Everything posted by pwoens
2003 forester rough idle and will not start unless you give it gas
pwoens replied to pwoens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt does seem to start and idle better after its warmed up. I read that scoobymods thread and was leaning towards the IACV and that thread has me leaning more towards it now. Just wish they were not so darn expensive lol
pwoens replied to pwoens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo check engine lights and no codes being thrown. The AT Temp Light will flash when idle is really low. I have never understood a good way to check for vacuum leaks - any quick insight on proper route to check this? Same with checking fuel pressure - not sure how to do that?? Thanks buddy!!
Hello everyone, Kids car is a 2003 subaru forester 2.5 x 160k auto. Replaced head gaskets last year prior to kid getting her license - made her help . Once she started driving we quickly found out the gas tank had a faulty vent valve and gave us the notorious issue of slow fill at the pump. We identified the vent valve as the culprit and replaced it. (that job was horrible BTW!!). It idled and ran fine prior to replacing the vent valve in the tank but after the vent valve job was complete we have had a difficult time getting it to start without giving it gas and it idles low most of the time, especially when cold. We did unplug the battery during the vent valve job and found out this can cause a loss of memory on appropriate idle level in some cases??? Here is what I have done to date trying to resolve the intermittent bad idle and not starting without giving it gas: replaced fuel pump reset/relearn the idle by unplugging battery, draining battery, plugging battery back in, turning ignition to on, waiting 10 seconds, and ten starting the car without touching the gas. Important note: The care would NEVER run after plugging the battery back in UNLESS you gave it gas. I even tried turning it over countless times hoping it would learn on its own. This process never would work for me. Cleaned the throttle body thoroughly inspected all hoses going to fuel pump. It runs fine when you are driving it, just idles low and hard to start. unable to find a MAF on this sub anywhere Anyone have this issue and find a resolution? Appreciate any insight anyone may have.
04 Outback H6 - Auto transmission hard shift 2 to 3
04 Outback H6 LL Bean 124k - has shifted hard from 2nd to 3rd since the day I bought it. I've flushed the transmission by draining fluid, refilling with fresh fluid, and repeat 3 times. I've also replaced the remote trans filter with OEM filter. It's also received the "special" additive from Subaru that's suppose to help with the transfer clutches sticking a little (a whole different topic but should have nothing to do with 2-3 shifting). Doesn't matter on temp the car always shifts harder than it should form 2-3. Took it to local renowned sub shop and they said replace the trans. Don't believe it. I'd like to swap the shift solenoid first. How and where can I find the exact solenoid I need? Is it a pretty simple job? I've replaced the H6 HG myself so I can't imagine a shift solenoid is too complicated?? Any help would be greatly appreciated!! Thanks
Adding cruise control???
98 impreza ... Could I add cruise control easily? Or is this a big job? If it's doable what all do I need from the parts car? Thanks
Which transmissions will work for my 93
pwoens replied to pwoens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcool...ya, the turbo has a hydro clutch... so will the trannys be exactly the same, like will bell housings and all that line up? So how do I tell if the ratio's are correct??
my 93 turbo legacy 5 speed ran out of fluid and is shot....will a 92 non turbo 5spd from same legacy body style work???
Got a vibration in the steering wheel...not balance issue
Hey.... my 93 turbo legacy started developing an intermittent wobble in the steering wheel about a week ago. Sometimes it will do it when accelerating, sometimes on deceleration, sometimes not at all. Sometimes it will give a quick jerk on the wheel to the left and then release?? I jacked the front end up and both tires feel solid, no looseness like a bearing going out? Tie rod ends and cvs look fine?? Thinking maybe something in the rack/pinion?? Any experience, thoughts, or ideas?? It also does not appear to do it above 45...so anywhere from 15-45 is where it will do it?? thanks for any insight
thought i threw a rod or something bad..but
pwoens replied to pwoens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXplug is still in and has not come loose at all...just to update ya
is the ej22t non interference??
I was always under the impression the ej22's were non interference, but it hit me that I really dont know.. So is my ej22t an interference or not?? If not I should prob change the belts
Car breakdown... need to replace immediately, what Subaru to buy ???
pwoens replied to akm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX7500 is way too much especially considering they will prob just be auctioning it off anyways.. Id say 4500-5500 for seattle area.
pwoens replied to pwoens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'll be sure to keep my ears open for the ticking/knocking sounds and will check the tightness over the next few days/weeks. Any cure for it if it is in fact dabaged threads now??
Legacy problems starting after engine is warm
pwoens replied to kimkathan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfor a meger 13-20 bucks I would replace the coolant temp sensor....it fixed my problem of similar issue. If I held the gas peddle pegged it would eventually start....so next time it doesnt start try the pedal to the medal. And swap coolant temp sensor.
so the last few days I have noticed a tick/knocking sound....figured I was going to throw a rod or something. Well...today I was heading up a little hill and all of a sudden kaboom!!! sounded like I threw a rod, smoke blowing, and some loud knocking. I figured I was hosed but popped the hood to see the spark plug dangling and sparking against the fender well. What a relief...some how the plug worked its way loose and that was the ticking/knocking noise. So i put er back together and no noises......runs like a champ. so if anyone has any ticking or knocking, check your plugs first
intermittent starting problems??
pwoens replied to pwoens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXseems it was either the coolant temp sensor (most likely) or the o2 sensor along with temp sensor....replaced both cause i needed to anyways and now problem seems to have gone away....woohoo...thanks everyone.
How to unfreeze a seized O2 sensor turbo
pwoens replied to pwoens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjust used a little pbblaster and it came right out....thanks everyone
I bought some pbblaster and will saturate the O2 with that tonight but what else can I try to unseize an O2 sensor?? thanks
need "check engine" light translation/help
pwoens replied to pwoens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi think that helps explain the light on the dash..LOL i remember seeing a pair of single prong green plugs (not black) unplugged yesterday and plugging them in....thats kind of funny...what an idiot LOL. so i unplugged them and now i have a simple solid check engine light. thanks guys.
pwoens replied to pwoens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just checked and if the diagnostic plug is the big black one with nothing plugged into it, then no I have no wires jumpered in that plug. I do however have two loose wires under there....will take a pic and post it.
pwoens replied to pwoens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXya, i thought this was kind of weird that it would display it like it is...but personally, im glad it is....must have been the offer of a chocolate chip cookie that made her display the code on the dash like this :confused:
pwoens replied to pwoens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdo you guys know of the top of your head (since im at work and cant look), is this like the ea82 coolant temp sensors where its simple to get to or do I have to remove any stuff first?? dumb question...what is IAC??
pwoens replied to pwoens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXExcellent...THANKS!!
pwoens replied to pwoens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1993 legacy turbo ... ej22t ... will check the coolant temp sensor
so twice in two days the new car has not wanted to start....it just cranks over and over and over. called the old owner and she said to floor the gas and offer a cookie to it...guess what...it worked??? so what would cause it to not want to start unless its floored?? looks like I have a bad O2 but I dont think that would cause the problem?? Any experience with this issue?? thanks again
pwoens replied to pwoens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks guys...had a feeling cause it hesitates consistently. as far as displaying it...dunno...its just doing it on the dash in that format.. Anyone have an online source for cheap o2 sensors?? I can get one from NAPA for 92 bucks but maybe online they are cheaper??
