980 Subaru?
it sounds like it that is where they are on the ea81 and ej22
can you see it now? if not here is a direct link http://i685.photobucket.com/albums/vv218/mikaleda/picture0002.jpg that's the best i can do for right now
oh that explains alot. i probably didn't do it right i really don't know what i'm doing i'm new to this. i'll look up how to insert pics and re post sorry about that.
96 Subaru Legacy 2.2l not Starting
mikaleda replied to cbeasley's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtest your cam and crank sensors. you can do that with a multi meter but if your using a chiltons total car care manual that is not fun. i did this on a 90 once and they give you the correct voltages and ohms but they don't tell you the correct prongs to test. i have seen the correct procedure in the repair forum the manual i had went from 85 to 96
mikaleda replied to mikaleda's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes i saw that and i don't have basic things like a good vice or shop where i can do this lol. i work in mother natures outdoor garage kinda sucks because we have a big rump roast garage but it got turned into something else. i like the idea of a used knuckle with a good bearing, i know where i can get one too same year and make poor thing got rolled.
yes i am just wondering what that is in the pic. i tried to describe where i found it, does that help? if not i will try to describe it better later. this is kind of secondary because at the moment i am replacing the front oil seal so i can't run it because it sprays oil every where and as far as i can see it has no use with the weber carb. also i will try to get a better pic of it all i had was my phone (i am working on it for a neighbor), i will try to get back over where it is at and get a better pic. with my camera. i will also add perspective
Mid Weber swap, I've run into problems. HELP!!!
removing the charcoal canister will decrease your mileage, and as for the cats leave them in just gut them. as for the rest i don't know that is just what i have seen on the cars with the weber upgarde.
this engine has the weber carb update. when i started the engine it started smoking really bad and i found this melting. what i want to know is what the heck is this and why when i traced it it was connected to the exaust? it looks factory but because of the weber upgrade i don't have reference. i have another car i can get parts off of to fix same engine just with stock carb. this part was on the back part of the drivers side of the engine it looks like there is a similar one on the other side of the engine to. oh ya also they have put lawn mower muffler stuffed with something for air cleaners i think that may have been part of the problem http://i685.photobucket.com/albums/v...icture0002.jpg
i am here again. this is my moms car it just hit 311k last month and we have replaced three of the wheal bearings now it sounds like the fourth one is going out! les schwab wants $220 to do one wheal bearing we had the other three replaced there. what i am wondering is how hard is it to do one of these? this particular one is the driver side front bearing. does anyone know what kind of tools i might need and/or have tips to make it easier? part of the reason i want to do this myself is i have the same year and model car as she does that has 211k on it so i know sometime in the future i will probably have to do this on my car. as always any tips, tricks, or opinions would be appreciated.
85 ea81 front oil seal
i'm going to try locking the flywheel first. i'm using a 3/4 inch drive ratchet on it the handle is about 2 feet long, i don't have to worry about the bolt being stuck lol
sweet thanks for the tip i will try this.
what is a good way to "lock the flywheel" without causing damage?
well i am working on this darn subaru brat. i finally have traced down the problem, it ended up being a front oil seal. my manual doesn't even say there is a front oil seal! my problem is the bolt that holds the pulley doesn't want to move. I have tried an impact gun on it, no results. i am wondering is it reverse threads or is it stuck? Also i need a way to hold the pulley from moving i don't have any specialty tools for this.
