Everything posted by pwoens
Hello everyone, Kids car is a 2003 subaru forester 2.5 x 160k auto. Replaced head gaskets last year prior to kid getting her license - made her help . Once she started driving we quickly found out the gas tank had a faulty vent valve and gave us the notorious issue of slow fill at the pump. We identified the vent valve as the culprit and replaced it. (that job was horrible BTW!!). It idled and ran fine prior to replacing the vent valve in the tank but after the vent valve job was complete we have had a difficult time getting it to start without giving it gas and it idles low most of the time, especially when cold. We did unplug the battery during the vent valve job and found out this can cause a loss of memory on appropriate idle level in some cases??? Here is what I have done to date trying to resolve the intermittent bad idle and not starting without giving it gas: replaced fuel pump reset/relearn the idle by unplugging battery, draining battery, plugging battery back in, turning ignition to on, waiting 10 seconds, and ten starting the car without touching the gas. Important note: The care would NEVER run after plugging the battery back in UNLESS you gave it gas. I even tried turning it over countless times hoping it would learn on its own. This process never would work for me. Cleaned the throttle body thoroughly inspected all hoses going to fuel pump. It runs fine when you are driving it, just idles low and hard to start. unable to find a MAF on this sub anywhere Anyone have this issue and find a resolution? Appreciate any insight anyone may have.
04 Outback H6 LL Bean 124k - has shifted hard from 2nd to 3rd since the day I bought it. I've flushed the transmission by draining fluid, refilling with fresh fluid, and repeat 3 times. I've also replaced the remote trans filter with OEM filter. It's also received the "special" additive from Subaru that's suppose to help with the transfer clutches sticking a little (a whole different topic but should have nothing to do with 2-3 shifting). Doesn't matter on temp the car always shifts harder than it should form 2-3. Took it to local renowned sub shop and they said replace the trans. Don't believe it. I'd like to swap the shift solenoid first. How and where can I find the exact solenoid I need? Is it a pretty simple job? I've replaced the H6 HG myself so I can't imagine a shift solenoid is too complicated?? Any help would be greatly appreciated!! Thanks
Hey.... my 93 turbo legacy started developing an intermittent wobble in the steering wheel about a week ago. Sometimes it will do it when accelerating, sometimes on deceleration, sometimes not at all. Sometimes it will give a quick jerk on the wheel to the left and then release?? I jacked the front end up and both tires feel solid, no looseness like a bearing going out? Tie rod ends and cvs look fine?? Thinking maybe something in the rack/pinion?? Any experience, thoughts, or ideas?? It also does not appear to do it above 45...so anywhere from 15-45 is where it will do it?? thanks for any insight
so the last few days I have noticed a tick/knocking sound....figured I was going to throw a rod or something. Well...today I was heading up a little hill and all of a sudden kaboom!!! sounded like I threw a rod, smoke blowing, and some loud knocking. I figured I was hosed but popped the hood to see the spark plug dangling and sparking against the fender well. What a relief...some how the plug worked its way loose and that was the ticking/knocking noise. So i put er back together and no noises......runs like a champ. so if anyone has any ticking or knocking, check your plugs first
so twice in two days the new car has not wanted to start....it just cranks over and over and over. called the old owner and she said to floor the gas and offer a cookie to it...guess what...it worked??? so what would cause it to not want to start unless its floored?? looks like I have a bad O2 but I dont think that would cause the problem?? Any experience with this issue?? thanks again
