5
Posts posted by Dee2
When trying to diagnose engine performance problems, an easy test to perform is a vacuum test. You can learn lots from it.
Reconnect any altered hose connections, then run the test.
It's hard to offer advice on this type of problem without some clear photos.
backfiring can be an indicator of a timing problem.
This is usually a sign that the starter solenoid contacts need to be replaced. Very inexpensive and easy to do. Several videos available on youTube. Beyond that, you may also need to add a starter relay. Also very inexpensive and easy to do. Starter relays are available off Amazon in a kit.
Is fuel actually getting to the engine ?
Getting spark at the plug ?
Distributor oriented correctly ?
Any computer codes ?
- 1
I believe so. How do i check?
https://www.google.com/search?q=how+to+check+power+at+coil&ie=utf-8&oe=utf-8
Your picture does not appear.
Also, You should stop posting "continuations" in new threads. To continue your post just reply to your own previous posting. And, you need to boil down your content. Too much information.
Post a little background, a question and then wait for an answer.
Yes, the CEL is on.........
This. Check the code, resolve the problem, then see if the stalling persists.
Hmm..
Runs with full lights for time X. battery expires and sits.
no juice means no fuel pump prime up on key turn,
after battery revives after sitting all night. Dead alternator? / dead battery combo?
I agree with jsyme. Weak battery is a good place to start, check / clean all the connections. If the problem persists, check the distributor cap for cracks. Moisture in there can cause problems.
Probably the wires grounding out somewhere. If you can access them cover them with some split corrugated tubing to keep then out of contact with the body/frame.
I'd like to get to the bottom of why the valve broke in the first place. Any thoughts?
Google "what causes burned valves".
There are many things that can lead to a burnt valve. You should look into reasons why only one cylinder has the problem.
Problem is also called 'memory steer or steering memory'. Google the terms with/without 'subaru' and you will find suggested solutions.
Dee2, I put a vacuum gauge to my motor. It runs around 17 cold, after reving it up for 10 seconds, engine misses and it reads about 13 vacuum, then after a minute of idling , vacuum goes back to 17 and the engine runs smooth. also engine runs smooth at idle after a 2 mile drive.
this guide will help you analyze the vacuum readings
...it took a couple of tries to find the sweet spot but in the end he got it started and driving
You're going to have to go through all the timing aspects...and set it right.
put a vacuum gauge on the engine and see what it tells you.
Here's a link which may help. I think part is similar for multiple engines. May be hard to actually find one though.
I would get new ones. Any parts store should be able to help you.
Sounds like it could be a valve problem. Scenarios 5,6,7,8 on the interactive chart all have similar readouts on the vacuum gauge. All indicate a valve problem. Subtle differences distinguish types of valve problems.
How do you know it's not a bad axle ?
Low milage 1990 Loyale value
Posted
They're not worth $5k. Even in great condition, I think you would be very lucky to break even. More realistically, expect to lose money if you sell it.
My advice would be to keep it and drive it.
